Question about Canon PIXMA iP3000 InkJet Photo Printer
The printing is not good, has messy and dull effect.
When i printed around 100 pages the print was still good but as it moves on the print is dull and light and it smears out.
    Guru:
  • 859 Answers
That's about right for the amount of printing you've done before this problem started to show up.
The solution is to run programs accessed from your printer control menus.
Run first, print head cleaning... perhaps twice.
Then, run print head alignment. In this routine you get several lines printed off and you choose the number correspoinding to the set of lines that line up together the closest. Then, enter that ID number for those aligned lines. Sometimes, its good to do this twice.
You will normally want to do these two routines each and every time you replace print heads.
If you need further guidance, use the comment box below to ask.
Regards,
Worldvet
Posted on Jul 04, 2008
What causes the printing to be cut off around the page edges on my Kyocera FS 4020DN?
when we want to print from email then
there is a print button within email if self probably right side of email which one is opened
a small print symbol is there try with these button
it opens a new widows from which good print can done
Aug 19, 2014 | Kyocera 1102J22US0 Model FS-4020DN Laser...
Why does my HP Photosmart C6150 All-in-One only prints/scans full black page
Open the scanner cover and check on you to copy double-check scanner moves when the light comes from the scanner and see if it sees the glass as if it would be messy to be opened and cleaned
Jul 22, 2014 | HP Photosmart C6150 Wireless All-in-one...
No magenta printing
Dirty mirrors will gives you dull color images..It seems color combination faulty..
chk original cartridges installed? or refilled cartridges?
Take supply status page..
chk colors..If color is dull(light) clean laser scanner assembly mirrors.
Do the color calibration..
chk drivers.,
Print from other file..
May 09, 2014 | HP COLOR LASERJET CP 3505 N PRINTER
Inconsistent printing
In the printer's dialogue find the print pages number. Print page from/to and select 20 pages chunks. In effect print only part of the document at a time. Add all chunks together in one pile. Work around I know, but it works.
Aug 02, 2017 | Brother HL-2130 monochrome laser printer...
My cannon mp468 prints photos real dill
On the printers properties select colour intensity and switch to manual. then select 'set'. And move the light/dark control over to light, around 15 to 21 seems best.
Jan 03, 2010 | Canon PIXMA MP460 All-In-One InkJet...
MP830 PGBK does not print, tried new cartridges and usual cleaning etc, nothing. Bought new print head but still does not print. Other colours Bk,Y,M,C all ok. Have tried 'Auto Alignment' but this fails...
the printhead probably needs to be taken out of printer and cleaned.
just pop the ink cartridges out, then remove the print-head, fill a sink full of warm water, and swirl the print head around in the warm water. Blow through the color slits on the print head into the sink full of water it will get messy. empty the sink full of colored warm water.
rinse and repeat till your are satisfied its clean. dry it off with a cloth towel you don't care for, because it will get messy and covered in ink.
put your printer back together and it should work...it may take a few times...but i got my printer 'PGBK ink cartridge' working again doing this. or you can spend 100 bucks and buy a new print-head...my printer is a mp830 it came apart easily no tools or force needed... good luck and don't break your printer...its easy.
Nov 01, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Printer has stopped printing full sheets, but when run test page it prints perfectly
Try this...Open your printer properties the same way you did when you printed a test page in Windows.
Look at the Effects tab. Look for the default print size and make sure it is set to 100%. Also check to make sure the paper size is set to 8-1/2x11 and not a smaller size paper.
Oct 27, 2009 | HP Photosmart C6180 All-In-One InkJet...
Prints labels too small
when you hit print, the window comes up and lists the printers available. If your printer is highlighted, click on preferences and click on the "effects" tab and there is a box with a percentage of size. Increase the percentage, if it is too small at 100%, try to bump it up to 125% etc.
Sep 17, 2009 | HP Office Equipment & Supplies
My printer wont print even after changing ink and cleaning
When cleaning doesn't help, you need a new printhead. Around $89.00 now and then you add labor. They sell a new MFC 490 for around $120.00 with a year warranty.
Jul 01, 2009 | Brother MFC-3240C All-In-One InkJet...
F380
You are using HP's cartridge with the smallest output . So if you are printing 80 pages of text, you will have a problem by the time you reach 95 or 100 pages. If you are printing in color, you only have 1ml/color. Meaning 3 colors. But in order to print a red, it will combine a magenta and yellow to product 1 color. So 3 colors doesn't mean 3 ml worth of colors. Effectively you may only be able to print 10-20 pages of color then your cartridge is empty. The black cartridge has about 4-5ml of ink. So if you print a lot I suggest you get another printer.
Mar 30, 2008 | HP DeskJet F380 All-In-One Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
112 people viewed this question
old marine
old marine
