Question about Technics Audio Players & Recorders
Technics amp model saex120. information on digital front reads "system overload" and will not produce sound.
    Genius:
  • Technics Master
  • 1,550 Answers
The audio amplifier IC are damaged you need to replace them.
Posted on Jul 04, 2008
Overload comes up on receiver when sound starts what causes this?
too many cables from outlet , use dedicated power source 12 amp
Aug 30, 2014 | Audio Players & Recorders
Hi, I'm digitising my old cassettes. I have a
Just connect the line outputs from the tape deck to the line input of the computer using a dual RCA to mini stereo adapter if necessary. Your processing software will correct any deficiencies and produce satisfactory results. Be sure to copy the original tape information before dumping the old tape; otherwise you will have a "mystery" CD
Sep 08, 2013 | Audio Players & Recorders
Technics SA-1000 Volume Level low
Hook the speakers to the remote terminals on the back and switch the front speaker control to select the remote speakers. If you have audio, your main amp channel may have an issue....
Sep 18, 2017 | Audio Players & Recorders
I'm considering buying the 180636 "surround sound bar speaker system." My question is, is this JUST a speaker system, which needs to be connected to a separate amplifier or "home theater...
The bar speaker system needs to be connected to an amplifier. What the bar speaker does is replicate a five speaker home theater system using just an amplifier.
The only thing that will give you a better sound quality is some type of amplifier/speaker set-up, wether you choose to have an amp and two speakers or and amp with five speakers and a subwoofer is up to you.
Nov 30, 2010 | Audio Players & Recorders
Stops working and reads Overload
hi there i have had this problem with technics amplifiers generally with them it was negative and positive mix up between input terminals for the speakers or in other case's running the amp with 2 many speakers.
eg. having 2 speakers Bi wired into 1 input making a 6.1 receiver into a 12.1 which makes the amp struggle causing overload or the worst case is a power unit problem.
Aug 01, 2010 | Panasonic SA-HE200 Receiver
OVERLOAD
First of all the KEF is a powered sub which means that it wants a line level signal NOT a speaker level. Send the signal from a tape output or pre-amp output to the sub input. The overload is because the impedence load for the speaker output is too low and looks like a short to the amp. Continued attempts to connect the system as described will result in damage to the output section of the amp.
Please let me know if you need more info.
Dan
Feb 03, 2010 | Technics SA-DX750 Receiver
I have no sound and it reads overload and tells me to turn off power. what do i need to do?
Hi
I have the same problem and a common problem with this model is :
"Technics models are sort of notorious for bad solder connections, especially
at the output IC's and regulator transistors. "
I hope this helps you
Sep 08, 2009 | Technics SA-AX540 Receiver
Overload
The manufacturer is Panasonic which uses the brand name Technics for consumer products. The unit is shutting off because a problem is detected in the amp section. This particular model uses an Amp-pac which is a single component that contains the entire output amp. That part is likely to be defective. The part number is: RSN3306P and is available for $65.73 from tritronicsinc.com
Dan
Feb 26, 2009 | Audio Players & Recorders
Overload message in technics model SA- EX400P-K I have an older Technics system. It has worked great for years but now I get overload whenever I turn it on. Have changed speaker wires but no use. Any...
The overload message is the old version of "protect" mode. This means that a problem has been detected in the output amp section and that section is shutdown to prevent further damage. Your unit uses amp-pacs. One or more are bad. These are marked RSN3305P and cost about $66 each.
Dan
Jul 15, 2008 | Audio Players & Recorders
229 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
