Question about Dell Latitude D600 Notebook
Battery not charging. Power Adapter ok
I just bought a new Battery and I also observed that it is not been charged.
  • MAGBADELO Jul 04, 2008
    Dell D600 not charging battery. AC adapter is ok.
    Scholar:
  • 94 Answers
DC jack issue usually.
Or a bad repair- many techs not skilled enough will wind up losing RV1,RV2 or RV3 MOV. this is so small that I had documented it on my site. The chip has no values printed on them, and are hard to find "Close-Up"
But fear not, most of the times it is simply a DC jack replacement. They are about $8 on ebay. And only a skilled tech should replace it.
How they fail?
It is a circular tri-axial ring inside, the leaf type contacts become fatigued and no longer pick up power. Or the center contacts become fatigued.
OR the jack left the factory with insufficient solder and repeated use caused it to crack.
Don't forget to rate responses
Posted on Jul 04, 2008
New battery HP g61 is fully charged but not working \
Maybe the AC Adapter Power Cord is not working. If you can't get on the laptop with the power cord then it is bad and the battery might be drained so you have no power source to power up the laptop.
If the laptop works only off the Power Cord and the batteryis not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let thelatop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in andremove the power cord. If it won't boot or shuts down then the battery is deadand needs to be replaced if the power cord is ok.
Apr 30, 2012 | HEWLETT-PACKARD HP G61A50US 156 AMD Athlon...
HI I HAVE A PROBLEM WITH MY C500 FIRT OF ALL THE DC JACK ON THE CORD MUST HAVE WORN BECAUSE IT STOPPED WORKING I TESTED THE CABLE IT HAD A BREAK IN IT SO I BOUGHT ANOTHER ADAPTOR POWER SUPPLY AND I GOT...
you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Aug 25, 2010 | Computers & Internet
Laptop will only work when plugged into the mains, battery will not charge
your battery may be died or discharged comptletely and your power adapter are not charging.
get test the power adapter first, if it is ok, you should buy a new battery then
otherwise you should buy a new power adapter.
Aug 18, 2010 | Dell Inspiron 1525 Notebook
My dell latitude c400 does not take a charge do i have to buy a new battery ?
Yes, most likely you may need to replace the battery. Try to get a different cell capacity this time (I do not know if you currently have a 6 cell or 9 cell battery). Once it's not keeping a charge it most likely has a problem.
Hope this helps...
Apr 18, 2010 | Dell Latitude C400 Notebook
When I plug the AC plug into my computer, the battery light doesn't appear that it's charging. I purchased a new battery and still doesnt charge. any ideas?
try to darin the batter first. heres the procedure. take out the battery and unplugged the power adapter. press and hold the power button for 30secs. after 30 sces, put the battery and adapter back in. then power on the computer and observe.
Apr 01, 2010 | Toshiba Satellite A135-S4527 Notebook
I just bought a replacement 9 cell battery and a 90 watt power adapter for my Dell E1505. With the new battery and power adapter my battery indicator light keeps flashing green and the battery doesn't...
If a new DELL ac adapter (3rd party Adapters are not recognized and the charging circuit is disabled) and a new battery doesn't resolve then the charging circuit on the motherboard is bad
Dec 29, 2009 | Dell Inspiron E1505 Notebook
ADAPTER WILL NOT CHARGE MY LAPTOP
Yes, more than likely you will need a new power supply. You can locate them at any computer store.
I hope this solution is helpful. Please remember to rate this solution.
Feb 11, 2009 | Dell Inspiron E1705 Notebook
Getting hot underneth
Both batteries could be dead. But if you bought a new battery, it's unlikely. I don't know what green light you see, but if it's on the power adapter, it just means it's turned on--not that it is charging.
Two possibilities: Your power adapter is bad or the motherboard is bad. Because you say the computer works if plugged in, then you have ruled out the adapter.
You should be checking/cleaning the battery contacts and if all else fails, going for a new motherboard.
Jan 16, 2009 | IBM ThinkPad T22 2647 Notebook
My laptop battery won't charge
possible when the old AC adapter blew it took part of the power management circuit with it, This is the circuit that detects and charges the battery, I'm not sure whether this a seperate replaceable daughter card or whether it is part of the main motherboard. you will need to investigate this (or send it for a service)
Oct 09, 2007 | Dell Inspiron B130 Notebook
Recharging doesnt work
OK Try to replace a new one battery then observe if can charge!? if not charging u have defective charging pin! or charging IC.
Sep 14, 2007 | Panasonic X700 Cellular Phone
Dell Latitude D600 Notebook Logo
223 people viewed this question
Alun Cox
