Question about JVC Cameras
I have a JVC camcorder gr-d850 and a mac. I'd like to take advantage of the dv in/out. Do I need anything other than a firewire cable? Do I need any specific drivers? When I hook up the camera to the mac using the firewire cable the mac doesn't see anything. Thanks
  • frogleystuff Jul 08, 2008
    I have a JVC camcorder gr-d850 and a pc (windowsXP). I'd like to take advantage of the dv in/out. When I connect a firewire cable to the camera, it doesn't see the camera. Do I need special drivers or program? If yes where do I get them? I can't find them on the JVC website.
    Thanks
    I don't have a usb cable that fits the 4-pin connection on the camcorder.
  • 4,889 Answers
Youd dont need any software. All you need is a firewire cable. Have a look at this video that explains how to upload video from your camcorder to mac.
Posted on Jul 11, 2008
    President:
  • 2,712 Answers
    Guru:
  • 859 Answers
Do I understand you are on a MAC? What OS version of the MAC are you using?
You can open up Boot Camp and then hook up your camera via Firewire which is the only way to connect a DV Camcorder to a MAC anymore. From inside Boot Camp you may be able to install the software that came with your camcorder or it should then be recognized as a dirve, which you can open and copy the contents of your video over to the hard drive. From inside this program you should be able to convert the file to a MP4 at least, which a MAC can access as well as good old avi.
Regards,
Worldvet
Posted on Jul 09, 2008
  • 6,487 Answers
If this camera can be connected via USB try it that way so we can check if only the firewire connection is the problem..
Hope that helps.....
Posted on Jul 08, 2008
  • Mark Gil
    Mark Gil Jul 08, 2008
    Go into Device Manager and see if you have an IEEE 1394 Bus Host Controller, and if you do see if it is working properly by looking at the Properties. Did you get an installation CD with your camcorder? Can you try your camcorder on someone else's computer to see if it will pick it up.
    Hope that fix it..........
  • Mark Gil
    Try this one also :
    1. Make sure that you have your cards seated and screwed in tightly.
    2. Load all appropriate drivers, go to the windows or manufactureers web-sites and make sure you are current.
    3. Make sure that the camera is off. Attach the firewire to the camera.
    4. Attach the firewire to the PC.
    5. Do not start your editing program yet.
    6. Turn on your camera and wait for the OS to recognize and load the appropriate device. DV IN on your camcorder doesn't mean you have a successful conection to the PC. It just means that the camcorder sees the cable is plugged into the camera.
    7. If the Digital device dialog window pops up, click on the appropriate program link. I always click take no action and then load the program.
    8. If you do not get the device loaded, go to start/my computer/control panel/system and click on hardware device manager. Click on any of the listings, then click on the scan for new hardware icon of menu pull down.
    9. If the camera is not added, or has a problem, try to reload the drivers.
    10. You can always try adding the device under the scanners and camera section of the control panel menu.
  • JVC Master
  • 13,433 Answers
Does the usb connection work? Il see if I can find you a driver
  • 3 more comments
  • Ekse Jul 08, 2008
    Heres the user manual
    http://books.jvcservice.com/Download/491...
    the drivers are on the cd, install the software the driver comes with it if not its on the cd.
  • Ekse Jul 08, 2008
    When connecting the camcorder to a PC useing DV cable, make sure to follow the procedure below. Connecting the cable incorrectly may cause malfunctions on the camcorder and /or the pc.
    - connect the dv cable first to the pc and then to the camcord
    - connect the dv cable plugs correctly according to the shape of the dv connector
  • Ekse Jul 08, 2008
    see page 42 in the manual, let me know if you need further assistance.
    Thanks,
    Ekse
  • Ekse Jul 08, 2008
    usb is only used for still images and reading the memory card, so you will have to use the dv cable for transferring anything else.
  • Ekse Jul 08, 2008
    you can also try reinstalling the ieee1394 controller
    open up device manager by right click my computer, select manage.
    Select device manager from the left side, then find the ieee controller right click and select uninstall.
    Ones the device is uninstalled you can either reboot the pc or click on the
    scan button to reinstall it.
    if reinstalling doesn't fix it try uninstalling and then restarting it will get reinstalled after the reboot.
    see if that does it.
    Guru:
  • 1,894 Answers
This wont work with MAC. you need to use windows
Posted on Jul 04, 2008
I need to connect my JVC GR D820 with a notebook, where did I download a driver ?
JVC have a FAQ page that might help, at THIS LINK. Question 8 is the one you want.
This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection for stills (if they have one) and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. You don't say what kind of notebook you have, but if it is a Windows one, you probably don't have a Firewire socket.
Nov 17, 2010 | JVC GR-D850 Mini DV Camcorder
How to transfer the video to my laptop and how get a driver and software.
Jvc GR-D850 MINI DV CAMCORDER driver downloads is available in the product website.Download and install it
Sep 04, 2010 | JVC GR-D850 Mini DV Camcorder
I have a jvc GR-D280 mini dvd camcorder i can not download through my dv to usb cable xp computer can not find the device
USB connection is only for the still photos on the SD card. If there is no SD card in the slot, it will not load.
Video has to be transferred via the firewire cable.
Mar 03, 2010 | JVC GR-D850 Mini DV Camcorder
I WANT TO KNBOW HOW TO CHARGE MY BATTTERY JVC GR-D850
If you have the GR-D850US here is the manual.
It will tell you how.
Make sure you use new batteries if yours are over two years old.
Good luck.
http://books.jvc.com/booklist.asp?Model=GR-D850US
Nov 21, 2009 | JVC GR-D850 Mini DV Camcorder
How to upload recorded movie to PC using USB
Do I need a driver so that Windows XP recognize my JVC GR-D850 when I connect it thru USB port? If I need, where can I get it?
Mar 24, 2009 | JVC GR-D850 Mini DV Camcorder
JVC GR-D50 not seen by PC or Mac via Firewire
Could it be a bad cable or a bent/broken pin where the cable is connected to?
Nov 11, 2008 | JVC GR-D50 Mini DV Digital Camcorder
I NEED A JVC DRIVER MODEL GR-D850AA
I found a Fix for vista with my GR-D850 jvc the Startech.com (3 port IEEE-1394 firewire PCI Card) works on vista when installed the pci card I was able to down lowed to windows movie maker with no problems.
I hope this helps
Aug 27, 2008 | JVC GR-D850 Mini DV Camcorder
Jvc gr-d72u
use firewire cable from your dv port to stream video-4-4 pin for laptop 4-6 pin for mac or tower
May 17, 2008 | JVC Cybercam GR-D72 Mini DV Digital...
Cameras Logo
88 people viewed this question
Top JVC Cameras Experts
Parshiv Luthra
Michael Galve
Michael Galve
Are you a JVC Camera Expert? Answer questions, earn points and help others
