Monitor is working out of scan range
When using Microsoft Word, the computer freezes and the warning box states that the monitor is working out of range. How do I correct this problem. Am using a denskstop which the monitor is working out scan range. Please i need a help how to fix this promblem
    Scholar:
  • 144 Answers
Try reinstallign Word, it seems your normal.dot has incorrect settings. What happens if you open a word file without opening word first? Does word work normally? Than clear the document and save it as normal.dot in your my documents folder.
Posted on Jul 05, 2008
How to turn my 1080 hp monitor on connected to my computer
Look for the power button/switch on the monitor
Oct 13, 2017 | HP Computers & Internet
The screen is black and a blue box in the middle that states "analog out of range. 67.0kHz/60Hz
Try to see if this works on another computer first, if it does, then it assumes the monitor is ok.
Then as the computer boots up, boot to safe mode by pressing F8 and once in that state, set the display to a mode that the graphics card will support.
If none of the full colour options work, the graphics card may be incompatible, try changing the graphics card.
Jun 13, 2011 | LG FLATRON W2252TQ-PF 22" LCD Monitor
My samsung 940N acts like a florescent tube, tries to start and doesn't
Use the self test feature.. follow the steps..
1. Turn off both your computer and the monitor.
2. Unplug the video cable from the back of the computer.
3. Turn on the monitor.
If the monitor is functioning properly, you will see a box in the illustration below.
This box appears during normal operation if the video cable becomes disconnected or
damaged.
4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the
monitor.
If your monitor screen remains blank after using the previous procedure, check your video
controller and computer system; your monitor is functioning properly.
Warning
The Power supply inside the monitor can be hazardous and donot open the monitor while power on.
Donot work with the monitor when it is open and the power supply is on.
If there is something wrong with the input signal, a message appears on the screen or the
screen goes blank although the power indicator LED is still on. The message may indicate
that the monitor is out of scan range or that you need to check the signal cable.
Feb 13, 2010 | Samsung SyncMaster 940N 19 inch LCD...
DELL E153FPf doesn't show the image
OSD Warning Messages A warning message may appear on the screen indicating that the monitor is out of sync range.
Cannot Display This Video Mode
This means that the monitor cannot synchronize with the signal that it is receiving from the computer. Either the signal is too high or too low for the monitor to use. See Specifications for the Horizontal and Vertical frequency ranges addressable by this monitor. Recommended mode is 1024x768 @ 60Hz.
Occasionally, no warning message appears, but the screen is blank. This could also indicate that the monitor is not synchronizing with the computer or the monitor is in a power save mode.
Jan 18, 2010 | Dell E153FPf 15" TFT LCD Flat Panel...
My monitor doesnt turns on but noting happens
I have try it with another monitor, Only want i can see on is the small box that has out scan range with a very dimm light.
Jul 04, 2008 | Computers & Internet
INPUT SIGNAL OUT OF RANGE
some how your screen resolution has changed above or below what your monitor can display. you need to boot your computer using another monitor that can work with the resolution your computer has switched to(i used a spare crt monitor when it happened to me) change your resolution in display properties to a normal level like 1027x768, and while the computer is on swap the monitor cables to verify the lcd is working.
It is perfectly safe to unplug the video cable and plug it back in while the computer is turnned on.
Dec 26, 2007 | Relisys TL775 17" LCD Monitor
Monitor out of range
Most commonly, this problem is caused by an incorrect refresh rate setting. LCD monitors typically DO NOT support refresh rates higher than 60hz - and this is no exception. Try running the game in "safe mode" if it has one. Adjusting the in-game video settings should solve the problem, just look for a screen refresh rate or any video-related setting with a number followed by "hz". Set it to 60, everything should be fine.
It could also be that at some point the game changes resolution (this frequently occurs if there is an in-game movie or cut-scene). In this case the resolution settings for the in-game movie might be at fault, check them if you can.
Sep 23, 2007 | Computers & Internet
Range Warning
first, 68.5 khz -85hz means horizontal raster frequency of source signal is at 68.5 kilohertz and repeats vertically at 85 hertz. (hertz means "cycles per second). the sony monitor cannot "read" the signal being sent from the pc. change the screen resolution to a lower number like 75 or 70 hertz vertical.
Jun 05, 2007 | Sony SDM-HS95 19" TFT screen silver LCD...
It probabily happens after you change the settings of display in control panel (windows), if so restart the machine and press function key <F8> after memory test and you shoud get to the startup menu, choose VGA mode and undo the changes in display that you have made.
Best Regards
Creon
Mar 30, 2006 | Dell P780 17" CRT Monitor
Computers & Internet Logo
658 people viewed this question
David Payne
David Payne
