In case of hard disk damage/ complete failure you may loose your data. Hence, it is highly recommended that you should immediately make backup of all your important/ critical data on CD/DVD or on external drive and contact HP Authorized Service Professional in your area for checkup of your laptop and repair/ replacement of hard disk.
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
the leads from your
((motherboard
to your hard drive)) make sure
they have a secure connection and are not faulty or just replace them they
could be faulty a faulty lead can give the same error message
hope this helps
this type of error message can be a caused by a few things it could mean that your hard disk is about to fail/crash you should check
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error also
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input will damage your computer
hope this helps
don
