Question about Jl Audio Car Audio & Video
Power on green light is on but no sound when speakers are hooked up
    Problem Solver:
  • 11 Answers
Light is on so suggests power, earth and remote turn on cable all ok. Now you just need to test the RCA signal and the AMP output. I take it you have used low level RCA as the input from the head unit? (two cables usually red n white although can somtimes be other colours) best way is with substitute amp n speakers etc although can be done with osciliscope or headphones. Once it is established the RCA signal is fine then you can check the speakers from the amp. disconnect them at the amp and put each of the two wires briefly to a battery, any battery will do e.g. 9v PP9 or 1.5v AA etc you should hear a pop from each speaker as you do it. that proves the speakers and wiring to them.
If there was no signal from the RCA the cables may be bad - requires testing from head unit to amp
failing that the RCA output may be reduced or turned off via a menu in the head unit
Or the RCA output from the unit may be knackered.
Sorry its a bit long hope it helps
Posted on Jul 04, 2008
Lights on woofer blink green for second than no lights at all
Little late I know, but.. when you power off the tv it SHOULD turn off about 25 seconds later. Assuming thats how you have it hooked up is directly to the tv.
Jan 25, 2016 | LG NB3730A Sound Bar With Wireless...
When I plug in the power supply to the transmitter the green light goes on only for a split second and goes out. If I wiggle it back and forth and it and out I can't get it to ever find a spot where it...
the sound source MUST be hooked up and running INCOMING SOUND to trgger the transmitter to work.the green light DOES NOT STAY on simply powering up the transmitter......
Jan 15, 2011 | RCA WSP150 Main / Stereo Speaker
I need an instruction manual to hook the speakers to my computer
There are no manuals for speakers. Speaker wires are color coded. Computer sound cards are likewise color coded.
the light green sound card mini plug port is where the green speaker wire is plugged in.
Pink is for microphone.
Black and orange sound card ports are for additional speakers.
Jun 28, 2010 | Boston Acoustics BA790 Computer Speakers
How do i hook up the speaker to my computer
if you have stereo speakers, connect it to the green audio port on your computer. if you have digital surround, you have green, yellow and black. insert the speaker connectors accordingly.
Mar 14, 2010 | Acer Aspire T310 PC Desktop
I need to hook speakers up to my Dell B110 computer.
2 things are needed to get sound from your speakers:
1-wiring connecting your speakers to a socket to the back of the computer. (The spot they need to plug in to ON YOUR COMPUTER is a small light green circular socket. The other end of the plug you plug in here should run to one of your speakers *usually the right side speaker-the right speaker should then have separate wiring to connect the left speaker.)
2- A source of power.
Some speakers use their own power source and plug in to a power outlet - your wall. Other types have a USB type plug and plug into a USB port in your computer and that is how THOSE get their power.
Those are the basics of sound setup. Some computers are equipped with more complicated setups such as surround sound, subwoofers, digital and more. Reply if you need more help, I will try to assist you further.
Hope this helps.
Feb 02, 2010 | Dell Dimension™ B110 PC Desktop
I moved my computer. Hooked it back up and now the side speakers do not work. They power on but no sound . tried several connections. USB is plugged in and the green to green connection is in. checked all...
Please can you advise if you have 2 sound cards installed
You will know this by looking at the back of the computer, the sound card wil have 3 ports coloured Purple/Dark Green and Light green
Your speaker connection needs to go into the light green and will have a symbol above it like this ))(left arrow)
If there are 2 sets of ports then try one and if that fails try the other if there is only one plug your speaker conneciton into the light green port
Jan 31, 2010 | eMachines ET1641-02w (PT.NA60X.001) PC...
They should be plugged in and turned on when you power up your system.They should be plugged into the green jack (line out). You then may have to check settings in control panel for your sound card's properties to see if digital only is checked. Try it both ways. Hope this helps.
May 22, 2009 | Boston Acoustics BA735 Computer Speakers
No sound from back surround speakers
We just hooked ours up and had the same problem, we switched around the s-air cards and that solved the sound problem immediatly.
Jan 11, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Sony XM-2200GTX...Power, Green Light, All OK, No Sound!
Sony generally drives their power light from a source that does not rely on the amplifier's switching power supply. This means that it's not a good indicator as to the health of the amplifier.
As long as you have B+ and remote voltage, it will light up. Since you've tested the speaker and the signal source, I think the amplifier is likely defective.
Oct 17, 2007 | Sony XM-2200GTX Car Audio Amplifier
Car Audio & Video Logo
85 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
