Question about Acer AL1912 19" LCD Monitor
Acer Al1912 monitor
Hi my monitor has lost all the red/pinky colours they are showing as black.
We have tried to restore the computer & reset the colour on the monitor but the reddy colours are no where to be found. Can you help me
  • mikjac Jul 08, 2008
    Hi, found the solution. We tried another monitor & the red was still gone. However, we unplugged the monitor & found one pin was snapped on the connection cable. Re-connected with a new lead & all sorted. The monitor has all the colours back. Thank you for your help.
    President:
  • 173 Answers
You can try adjusting your color and tint on your monitor and also adjust the resolution with your computer. To make sure it is not a problem with your video card, take and use a known good monitor (borrow one from a friend, family member, co-worker, etc) and connect it to your computer system. If the system boots up fine and there is no problems, then your monitor is going bad and you will need to replace it, because it is not worth fixing financially. If you plug it to a known good monitor and it is still doing the same thing, then your video card is bad and you will need to replace that. You can see the symptoms and this same procedure in my profile under tips. I hope this helps and please let me know if you need further assistance.
If you would not mind please rate my help, I would really appreciate it. Thanks.
Posted on Jul 08, 2008
Acer X193HQL LCD Monitor Colour Problem
Hello Sales, hi, try to reconnect the VGA cable from the PC, and wiggle it a little and see if the green tinge thing disappears on screen, if it does there are loose contacts, you can also try to replace you VGA cable, see if it solve the color problem.
Apr 27, 2010 | Acer AL1912 19" LCD Monitor
Hi there,my acer al1912 monitor lights up briefly after i turn it ln and then turn black what could this be? Pieter
It could be the problem in the power supply because of bad caps, or bad inverter circuits, or worst will be bad lamps. Look for bad caps first and report back what you see so we can guide you further, see example of failed monitors due to bad caps and lamps: http://s807.photobucket.com/home/budm/allalbums
Feb 02, 2010 | Acer AL1912 19" LCD Monitor
How can I connect my Fujitsu Siemens key board with my Acer AL1912 monitor? There is a connect button on the key board, but where is the connect button on the Acer?
Is it a wireless keyboard? If that is the case, then you should have a receiver unit attached to the PC, usually to a USB port. The ACER is justt a monitor, here is the user manual: http://www.retrevo.com/support/Acer-AL1912-Monitors-manual/id/719ag115/t/2/
Jan 20, 2010 | Acer AL1912 19" LCD Monitor
I have a acer al1912 faulty
It might be worth a try but the two different sizes could have differing resolutions and if they do, the boards are not likely interchangeable.
Jan 29, 2009 | Acer AL1912 19" LCD Monitor
Acer AL1912 Monitor - Screen to black and light on yellow
I found some solutions other posted that didn't come up the first time I looked. I did a reboot and I'm good to go!
Dec 07, 2008 | Acer Computers & Internet
Acer al1912
You havn't so much lost a colour as you have a damaged video cable from the PC to the monitor.
The wires inside the cable can break very easily, and will make contact (and look normal) if the cable is moved into the right position.
Grab the cable about 4" from the back of the PC and push it towards the PC (while it's all plugged in and running).
Then move the cable in a circle while it's sort of crunched up like that.
The signal should go good (maybe only for a second) and if you can find something to keep the cable in that position until you get a new one it will be fine.
If you have a spare cable, then just swap it over.
Jul 12, 2008 | Acer AL1912 19" LCD Monitor
Acer al1912 19" black
See if the problem happends in safe mode ( while booting hit F8 and aboot menu wil come up) if everything works fine then your issue will be the driver or a resulition that the display does not support or a refresh rate. Frist try to change the Res to a lower one and common (1024X768 or 800X600) also change the refresh to somewhere 70 to 75 and reboot if this dosent fix the problem try updating your video driver in safe mode
Jan 09, 2008 | Acer AL1912 19" LCD Monitor
Acer al1912 with S3inc trio 32/64 card
start with a 1024x788 60hz refresh , connect lcd
and then try any higher freq/refresh as it will ask you to verify.
Nov 02, 2007 | Acer AL1912 19" LCD Monitor
Acer AL1912 19" LCD Monitor Logo
75 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
