Question about Quark Academic QuarkXPress 6.1 for PC
Quark picture files
Can anyone help??????
Quite often I have to work from home. So I have to copy work to an external HD. When I open any quark files from the external all the picture links are missing so I have to go through and re-link the picture files. Any ideas as to why this is happening???????
Since you're copying your Quark file to an external HD, I assume that you're also copying the image files? What you should do before copying to the external HD to work on the file at home is under the File Menu, use the 'Collect for Output' feature, which may take a while depending on the size of your file, number of images, etc., but then you can use the Quark file from the xternal hd, and back and forth to your computer without having to relink the picture files all the time.
Posted on Jul 21, 2008
Yes, max osx 10.4.11 and quark 6.5
Below is a standad mac fix-all and a quark fix-all but it could be something else that has happened, after looking on forums there appears to be a problem with this type of problem which quark never bothered fixing in 6.5. I would also instal the quark update from 6.5 to 6.52 from http://www.quark.com/support/downloads/Details.aspx?fid=122 before you do this it may correct it.
Mac Fix-All
Another thing I would do is go to the applications folder and then the utilities folder open up disk utility once opened click on your hard drive and then click on repair disk permissions and let it complete the verification and repair (it could take 20 minutes or more) depending upon the size of your hard drive. A lot of people do not this but to keep your machine running efficiently it should be done on a monthly basis.
Quark Fix-All
It could be that your quark preferences have corrupted, I would go to your users folder then go into the library folder, then the preferences folder and then the quark folder within the quark folder there should be a file called "XPress Preferences.prf" move this to the trash (But do not delete it yet). When you open quark next it will recreate the preference file and hopefully that will sort it out. If this has corrected the problem you can then delete the file in the trash. Please note that you will have to reset your preferences once you open Quark again.
Hope this helps in some way.
Nov 16, 2011 | QuarkXPress 6.5
Running Mac OS X (Snow Leopard)....Quark 7 will not launch due to damaged application preference....says to delete file and relaunch....that does not work... Also....when Quark was working on OS X (Snow...
It could be that your quark preferences have corrupted, I would go to your users folder then go into the library folder, then the preferences folder and then the quark folder within the quark folder there should be a file called "XPress Preferences.prf" move this to the trash (But do not delete it yet). When you open quark next it will recreate the preference file and hopefully that will sort it out. If this has corrected the problem you can then deleted the file in the trash. Please note that you will have to reset your preferences once you open Quark again.
Hope this helps.
Sep 13, 2011 | Computers & Internet
I am using QuarkXpress 6.5 which was working fine until yesterday. But since today morning, I am not able to open it, neither does my .qxd/.qxp document open. Please help asap. I am on a deadline.
Hope this helps.
Jan 18, 2011 | QuarkXPress 6.5
Quark won't open file
This is most likely a version problem. Quark 6.5 won't open any file from a newer version (Like Quark 7 or 8)
Nov 19, 2010 | QuarkXPress 6.5
Error 1720. Trying to install Quark 6.1 on Windows 7
I definitively solved this problem. Follow these steps:
1) Install first Quark Xpress 6.1 on a Windows XP PC.
2) Copy the entire directory of installed files (Normally c:\program files\quark) on a pen drive.
3) Install Quark Xpress 6.1 on your Windows 7 PC until the installation stops with 1720 error.
4) Abort the installations, then copy the Quark directory stored on your pendrive in c:\programs x 86 directory overwriting the existing one.
This way Xpress 6.1 works perfectly on a Windows 7 PC. Guaranteed!
Sep 02, 2010 | QuarkXPress 6.1
When I try to open my Quark 6.5 the icon spins but Quark will not open. I turned off suitcase but Quark still won't open.
Please Navigate to HDD>>Users>>Home User>>Library>>Preferences>>Quark>>QuarkXPress 6.5 folder and delete all the files present in that folder.
Also check if there is any Preferences folder under HDD>>Applications>>QuarkXPress 6.5 folder, if yes then delete that folder as well.
Now launch QuarkXPress and check the results.
Dec 10, 2009 | QuarkXPress 6.5
Quark won't open. I have shut down, completed repair permissions . . . no luck. Starts to load and immediately quits. This started after doing an update on Microsoft Office. What can I do? I am using Quark...
This is for Quark on a Mac. What you could do is go to users then which ever user is the active one then library then preferences then quark then QuarkXPress 6.0 (or may say 6.5) in this folder is a file called "XPress Preferences.prf" move it to the trash (Do not empty the trash if it does not work you can replace the file back into the preference folder) and then start up Quark, it should rebuild the file.
Please note your preferences will be back to default and you will need to reset them.
Hope this helps.
Nov 11, 2009 | QuarkXPress
Quark 6.5 error code 10660
Just open the file once and save it and it should work.
You can also try adding a .qxp extension to it and then try opening the file
Jun 16, 2009 | QuarkXPress 6.5
Can't open Book files in Quark 6.5 Mac
Try opening the book first and then the chapters and it should work fine
May 21, 2009 | QuarkXPress
Join a seperate quark page to my main quark project
Trash yorr Quark Preferences and restart. Try opening 2 new documents.
If you can do that, the problem is not Quark. It is the file you are working with.
Dec 30, 2008 | Computers & Internet
Quark Academic QuarkXPress 6.1 for PC Logo
134 people viewed this question
Top Quark Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Michael Galve
Michael Galve
Are you a Quark Computer and Internet Expert? Answer questions, earn points and help others
