Question about OKI MICROLINE 320 Turbo Matrix Printer
Problems with Printing Special Size Forms
We have a Oki Dot Matrix Printer (OKI Turbo 321n) that we are having problems with printing our special size (3 1/2 by 4 1/2) order tickets. The forms are being printed from a Sybase Powerbuilder application and we have set up a special form size.
The problem appears to be that the printer is ignoring the form size and is instead printing a 8 1/2 by 11 size document. It is also generating an extra form feed for each print record. The printer prints the information on the correct spot on the first form (vertically and horizontally, but then form feeds to the top of the fifth form. THat is it prints the first form correctly, but with the wrong length(11 inches) and then does another form feed. Consequently we are wasting 3 forms for every one that we print.
Any help would be greatly appreciated.
    Master:
  • 788 Answers
First I would print the menu settings by going into menu mode (Shift+Sel keys) then pressing the print key. Then I would reset the printer to defaults by turning it off and turning it back on while holding the Sel+LF keys. Then go back into menu mode and make sure to match the emulation mode, character set, language set, code page, page length, and all the Parallel I/F settings. Then try your print job again. If you problem still exists then it is most likely that your application of driver on the comptuter is sending the extra lind feeds and that the problem is not with the printer.
Posted on Jul 04, 2008
  • Dean Joly
    Dean Joly Jul 04, 2008
    You will also most likely have to use the top feeder and set the page length control option in the top feeder section of the menu to actual page size as the printer has no option for 4.5" page length.
  • 2,071 Answers
On the PC that is giving you the problem;
Make sure that the paper size in the printer setup is correct.
Make sure that the paper size for the report (in access) is correct.
I have a program (access) and some of the reports in it have margins down to .3 and it if the printer is set to us - Letter paper size instead of A4 I have the same problem as you.
  • 105 Answers
Try to change the application which is used to print and test it with another application which is suitable for printing.
    Genius:
  • 1,847 Answers
You have to chk the setting on the print setup.
  • Legin Varghese
    Legin Varghese Jul 04, 2008
    there is nothing wrong with the printer.
    This has to do with the printable area issue. 1st chk the software which you r u using to output the print.
The printer cannot be set to a page length when printing from a dos program. The page length is incorrect but changes with every print even though the same file is printed
Prints from DOS programs do not have a "page length" setting of their own, nor do dot matrix printer have a page length of their own.
Page feed is achieved by sending a special control code (^L), and the meaning of ^L can be set through specific escape codes that the DOS program has to know.
My guess is that you need to tell the DOS program the page size in lines or inches, and maybe instruct it to send a page feed command after each page.
You can try directly programming the printer, but if the DOS program is sending out the wrong codes, this is not going to help. Anyway, here goes. Good luck!
http://www.masondesigns.com/staging/dhl/printer/lasernet/turboset.html
Feb 01, 2010 | OKI MICROLINE 320 Turbo Matrix Printer
Oki 320ml dot matrix printer pauses while printing and the menu light start to flicker.It resumes printing after a while. Why?
The printhead has some thermisters in and it is either actually overheating or a faulty thermister thinks it is overheating. Either way, a new printhead is required.
Jan 14, 2010 | OKI MICROLINE 320 Turbo Matrix Printer
I have limited option for my TVSE HD-745 Dot
Paper size and pagelength are normal set by the incoming print datastream.
You can usually set this up from within the application you are using to generate the print datastream.
Let me know if I can assist you further.
Don
Jan 13, 2010 | OKI MICROLINE 320 Turbo Matrix Printer
PRINTING INDIVIDUAL SHEETS, MACHINE WILL **** PAPER THROUGH ONCE AND THEN BEGIN PRINTING THE SECOND TIME IT IS INSERTED
This sounds like a printer driver problem. Reinstall the driver from the Printer disc (or get one off the web). Failing that it may be because the paper size set in the PC wordprocessor doesn't match what is set in the printer software.
Dec 01, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
How i can copy the custom paper size for oki 591 to other computer
you can not copy the custom paper size to other computer ....you ca nconfigure same paper size in other computer..........
  1. open printers and faxes
  2. From the File menu select "Server Properties" (Print server properties)
  3. Forms tab
  4. Click "Create a New Form" and add information that you want
  5. Click OK
Oct 08, 2009 | OKI MICROLINE 591 Matrix Printer
OKI DATA MICROLINE 320 TURBO PRINTER PROBLEM
Hi Charles,
Use the IBM proprinter driver for this printer and select IBM in the menu of the printer.
Hope this helps.
Dezzi
Sep 10, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Pharmacy labels are printing so big they are taking up two labels.
Try deleting the Oki from the Printers and Faxes folder and rebooting.
Windows may have screwed up the driver.
If that doesn't work, use Add New Hardware but don't let it choose the driver, use the manual option and pick your Ok model from the list.
It may have stupidly installed the 320 instead of the 320T driver; they may be different.
Aug 02, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Oki microline 320 turbo printer
Did you check your print queue? May be there is an error in there waiting for you to instruct it.
May 22, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Sugest my problem
Will printing 4 lables and then will skip 4 lines and then print again
Mar 23, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
OKI MICROLINE 320 Turbo Matrix Printer Logo
749 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
