Question about VIA Computers & Internet
Video memory i have a via tech computer model:VT8601.it has a intergrated graphic card.can i increase its video memory by contributing some of ram or hard disk space.i am not able to buy a video card because some on told me that it will affect my computer's performance.if any sof ware is present on net which is downloadable please tell me. my email:sunny_grewalz@yahoo.co.in
    Novelist:
  • 150 Answers
1) On board video devices often use main system RAM,
by remapping it into their own address space.
This is designed to be CHEAP not GOOD.
Any RAM used by the video controller is NOT available to
to Windows, thus reducing system performance.
2) Sacrificing system RAM for video is a bad idea, the
system needs it more. Extra RAM in video controllers
is used mostly for 3-D effects and gaming, because
most video systems already have plenty of RAM for
implementing colors screen resolution.
On board video controllers are never fast or exotic enough
to benefit from the extra RAM anyway.
The rest of the system (i.e. Windows) on the other hand
can put any extra RAM to a far better use, by reducing
the need to store transient data on disk.
Don't forget that a hard disk is 10,000,000 times slower than
physical RAM, and when Windows starts running out of
physical RAM, it starts swapping data to disk (thrashing).
The performance penalty is not subtle !!!! Operations that
took a few seconds can take hours and even days.
3) It may be possible to change the balance between
system RAM and VIDEO RAM in the BIOS.
This depends on the motherboard.
4) If you want to drastically improve performance, do
buy a separate video card, for example an ATI Radeon
Saphire and disable the onboard video.
You must make sure the video card will fit in your
motherboard. Depending on the boards age, it
can use one of several types of I/O slots:
Vesa
PCI
AGP 2x
AGP 4x/ 8x
PCI Express
etc...
The card must match the slot.
5) The suggestion that adding a separate video card would
somehow slow down your computer is absolute non-sense.
Tell the guy to read some books, take a few classes, and
keep his opinions to himself until he knows something.
Internal video cards (on-board) have limited capabilities,
and steal system resources. Add-on cards are designed
for performance, by adding resources and off-loading
graphics related computation from the main CPU,
allowing it to do 0ther things.
6) Finally, using the hard-drive to supplement video RAM
is impossible. The hard disk is way too slow. It would be
like hitching a snail in front of your Porche. Perhaps
even a little worse.
Video RAM needs to be extremely fast, even faster than
system RAM. It is often organized using ultra-wide buses
with interleaved addressing for maximum speed. Also,
for this reason, good video RAM is not cheap. A good
Video CARD will have between 256 to 512 MB of fast RAM.
If you run Windows XP, your system should have at between
1024 to 2048 MBytes of system physical RAM.
Less RAM will make your system drastically slower when
doing things like video and image processing.
For VISTA, two gigs is the absolute minimum.
Disk are used for storing lots of data at a slow speed,
and retaining it with the power OFF.
Hard disks can store about 1,000 times as much as
physical RAM, but the access time is up to 10 million
times slower:
RAM can be accessed in 1 nanosecond.
DISK takes 10 milliseconds.
Hope this answers your question
Please rate my answers.
Martin
Posted on Jul 04, 2008
Need abetter graphic card for acer aspire 5251
in Acer Aspire Series is using Intergrated Graphic Card.
that mean if you wanna Upgrade your Graphic Resolution,
you have to set to a bigger shared memory/RAM for Display Graphic Card/VGA memory from BIOS Setup.
for example if you using RAM 2Gb, and you can make your VGA(Video Graphic Adapter) to 1Gb.
But in My Computer Properties the RAM will Show only 1Gb.
Because another 1Gb of RAM you've use for VGA.
you can check it from dxdiag.
(for opening dxdiag > Click Start > click RUN... > type dxdiag > and Oke/Enter)
Jan 07, 2012 | Acer Computers & Internet
I have acer 5745 model which is with intel HD graphics.When I go to graphics properties it shows minimum graphics memory of about 128 MB and maximum graphics memory 1051 MB. So,my question is does acer...
You may be able to increase the video RAM in the BIOS configuration.
The laptop's built-in video card most likely uses shared RAM, it uses part of the main RAM models and the more you grab for the video RAM the less main memory is available, You may need to install more RAM to make the laptop run better.
