Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Me again I got the capacitors like you recommended and I took it a part per directions and I see this i a bit over my head. i do not know how to sauder. I am not sure even where to but these things on the board. Do you recommend a good service repairman? And what would be a far cost? My email address is michele9886@msn.com You have been very helpful and want to thank you for all your help thus far.
  • Mitsubishi Master
  • 8,617 Answers
Whats your zipcode and i may be able to locate a good repair shop
Posted on Jul 04, 2008
  • Sonny Berry
    Sonny Berry Jul 04, 2008
    Sand Tech Computer Repair
    User Friendly Nationwide provides the best possible services for the... Read More
    Service Area: United States
    Service Cost: Free Estimate
    Rating:
    Call:
    (203)233-1209
    www.sand-tech.co
    m
    Photo Tronics Incorporated
    Camcorders, Digital Camera & Lcd Prog Service, Digital Cameras, Dvds,... Read More
    Service Area: Seattle
    Service Cost: Call for Estimate
    Rating:
    Call:
    206 6822646
    Adams TV
    Dvds, New Tvs, Remotes, Repair, Some Used, Tubes
    Rating:
    Call:
    206 6324211
    All Area Service
    Rating:
    Call:
    206 2440416
    Allied TV & Vcr Service
    Rating:
    Call:
    206 6320930
    Amirs Stereo TV & Vcr Repair
    Rating:
    Call:
    206 7834040
    Anna TV & Gifts
    Rating:
    Call:
    206 7252727
First of all my mate bought a vauxhall corsa duel fuel he drove it from heathrow to where i live about 150 miles he said that it wasnt pulling good did compression test and number 2 and 3 had no...
It might be a silly question on my part but here goes.
Did you put a new gasket between the head and block. Only reason you would have water in the block is if the block was cracked or the head gasket was defective.
Mar 14, 2015 | Vauxhall Cars & Trucks
I have a Clarion XMD2 Marine radio. When I play the radio or a CD, there is a low level "static" sound that plays over the music. I thought the power feeds or ground were bad, but direct wired...
I didn't suspect that the fault came from the speakers but in the unit itself. This kind of symptoms indicated of faulty electrolytic capacitor in the power supply section and/or in the sound output circuitry. To isolate it, you must have a capacitor checker to determine its condition or you may replaced all the electrolytic capacitor in your unit because this is only few in the set and very cheap price per piece. Just remember that you must replaced it with same capacitance and working voltage that is labelled in the body. Also, upon installing, you must check the polarity (positive and negative side) to avoid further damaged.
Also, check for bad solder joints(crack/dried/cold solder) in the board, it will produced the same symptoms.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
May 16, 2011 | Clarion XMD2 CD Player
All funtchions work except it dos'nt heat up anything Light comes on, turntable works, timer works. But no heat
I tried the ICE60705 number and it did not cross http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=IEC60705
Is that a serial number by chance?
To do any of the below the chassis cover must be removed.
To perform a diode resistance check you must first ground the high voltage capacitor several times to avoid a nasty shock.
To check the Diode you have to disconnect one side if the diode before reading resistance. Read the Diode on R X 1000 and then reverse the meter leads is should only ONE way. IF it reads both directions or not at all then it has failed.
To check the HV Capacitor (After grounding) you reverse the leads repeatedlyand watch for a momentary jump on an analog meter EACH time the leads are reversed. No jump of the meter needle = bad Capacitor.
Diodes can be found here:
http://www.appliancepartspros.com/Appliance-Parts/?keyword=Diode%2c+Sharp
I know that this is an 850W free standing Microwave. I just can recall the model number from memory.
If you find either one of the 2 parts bad I recommend contacting a LOCAL appliance parts center with parts in hand for the simple fact the model number is not crossing.
Just make sure they failed per directions above before replacement.
Thanks again for choosing FixYa.
Kelly
P.s. If the above parts check out good then that leaves the door switch or the magnetron as possible failures. If the Magnetron has failed you may want to evaluate repair vs total unit replacement cost of the microwave.
Aug 19, 2010 | Sharp R-1480 Microwave Oven
The electric motor on my compressors gets hot and will not engage the motor is direct drive
As per your comments the motor just get hot and doesn't run. Check
the starting capacitor of your motor, or have it check. It may need a
replacement. On the other hand, check the motor winding if it is partially burned. If it is burned, have it rewinded, replace the starting capacitor, and
you have it running once again.
Nov 01, 2009 | Air Tools & Compressors
Ac fan not turning on I can ''stick start it'' but which direction?
The condensor fan should be sucking air from the top and blowing it through the coils, probably a counter clockwise direction. The buzzing/humming sound is confusing to me. A humming sound sounds like a motor that can not turn over to start. A starting capacity would be needed. Just because you changed it out last year does not mean it is good. A buzzing sound sounds like a contactor problem. Contactors buzz and after a while, they will fail. In any case, you can "stick start" the condensor fan PROVIDED you are sure the ac compressor is working (this is for a short and temporary use). Also, you may have a high load duty capacitor that assists in the unit running. This will affect your condensor fan operation if it is not good. Unless you know all the components and operations of ac electrical, I would highly recommend calling out a professional.
Jun 26, 2009 | Carrier Heating & Cooling
How do I remove the print heads and clean them? Where can I can additional print heads and how would I replace them? The service center near me over the phone said that to replace the printer heads would...
The print head should be part of the inkjet cartridge. Did you not use the printer for a while? In that case, the cartridges may have just dried out. The price he quoted you sounds a bit high, but not unheard of, for a set of new inkjet cartridges.
You should be able to get replacement inkjet cartridges from Staples, Office Depot, etc.
It really is a coin toss...most people would go for a new printer...and i would recommend, get a laser printer...the cost per page is far, far less.
Hope this helps.
Bilal Hassan
Clarksville, MD
Jun 03, 2009 | Brother MFC-440CN InkJet Printer
Noise from the rear of my 97 crv when turning left and right
Hi
Sounds more a rear wheel bearing problem ?
Check for excessive play, and noise from both rear wheel bearings and hubs, with the vehicle jacked up and supported safely.
Good Luck !
A FixYa rating would be nice...Thanks... John.
Feb 27, 2009 | 1997 Honda CR-V
Subwoofer blew up my car stereo
You didn't mention an amplifier. Did you try to connect your subwoofers directly to your head unit? If so, that is why you no longer have a working head unit, unfortunately. You have to have an external amplifier to drive those subwoofer, not 22 watts per channel from an in dash stereo. You're correct in your assessment that putting the subs in again would cause the same thing. Find a reputable shop that can sell you and properly install the equipment you need to get you up and running again. Sorry for your loss.
Jun 27, 2017 | Car Audio & Video
Printer skipping lines
The printer ink that you are using are genuine?
Try Genuine ink clean the head after check nozzle , print nothing spaces , test printing pictures.
Nov 27, 2007 | HP PSC 2355 All-In-One InkJet Printer
Resistor on power supply board
Dear Biigjohn, First, first C613 means that it is a capacitor, not a resistor.And It seems to be a electrolytic Capacitor.If it has burst, then it's can will be inside. just search. the details of the Capacitor will be on it. most likely it will be a 10mfd 160V capacitor. Check and replace.
Aug 14, 2006 | Sony KV-27V26 27" TV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
