I have wattpad on my phone and my whole library has got deleted after my phone died whilst using the application and it has also got very slow, what can I do?
The application is either too big to be easily supported with your phone and its probably taking too much space on your phone,look for a simpler version of the application that you installed in your phone....
I would suggest for you to delete that apllication and free your phone memory....
Try a hard shutdown by holding down the top on/off button while on the main menu screen. DO NOT do it from the Wattpad page, that might delete all your stories.
Hello Sir\Ma,
Firstly, your phone may be affected with virus, probably some files or application you have on the phone memory is being affected with virus. and to remove the virus, it is either you connect your phone to a PC that has a strong or updated antivirus using a USB, then scan it for virus, but if no virus is detected, then the slowness is a result of overload.
If you have too much files like heavy music, videos, themes, applications, and picture of a higher bytes on the phone memory or memory card may as well slow down your phone especially if the memory card capacity or size is to higher for the phone to carry. So, you will need to either reduce those files or probably delete then. you can also delete some old message that are not needed so as to free space on the phone memory.
Regards
You don't have a virus. Just make sure that you get the over the air updates whenever available. The latter versions of the phone are much more efficient than the earlier ones. Try closing applications when not in use to speed operation. Press the blackberry button choose switch applications and then close the ones you are not using. You can also delete the default third party software that comes on your phone if you don't need it. For instance, if you never use Verizon navigator, take out a few messengers i.e. aim, yahoo, remove flicker (you can always get this applications back later so no worries).
