Question about NorStar T7316E Corded Phone
T7316E Voicemail issue
Hi
I have moved phone extensions at work, and I cannot access voicemail as I do not know the password the previous occupant had (he has now left the company).
Can you please advise how I can reset the password when I did not know it to start with?
Thank you.
Gillian
gillian.vantebberen@wartsila.com
  • Aprilhe Dec 22, 2008
    I'm having that same issue! Does anybody know? I've tried our provider, but they want to charge me at least $160 to send somebody out here to "fix it". Rediculous!
Reset the voicemail password.
Do so by first presing
Function 985 (to view the mailbox number the phone is using)
Function 983
Log: 1020000 (or 120000, 10020000 1st is for 2 digit extensions 2nd is for 4 digit extensions)
Left Button (MBOX)
Right Button (CHG)
Enter Extension
Left Button (RESET)
This should reset the passwod to 0000, the steps maybe a little bit off depending on the software version installed on the phone system, but something like that will fix the problem.
Posted on Dec 30, 2008
When logging into the voicemail for a Nortel T7316E i get the Mbox Locked warning. I have followed the steps to reset my password and have successfully done that. I then proceed to access my voicemail with...
You're resetting the wrong password. Keep in mind that mailbox numbers and extension numbers are not always the same. When you're resetting the password, make sure that the EXT assigned to it is the right one !! If you're resetting the reception mailbox, it's usually mailbox 100 (regardless of what the extension number is)
May 10, 2011 | NorStar T7316E Corded Phone
I have a Nortel T7316E phone at work. We have extensions but don't have direct dial; only a receptionist that can place calls into our voicemail. My question is, how can I check my voicemail remotely after...
Depends on the voicemail, but generally:
Call the receptionist
When the auto attendant answers, press * (or sometimes "**"), OR ask the operator to transfer to your line and press "*" during your message.
It will ask you your login information.
Dial your extension and password together as one number and press #
You can now operate the voice mail.
Mar 16, 2011 | NorStar T7316E Phone
T7316E Corded Phone (nt8b27jaab): I cannot log into system administration to change ...
Try this:
Press "Feature 985" which will display the voicemail extension #. Dial 9, and you will be prompted for a password. Press "RESETSMPSWD". Then log in with the 1020000.
Good Luck!
May 18, 2010 | NorStar T7316E Corded Phone
How do I remotely access voicemail messages for the Nortel T7316E?
To access your voice mail remotely, call into the voicemail and wiat for either the main greeting or your mailbox greeting to answer the line, press ** followed by your mailbox number password and then the # key (ex. **2251234#).
Jan 08, 2010 | NorStar T7316E Corded Phone
Voicemail and password
I would unplug power to the voicemail, then restore. Wait 10 minutes and then do the same to the phone system.
What you are trying to do is reinitialize the voiecmail, if you dont know what you are doing you will do more harm than good.
Jul 20, 2009 | Nortel T7316E 2-Line Corded Phone
T7316E Voicemail Password Issues
Feature 983
password is: 1020000 (if you use 3 difit extensions)
OR
120000 (if you have 2 digit extensions)
Jul 09, 2009 | Nortel T7316E 2-Line Corded Phone
My voicemail on my nortel platinum is locked
You need to reset the password .
Feature 983
enter 1020000 as the password if you have a 3 digit extension number or enter 120000 if you have a 2 digit extension
next press the button under the screen with the heading of m box or mail box
next your options are add delete or change
press change .
next enter mail box number
the next step will be to press the reset button
after re-setting the password press the release button . Now open your mail box and enter the default password 0000
Jun 05, 2009 | Nortel T7316E 2-Line Corded Phone
NorStar T7316E Corded Phone - voicemail / ring time
Go to programming of Norstar which will be F**266344 password will be 266344.
Dispaly shows u terminal and extensions.
press show
then next display will show u capabilities.
Press show then next display will show u FWD no answer.press show then next.and change the ringing as per ur requirement.
Feb 23, 2009 | NorStar T7316E Corded Phone
How do i inrease the number of rings
Don't know if this will work, but try the 983 feature, pw 1020000 (or 120000, or 10020000, depending on your extension numbering). Access the Mailbox menu. "Show" thru the menu until you get to "forward to" ###, then next. This should ask for delay. (to est time in seconds, multiply the number of rings by 6)
Dec 11, 2008 | NorStar T7316E Corded Phone
Log Password Lockout...
dial feature 983 it will ask you for password then you put in the pass word. Which you put in and see if it works at this stept.
If does not work Enter Feature 985" on the phone then set XXXX ( something will appear) At this point hit 9 onthe phone , and then the password is? send me a personel email and I will send you the password. I think it is not good to post passwords.
May 08, 2008 | NorStar T7316E Corded Phone
NorStar T7316E Corded Phone Logo
1,855 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
