Toshiba Portable DVD Player
"No valid disc" comes up on the screen when I put a disc in. Has not always been a problem. Toshiba SD-P1900
  • docindakar Aug 02, 2008
    When "loading" a DVD on the Toshiba SD-P1900 portable DVD player, "No Valid Disc" comes up on the screen. It doesn't appear that the disc is spinning which tells me that I need a new motor. How can I get such a motor and how do I go about replacing it?
  • raresolid Mar 30, 2009
    I have the same problem. i watched about 5 movies and then it stopped working.
5 Suggested Answers
SOURCE: No Valid Disc - Toshiba SD-P1900
one thing I tried that works so far, (now I jinxed it) is if when I put the disk in and close the dvd cover and I don't hear it starting to spin, I turn the machine off and then back on again...so far so good.... Technology rules!!!
Posted on Jun 24, 2008
SOURCE: my toshiba portable dvd player (sd-p1900) won't
i had this same problem, its likely a disconnected ribbon wire off the drive, One I plugged that in it read/spun the disk, now I just need to get the screen to stop being blank white heh. Good luck ^^
Posted on Jul 20, 2009
fieldy14
  • 456 Answers
SOURCE: my Toshiba portable dvd player says no Valid Disc
If the units under warranty you may want to contact Toshiba as it sounds your unit is in need of a replacement laser assembly.
If the unit isnt under warranty, Toshiba should be able to supply the parts you need and as long as you mark every thing that you remove, as to know where it goes when re-assembling the unit. The lasers arent difficult to replace. Good luck.
Posted on Jun 07, 2010
walesarumi
  • 6993 Answers
SOURCE: Howdy...I have a Toshiba SD-P1900
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
Posted on Jun 23, 2011
Dvd not spin player
You need a spacer; without it reading is impossible
Aug 25, 2014 | Toshiba SD-P1900 Portable DVD Player
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
Disc doesn't spin
Hello
Check whether the disc inserted into the player spins. If it does not spins, replace the sled motor.
SD-P1900SN After inserting movie DVD, I get message, "No Valid Disc". I ensure disc is inserted properly. Bought player a couple of years ago. Have only used it 3 times. Can't find anything in manual...
Check for cracks or scratches on the dvd disc?It a dvd movie disc,not a computer program dvd disc?Take the dvd disc,washes it with some dish washing soap.To clean all the grims and grease out of the dvd disc laser surface to the dvd player laser eye to read the dvd disc.
Jun 17, 2010 | Toshiba SD-P1900 Portable DVD Player
Hi When I turn ON my Toshiba SD-P1900 player,with
I brought my dvd player to the Toshiba repair center. To be continued...
Nov 26, 2009 | Toshiba SD-P1900 Portable DVD Player
Disc read error
Dear Sir,
After 2-3 years generally all optical drive lenses goes bad,so first try by cleaning lences,if it not solves your problem then try by replacing lence of your DVD Drive,if you have any problem regarding this issue leave a feedback we will glad to assist you.
have a nice day
good luck
Sep 11, 2009 | Toshiba SD-P1900 Portable DVD Player
My toshiba portable dvd player (sd-p1900) won't play discs. We have two, and the other one works, so it's not the disc. When you put a disc in, it doesn't spin, and it says that there is no disc.
Jul 14, 2009 | Toshiba SD-P1900 Portable DVD Player
Yep sone of a gun ! With the Toshiba Portable DVD Player, hold the "Mode button" down for several seconds and it will make a chain saw noise take your finger off, hit it again once and bingo now it works. I was ready to throw this player in the trash!
Jan 17, 2008 | Toshiba SD-P1900 Portable DVD Player
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
Electro Med Services...
