Question about Kyocera Office Equipment & Supplies
My KM FS 6950 DN mono laser printer is producing a fine gray background on both sides of each printed page. If I set the toner density from number 3 to number 5 , the gray background disappears on the front side, but remains on the back of the page. The printer has done approx 45,000 prints in 18 months and I always use genuine KM toner
  • gajj Jul 04, 2008
    If I set the toner density from number 3 to number 5, the gray background disappears from the front side, but remains on the back of the page. I have removed and cleaned the charge roller with water and dried it with lint free cloth. There is no toner spillage and the shield glass is clean. The printer has done about 45,000 prints in 18 months and I always use genuine KM toner.
    Scholar:
  • 83 Answers
I'm not familiar with this particular printer but I have something to say anyway. Some of this info you may find useful.
Your brand is a Kyocera Mita and your model I can't find on the manufacturers current product list or the legacy list on USA models. Your printer is a United Kingdom model.
You can check out support for your printer here
  1. In the control panel of your printer or on your computer for this printer there could be a section in there that tells the printer to print with this light gray background. In otherwards it might be configured to print like that. It might be as simply as unchecking a box or making some other adjustments in the control panel.
  2. Missing or light portions of the output are most often due to low toner.
  3. Indistint images(or those that appear as though the camera was of of focus) the proper charges aren't being applied to the drum or paper, the image isn't properly formed and transferred from the drum to the paper. Cleaning the corona wire might fix this problem. Also check that the HVPS is outputting the required high voltages.
  4. Using a deeply texured paper can result in improperly fused toner.
  5. You might need to replace your rollers because they are dirty
  6. If your have an older laser printer, you may encounter repeting white areas. This is the result of of a dirty corona wire. Cleaning the corona wire may solve the problem.
  7. Stray marks are usually the results of dirt, loose toner, or a damaged drum. Clean out the printer with a laser-printer vacuum because they are designed so that they don't produce static.
  8. A formatter board in the printer interprets the computer's output into commads that the printer can use to create your output. Sometimes these boards go bad.
  9. Aproblem that can be desribed as "ghost images" is the result of the previous image not being totally removed from the drum. You might see the entire image ghosted, or just some areas that show up as stary marks on the current page. Check that the cleaning blade and the erase lamp are working properly.
Posted on Jul 04, 2008
    Master:
  • 788 Answers
First this to try would be to clean inside the printer with a clean paintbrush and some compressed air. Then try again with a new toner cartridge. If that doesn't work then it's either an electrical issue or a transfer roller problem. Purchasing and instralling a maintenance kit may solve your issue, the kit for you printer is MK-440.
    Sergeant:
    Champion:
  • 221 Answers
You should warm-up your Machine with a Heater and then retry. If this fails, you should contact Service Center.
Also, you may change the Paper Roll before that.
  • 105 Answers
Try to clean the rollers and try
  • 682 Answers
First open the cover and get out developer unit and with lint free cloths clean registration roller(metal)and reinsert developer unit.
if no improvement change toner kit.
    President:
  • 2,712 Answers
You may need to clean the rollers. Try that first and post back with results..
Using an HP LJ1320 printer. When I print my page comes out with a faint gray look to it (not white). When I duplex the gray intensifies. I thought my toner cartridge was leaking toner so I replaced the...
Your Print density could be set too high.
Try to Decrease the amount of Density through the device configuration utility.
You Must have teh HP Toolbox installed to change printer settings
Feb 15, 2011 | HP LaserJet 1320 Printer
Printer leaves look of burn marks as granular shadow over page
If the paper really is being burnt then there is a fault with the fuser roller temperature control. This would also make a smell. If this gray sheen is made of toner then this may be the laser unit not putting out enough power. The optics could be dirty. One thing to try before attempting repair- Reduce the print density to minimum in the printer advanced settings. This increases the Laser power. Good luck
Sep 22, 2007 | Lexmark C524 Laser Printer
The printer is printing a yellow background on all pages. How do I get it to stop printing yellow?
It may be that you have extra yellow toner floating around in your printer so take all the toners out and hoover out your printer. Then print out about 10 - 20 blank pages to remove any left over toner. This should solve the problem, if not then its more than likely a faulty toner.
Sep 24, 2010 | Kyocera FS-C5015N Laser Printer
How do I change the toner density on the push button display when it is locked with an * We have low or a feint print out of the fine print on the print settings print out test sheets. I have cleaned all...
A new laser could help, but you should make sure the toner save is turned off, it makes toner last longer by making light prints. Toner save is set in printer properties in the control panel
Sep 10, 2009 | Brother HL-5240 Laser Printer
Kyocera FS-C5015N colour laser printer. -printing grey backgound
it seems very important to shake the toner before using your printer.
it is not too late
remove all toners and shake them well
you will find after a short time that the grey background goes away
Jul 09, 2009 | Kyocera Office Equipment & Supplies
Paper turns gray
it is written in the Manual:
If the amount of background toner shading becomes unacceptable, the procedures described below may help to clear the condition:
* Increase the density setting. This will decrease the amount of background shading.
* Change the paper to a lighter basis weight.
* Check the printer's environment' very dry (ow humidity) conditions can increase the amount of background shading.
*Replace the toner cartridge.
*Replace the transfer roller
i hope it can help.
Regards,
sabeteh
Mar 28, 2009 | HP LaserJet 4 plus Printer
Kyocera 3900 dn, is there a way to speed it up?
1.install the latest print driver; see if the rip/spool time is long or the printing time is long. The rip time depends by your computer (!) and the print driver (disable the collate option when printing multiple copies of 1 page = on the printer you should see 1/5 spit a page then 2/5 and spit another page for 5 copies of same page. If you see processing the spit the page then processing and spit the page means your computer is sending 5 times the same page instead of sending once and ask for 5 copies !!! )
2.use network connection instead the USB.
3.expand the printer memory
4.switch the printer from PCL to KPDL or Auto when printing pdf files.
Dec 28, 2008 | Kyocera FS-3900 DTN MONO LASER PRINTER
Shadowing/graying with printing
Hi fa1103:
Gray background
1. Do not use media that has already been run through the printer.
2. Try using a different type of media.
3. Print a few more pages to see if the problem corrects itself.
4. Turn over the stack of media in the tray. Also, try rotating the stack 180°.
5. Open the Configure Device menu at the printer control panel. On the Print Quality
submenu, increase the TONER DENSITY setting. See the user guide.
6. Make sure that the environmental specifications for the printer are being met.
try these steps to see if they work for you.
pdouglasss
Dec 23, 2008 | HP LaserJet 2420dn Printer
HP Laser Jet 4L Printer Model #C2003
Try lowering the toner density using the printing software or the printer menu.
Feb 03, 2008 | HP LaserJet 4L Printer
Print quality problem
Hi there sound to me like the toner cartridge is either faulty or leaking. Is it or has it been refilled if so remove cartridge vacuum out the insides of loose toner install brand new toner cartridge then test again. It cannot be the fuser unit as it will have quality problems all the time so try above and I hope it works for you.
Thanks J
Jan 14, 2008 | HP LaserJet 2420 Printer
347 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
