Question about Pioneer DEH-P6700MP CD Player
Pioneer deh 6700
Hello .. what's happening is that my facemask lights up and shows full display of everything.. the volume has full funvtion but none of the other buttons work.. what should i do?
  • 2 more comments
  • cortex1981 Dec 09, 2008
    idem : volume ok; buttons hs
    i'll try button mode + 1st channel tomorrow
  • Anonymous Mar 25, 2009
    I have the same probleme.
    But what or whrer is the "mode" button and "the first channel" ?
    Thank you for your answer
  • rick4222 Mar 25, 2009
    I've got the same problem.
    volume ok; buttons hs.
    But what or where is the "mode" ant "first channel" button?
    Thank you for your answers.
    Sorry for my English, I'm French..
  • vilkpaulius Apr 06, 2009
    i have same problem , someone tell how to unlock facemask
Hello, my front panel doesn't work. Only volume is working but nothing else. Any fix? Do I need to buy a new front panel? Thanks.
Posted on Jun 20, 2011
The solutions is to hold down mode button and 1st channel button at the same time and this unlocks the faceplate. seems like my head unit got locked by a combination buttons being pressed while in the arm rest. worked straight away for me.
Posted on Jun 26, 2009
I fixed it by pressing the mode button and first channel button at the same time. It seemed to "unjam" the system]
\Hope it works for you too.
Posted on Nov 06, 2008
I had a repai at the local bestbuy store and i havent received a call from anyone regarding this my service order number is 01097-943998726 and my phone number is 2056013072
Posted on Jul 04, 2008
AVAYA Merlin Magix phone system powers on, all phones have blank display but have message light blinking, no dial-tone, key press = no sound, adjust volume rings phone and displays on screen.
if you have it plugged into an outside line and do not have a dial tone call your phone company .but when buying stuff at an auction , well you get what you got even if it's old and none working
Feb 21, 2016 | Lands Phones
I have a Mackie ProFX22 and when I solo the "rude solo" LED turns on. I have checked every signal and none are soloed. Also only the left meter shows anything. What is causing the "rude solo"?
The "rude solo" wil only flash if something is soloed. You need to check again as there is STILL something soloed. The left meter is because that is showing the channel that is being soloed. Once you unsolo everything, the meters wil display full left and right as usual.
Apr 02, 2014 | Mackie Music
MT1500 shows full battery but beep's like it's dead
Hello
This double beep tone you are hearing is a acknowledgment tone indicating that the radio is in the transmitting mode. On the Motorola MT1500 radio you can adjust the tone volume separate from the reception volume by simply holding down the volume control and setting the tone volume level.
I hope this helps.
Bruce
Jan 04, 2014 | Motorola Radio Communications
NAD M3 power light turns red immediately and PROTECT message displays. Amp keeps functioning but volume control doesn't work up or down.
Hello
Check the connection to speaker with this amp, for any short or any other fault. disconnect the outputs, ie, speakers from the amp, and switch it On, and see the protect display comes or not. If it comes, the fault is internal and the set need service.
Your M3 dual Mono integrated amp, is of high output power and its outputs are protected against any overload or short circuit. If the system detect any among this condition specified above, it will show protect mode display.
Never load this amp, as protection display is there, as it may damage the speaker or its internal power amplifier section circuits, may cause more money to get it repaired. OK.
Jan 23, 2012 | NAD M3 Master Series Integrated...
I have an akai 52, it just happen, the screen looks to big for tv and its like its stuck in a panorama mode also....how can it adjust this? i have tried everything with the menu button and nothing seems to...
Check for a button that says 'pic size' or 'zoom' or 'aspect' or something similar on your remote. Most newer TV's have this funvtion but it's almost always controlled by the remote, not the TV menus.
Sep 17, 2011 | Akai Televison & Video
Amp not working properly.............
Mke sure that the tape monitor switch is turned off.
Dan
Apr 09, 2008 | Audio Players & Recorders
Cd pioneer dehp350
check for a stuck button on the face. Thats what happened to mine. Nothing on the face worked... remote wouldn't work...started pushing buttons untill one "popped" and then everything was fine.
Dec 31, 2007 | Pioneer DEH-P3500 CD Player
Denon AVR 1905
It happens sometime with low voltages. Try putting in a voltage stablizer in the path and test it. If it works, get a high quality component to give you correct voltage.
Nov 20, 2007 | Audio Players & Recorders
Controls
Someone push the volume up button too hard and is stuck,this also has the micro(brain) confused,all this happen before you fund out your remote would not work.
Sep 03, 2006 | Sony FD Trinitron WEGA KV-32FV300 32" TV
Pioneer DEH-P6700MP CD Player Logo
1,914 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
