Question about Panasonic KV S2026C Path-Through Scanner
Red Light The Ready/Error light is on steady red. Scanner doesn't function.
  • 2 more comments
  • jimtav Jul 27, 2008
    yep - same here
  • chazola Aug 20, 2008
    I kept gettting remove paper message even though there was nothing stuck. I cleaned the scanner and then got a constantly lit ready/error light
  • tsbmd Dec 17, 2008
    same here
  • Anonymous May 05, 2009
    you are a god among ants chiwawa
  • 32 Answers
This scanner has a paper detection sensor at the eject rollers where the paper comes out. Its a reflective device that can be fooled by paper dust buildup. Look in the gap where the paper is fed out, in the center you will find a little reflective patch facing up. Use a blower bulb or GENTLE puff of canned air, followed by a damp q-tip. There are similar sensors in the vertical transport that can give the same error. Don't overdo the canned air. It doesn't remove dust so much as just re-arrange it, usually to somewhere harder to reach. I don't keep it in my toolbox, and I do this for a living. Blower bulbs are much easier to control.
Posted on Apr 07, 2009
Red error light on vupoint magic wand scanner
Viewpoint scanner manuals are available for download: http://www.vupointsolutions.com/downloads.php?d=manuals
Unfortunately I still can't get my red error light to turn off!
Jun 28, 2012 | VuPoint Office Equipment & Supplies
Hello, My Kodak i1440 scanner is blinking a steady red light. The time I turn the scanner on, both green and red blinks once then the red light get steady. what possibly could be the reason? Thanks;
First you need to see if the scanner shows in the device manager , if it doesnt it is likely the CPU / Main board is faulty If you can see the scanner in the device manager it has connected and loaded its firmware in this case it could be many things but the image guides are the most common issue , check them for damage especially the white area on the underside
Sep 26, 2011 | Kodak i1440 Pass-Through Scanner
How do I know when an EN-EL! for the Nikon Coolpix 5000 is fully charged? what do the following conditions indicate? 1. Charger red light flashing 2. charger red light steady 3. charger red light...
Charger flashing red indicates the battery is still not full and is in the process of recharging.
Red light steady indicates your battery is fully charged and ready to operate with your Coolpix 5000.
When red light is off it indicates there is no battery inserted or the charger is not pluged in.
Mar 26, 2011 | Nikon EN-EL1 Battery + Charger...
I mistakely deleted pictures from my camera (Kodax Esay Share M340) Move picture to internal memory.How can i get the pictures back
If Try one or more of the following
Ready light does not turn on and the camera does not work.
Ready light blinks green.
  • Camera is operating normally.
Ready light blinks amber.
  • Wait. Resume picture taking when the light stops blinking and turns green.
Ready light blinks red and camera turns off.
Ready light glows steady red.
Ready light is off or glows steady green.
Mar 10, 2011 | Kodak Cameras
Wd 62327 DLP red 3 blinks 1 steady red light
Call for waranty repair if less than 3 months old.
Jan 08, 2010 | Mitsubishi WD-62327 62" Rear Projection...
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Once i powered the avision 220 on, The moniter shows E and 7
When you first turn the scanner on, the READY light will blink, indicating that the diagnostics are in progress. Observe
the front panel Error LED (Red) closely. In a short time, the Error LED indicates the results of the offline diagnostics as
explained below.
Ready LED(Green) is off and Error LED(Red) indicates 7, the error indication is"Face down light check failure".
Followings are the solution for the above problem:
1. CCFL is on? Yes. CCD error, Optical assembly is to be replaced.
2. CCFL is on? No. Inverter error. Lamp inverter circuit is to be replaced.
3. CCFL is on? Yes. Issue resolved.
4. If the CCFL is still off, then CCFL is to be replaced.
Hope the above information is helpful.
Please revert if you have any doubt.
Thank you for contacting FixYa.
Regards,
TechSatya
Nov 01, 2009 | Ambir Technology Avision 220 Pass-Through...
The red lights are blinking under lamp and temp.
did you try setting the lamp over the red light on the tv?
Jul 14, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Red light flashing and noise
The user manual states the flashing red light signals that your transportation lock is on. Look underneath the scanner and you'll see a switch for "lock" and "unlock." If the switch is turned to "lock" move it over to "unlock" and plug the usb cable back into your computer. It should work with no flashing red light. If not try restarting your computer and plugging it back in again.
Mar 30, 2009 | Epson Perfection 2480 Photo Flatbed...
Ready/Error Light
IT have just been down to look at our scanner & cleaned the sensor which is in between the rollers just where the paper flits out at the bottom - we now have a green light! So look for that sensor.
Apr 18, 2007 | Panasonic KV-S2046C Pass-Through Scanner
Panasonic KV S2026C Path-Through Scanner Logo
1,290 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
