Question about Levelone Level One FreeCon 802.11G Outdoor WAP 108 Mbps (WAP-1001)
Very slow connection!!!
I'm working in a company and we recently installed level0ne wap-1001 in order to connect two networks.It's a simple workgroup network with a server and 5 pc's.Three in the main building where the server is and two in the building that we wanted to connect wireless!We finally manage to connect but we are facing a problem of a slow connection in the network in the building that it is connected wireless.We can see the shared forlders from the server but when we're trying to open or to use an application it takes ages!!!Any solution of how can i enhance the signal or something else in configuration tab???I also have to mention that betwween antennas intermediate power cables but i put the antennas 50 cm under them so they can see themselves diretly!!!Please Help!!
My acsses level one wap-1001 not wourk after firmwer i do four it
from wep sit orgenal
she is tern on 15 sac and of anther tin
i ned th eprom in sed the acsses to sheg th flash in sid it
ples kan yow help me pless>>>>>>>>>>>
Posted on Aug 17, 2008
  • fadefdas Aug 17, 2008
    my access level one wap-1001 not work after firmer i do four it
    from weep sit original
    i ned th eprom in seed the access to sheg th flash in sid it
Why i cannot factory reset username, password and ssid ap? and i just can factory reset ip ap
What are you connecting the wap-1001 to? An existing network . Does the subnet mask match it defaults to 255.255.0.0
if the p.c you plug directly into the ethernet connection of the ap has a different subnet mask it can't talk to the router. how does your p.c get its ip address is it static or dynamic via dhcp server . ip is default of 192.168.1.20 also is anything assigned 192.168.1.20 .
http://download.level1.com/level1/manual/WAP-1001v1.02_UM.pdf
the default password and user name is in the user manual
Jun 17, 2015 | Levelone Level One FreeCon 802.11G Outdoor...
How to make vista act as router? without using any outside router !! the inbuilt wifi syatem should act as router..
Yes well IF you use two network cards, a WiFi Adapter & an Ethernet Adapter, you can do this, now with a WiFi adapter, as you say, What you do is connect to the internet on the PC, and "Share" the internet connection via the WiFi. You set up the WiFi as either an "Access Point" or a an "Ad Hoc" network, if you want to communicate with the "Other" PC's, and have then communicate with you, as well as access the Internet. So setup is simple, using the manufacturers DVD install the WiFi. card, then, Set it up as you wish, the PC's that connect should be in the same Workgroup, have sharing enabled and be passworded too then as said connect to the Internet and the "Other" pc's will be able to "Burrow" out through you Internet, through the ADSL Modem attached to the "Main" PC. Usually via the Ethernet port. You still need to set up an SSID and use a WAP/WEP key for security. on the WiFi card.
Mar 08, 2010 | Microsoft Windows Vista Home Premium with...
Vista cannot discover XP hosts
This happens if Vista retains history of network devices that once existed on your machine, but do not exist anymore.
Follow the steps at the link below for solution to your problem:
http://techs4u.wordpress.com/2009/08/04/windows-vista-network-connection-cannot-be-renamed/
Jul 30, 2009 | Microsoft Windows Vista Business Edition...
Vista Zombi Eternet Card
If have a problem with Vista and XP workgroup networking.I suggest you find the answer from this website:www.adapterlist.com,It's very cool.
Jul 27, 2009 | Computers & Internet
Facebook connection problems Transport error (#1001)
I found a simple solution. Try and see if this works for you too.
1) Go to Privacy Settings.
2) Click Application button.
3) Click Settings tab.
4) Uncheck any of the boxes. (For me I unchecked everything except Profile picture, Basic info, and Online presence)
5) Save changes.
After doing that, all my applications started working for me again. Hope this helps.
Jun 11, 2009 | Facebook Social Network
Network is running dead slow...
Please make sure that all the cables are in good condition, if not replace them with high quality ones for better speed. Make sure that there are no hardware on software conflicts in the server and the client PC's. Run regular maintenance.
Have a look at this article which is on client performance tuning.
http://docstore.mik.ua/orelly/networking_2ndEd/nfs/ch18_01.htm
Mar 19, 2009 | Dell Computers & Internet
Using multiple networks
if you are using windows 2000 or later start the routing and remote access service (make sure to set it to automatic) and that should solve your problem.
Jan 13, 2009 | Intel REALTEK nc-r150201 Network Adapter
What is enterprise network?
During the 1980s, organizations began to install local area networks to connect computers in departments and workgroups.
enterprise networks would let people throughout the organization exchange e-mail and work together using collaborative software. An enterprise network would connect all the isolated departmental or workgroup networks into an intracompany network, with the potential for allowing all computer users in a company to access any data or computing resource.
An enterprise network is both local and wide area in scope. It integrates all the systems within an organization, whether they are Windows computers, Apple Macintoshes, UNIX workstations, minicomputers, or mainframes.
An enterprise network can be thought of as a "plug-and-play" platform for connecting many different computing devices. In this platform scenario, no user or group is an island. All systems can potentially communicate with all other systems while maintaining reasonable performance, security, and reliability.
gimme ur acknowladge by rating me
Thanx
Romy
Dec 24, 2008 | Computers & Internet
WAP
Sadly your question is too simple, as it depends on many factors, what country you're in, which network, etc.
In theory the button with the globe symbol just above the send/dial/answer key should be your hotkey to WAP. Some operators will not allow you to use WAP (and other things like MMS and voicemail) until you have made a chargeable call. You may also need your provider to send you settings by text in order for WAP to work, especially if you have used this phone previously on another network. Some providers block WAP on pre-paid by default as data rates can often be high and you can use up credit very quickly. That doesn't mean you can't have it, you just need to ask your operator to activate it.
Dec 29, 2007 | Motorola Mobility W375 Cellular Phone
Levelone Level One FreeCon 802.11G Outdoor WAP 108 Mbps (WAP-1001) Logo
151 people viewed this question
Top Levelone Computers & Internet Experts
micky dee
Prashant M
Prashant M
Are you a Levelone Computer and Internet Expert? Answer questions, earn points and help others
