Question about Creda W120VW Front Load Washer
Creda Excel 1200 W120VW Front loading washing machine
Drum not rotating during wash or spin cycle - any suggestions please?
    President:
  • 1,462 Answers
Check motor brushes for a start
Posted on Jul 04, 2008
  • Paul Nov 25, 2012
    Obviously you have not read the description of the fault correctly - I stated that the brushes were in good condition - they are not short and both are in contact with the commuator surface, if one brush was short and not in contact with the commutator surface the motor would not rotate, different if the motor was a 4 pole machine then it would have 4 set of brushes 2 would be positive and two would be negative, the motor would still run on either 2 + & 1 - but this would induce rapid brush wear an the single carbon, oh by the way I resurface commuator via commuator grinding for a living and have vast experience 28 years with Dc machines.
How do i put door on again on creda excel 1200 as it has come off hinges
sounds like maybe you just sit the door on those pins and close it
Jun 04, 2014 | Creda W120VW Front Load Washer
Creda excel W120VW the door lock light keeps flashing and cycle stops. If I hold the start button for a few seconds it starts again but then stops after about 2 mins.
From what you descibe it COULD be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
May 15, 2011 | Creda W120VW Front Load Washer
I have just 'acquired' A creda excel 1200 washing machine. Model no W220VW serial no 40125977. Unfortunately is have not come with an instruction manual. Is it possible to obtain one please? thank...
In your browser bar type in:
HOTPOINT USER MANUAL and follow the links.
You will find what you are looking for.Although it says Hotpoint, just type your model in the box, and it will come on screen, then you can save it, or download it to your printer
Plz rate my solution.
Jun 21, 2010 | Creda W120VW Front Load Washer
Manual for Creda Excel 1200 W120VW
Thanks
Dec 15, 2008 | Creda W120VW Front Load Washer
Creda excel 2000 skips spin and rinse cycle
The filter is located in the sump hose at the rear of the washer.
Remove back panel and undo the clip that holds the large black hose onto the rear of the drum .
Inside it ,you will find the filter.
Remove and clean.
Plz leave feedback for this solution.
Thanks.
Dec 14, 2008 | Creda W120VW Front Load Washer
Re: Creda W120VW
is the machine on its own circut
Mar 29, 2008 | Creda W120VW Front Load Washer
Creda excel 1200 front loading washing machine
This will either be a blocked pressure vessel, or the brushes on the Motor. I am not sure where the pressure vessl is on this model But you will find it buy taking the top of and finding a round or oval shaped component with a plastic tube running from it. carefully pull this tube of and blow down it. it should be clear. unplug machine first.
Nov 18, 2007 | Creda W120VW Front Load Washer
Creda W120VW Front Load Washer Logo
518 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