Feb 02, 2011 | Computers & Internet
Hello sir I've intel desktop computer. when I play high graphic video, the screen goes blank & dark
HI, Regarding this issue please do update the graphics card driver for your computer.
Nov 19, 2010 | Computers & Internet
How do I find my graphics card on acer laptop 4720z and change settings to best play games
* The system configuration of Acer Aspire 4720Z PC Notebook is :
160 GB or larger hard disk drive / 5-in-1 card reader / 512 MB or 1GB DDR2 533 MHz DIMM module / Intel Pentium dual-core mobile processor technology T2310 (1 MB L2 cache, 1.46, 533 MHz FSB), Mobile Intel GL960 Express Graphics Chipset.
* Your system have "Mobile Intel GL960 Express Graphics Chipset" graphics accelerator card embedded in the motherboard. Like most of the laptops/notebooks, there is no room for upgrading the graphics card in the motherboard!
* But you can upgrade the RAM upto 2 GB using two DDR2 DIMM memory modules.
* If you want to play 3D games with better performance, switch to Windows XP SP2 and upgrade the RAM!
* If you want to upgrade the memory (RAM), you can check this site : http://www.laptoppartsexpert.com/c-60093-acer-aspire-4720-series-as4720z.html
please rate this advice if it helps...tc! :)
Jan 13, 2010 | Acer Aspire 4720 Notebook
How we can share RAM memory with graphics memory of our PC?
go into the system BIOS by pressing the DEL or F2 or F10 key and the you will see the BIOS menu, ther you will see intergreated peripherals and there you will see video ram something like that and there it will show you 8Mb change it to 32 or whatever you want press F10 and reboot and your memory is changed.
Mar 23, 2009 | Computers & Internet
My1 gb ram didn't make any change even in games in my pc even those games which used to run at a particular speed earlier before the added ram are running just like thet speed even after adding 1gb more...
Ok, let's explain this. RAM does not necessarily make your pc faster.
Your pc can be faster if you upgrade your CPU or graphic card(only graphic application will make you notice the increased speed in graphics).
RAM can be a bottleneck for application that need a lot of memory like photoshop when working on multiple very high resolution images or 3D cad when working on large assemblies, or VMWare.
Vista manages the RAM in such a way that you might notice a slight performance increase and less disk usage during standard desktop activities, but XP doesn't.
if you don't use very many applcations at a time and/or you don't use memory consuming applications, the added RAM is not used at all and your computer won't be any faster than it used to be.
Video memory is basically the same. you will notice a difference in performance from a large video memory(512MB-1GB-2GB) only if you game at high resolution like 1080p or higher, usually supported only by large monitors like 20" or larger.
Feb 19, 2009 | ASUS EN7200GS/HTD/256M-256MB PCI-E DDR...
Increase graphics card memory
go to your bios setting > chipset feature > onchip AGP.
you can increase your Graphic card from ther if it is on bourd.
Jan 28, 2009 | Asrock P4I45GV R5 Motherboard
I hav a nvidia 8400gs graphics card how can i increase its size 1. by sharing it with hard disk 2.by sharing it with ram 3.what are the effects of this procedure?
upgrading your video card. There are probably only two basic reasons to upgrade a video card: 1. Your current card has poor performance.or You just "want" faster video performance.
If you think your current video card is performing poorly, there are a couple of things you should do prior to upgrading your video card. The first thing your should do is give your computer a "tune-up". This involves things like running Defrag, Scandisk, virus checkers etc. (for further explanation of tune-up procedures, .
Once you are certain that your computer is performing properly, and your computer is still experiencing slowdowns in video intensive programs, like games or graphic design programs, then the second thing you may need to do is upgrade your computer's main system memory. Inadequate amounts of system RAM will choke your computer's performance. That's why I recommend all newer computers have at least 512 MB of system RAM.
I want to share memory with my graphic card
the system cannot share memory with your graphic card, the hard disk can share its free space with the RAM to increase performance when you have little RAM installed.
I recommend buying a graphic card with 512mb memory for your system.
Jan 09, 2009 | Computers & Internet
Computers & Internet Logo
182 people viewed this question
Top VIA Computers & Internet Experts
David
David
Abhinandan  Patil
Abhinandan Patil
jason
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
