Paper Jam in R300 Epson Stylus which I can't clear
    President:
  • 2,712 Answers
Look for any debris, bits of paper, etc in the printer. You can try using a can of compressed air to blow out any debris inside. Should that fail, try a hard reset: Unplug printer from PC and power source, wait about 5 minutes and reconnect everything and see.
The paper jam error could be due to one of the following:
  • Check for paper in the paper tray
  • Check the size of the paper in the paper tray to see if it is the same as what the printer is set for.
  • Defective D-roller
  • Debris in the paper path
  • Gears not turning or broken gear
  • Defective paper tray
  • Broken input sensor flag
  • Defective input sensor board
  • Defective system cable 2
  • Defective system board
  • Exit Sensor flag (Fuser)
  • Exit Sensor board (Fuser)
  • System cable 1
If there is no bit of paper or debris stuck in the rollers, it would indicate something more serious, and in need of servicing. If your machine is under warranty, I suggest you take it back to the shop and get it replaced.
If your warranty has run out, then you'll either have to get it serviced or buy a new printer (whichever works out cheaper for you)
Hope that helps!
Posted on Jul 04, 2008
5 Suggested Answers
ohms
  • 1879 Answers
SOURCE: epson stylus photo R300
>disconnect printer from the computer
>powercycle the printer
>check for obstructions / torn papers inside unit
>if issue still persists - hardware issue
>warranty starts from the DATE OF PURCHASE better check
Posted on Jan 03, 2008
jackboy
  • 2985 Answers
SOURCE: r300 paper jam
Shut the printer down.
Remove the software from the computer.
Come off line.
Disable the Antivirus software
Re install the printer software following the prompts exactly
Come back for more help if this did not do it
Posted on Feb 09, 2008
jackboy
  • 2985 Answers
SOURCE: Epson Paper Jam Error
Discover the rest procedure for your particular printer
Usually involved switching off- then holding down a couple of button whilst you switch on
for example Service and stop.
Try www.fixyourownprinter.com for more info
or
www. stevesdigicams.com/forums
Posted on Jun 10, 2008
aicaxz
  • 511 Answers
SOURCE: epson r300 says this
It's caused by chip that have bad connection to chip connector at carriage, or "crash program" at chip itself. Check for the connector, and try to use another chip.
Posted on Sep 20, 2009
Epson r300 says this
Sep 20, 2009 | Epson Stylus Photo R300 InkJet Printer
EPSON R 300 SAYIN PAPER JAM WHEN NO PAPER JAMMED
Make sure that the paper path is completely clear and clean the paper sensors with a q tip. They get very dusty!
Aug 29, 2009 | Epson Stylus Photo R300 InkJet Printer
Paper jam when there is no paper jam
R300 Epson stylus says paper not set correctly yet it is. Any recommendations
Jun 16, 2009 | OKI Pacemark 4410 Matrix Printer
Paper jam error
Dear Sir,
I have Epson Stylus-1390 Photo Printer. Problem is when giving photo printing option thru printer driver printer get error is paper jam..
can you give me solution for the same.
thanks
Jan 09, 2009 | Epson Stylus Photo R300 InkJet Printer
Paper jam error
take out jammed paper and replace the paper
Jan 05, 2009 | Epson Stylus Photo R300 InkJet Printer
Epson R300 Constant Paper Jam
Take it apart,as fas as you can.clean out all of the paper and chips. The print 5 pages only, twice as the Epson manual says to do , in order to clean itself out.
Dec 23, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson R300
Make sure the photo paper is not curling when it goes in. I had same problem before, with paper jam error even though the photo paper did not appear jammed. I noticed the photo paper was slightly curled, so I flattened it out and that solved my problem. Also, if you are loading multiple sheets at one time, try just loading one sheet and see if that fixes it.
May 11, 2008 | Epson Stylus Photo R300 InkJet Printer
R300 paper jam
Come off line.
Feb 09, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson stylus photo R300
Dec 31, 2007 | Epson Stylus Photo R300 InkJet Printer
542 people viewed this question
jasbo
jasbo
