Back to:
Tags:
PC Desktops
Generic problem for all PC Desktops
Have a lexmark x6100 and
posted by JDYARK on Jul 04, 2008
Have a lexmark x6100 and can not connect it to computor. Have windows xp and it says no printer found, when i run set up disc, all cables are connected correctly and working
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jul 04, 2008
Thanks for Trying (70)
otacon
Rank:Guru Guru
Rating: 88%, 1389 votes
Did you run the setup disc with the printer not connected? You are supposed to connect it when setup instructs you to. Also, you may have a faulty cable. Try another cable if possible.
Rating Locked! (?) JDYARK has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Have a lexmark x6100 and:
I don't want to Accept this solution
Can you Help with these PC Desktops problems?
E-Machines eMachines Desktop PC
Loud, varying whirring noise up and down sounds even...
PC Desktops
insignia model NS-20wlcd the screen is blank when I swap...
PC Desktops
cannot find power suppy mine got lost please help
PC Desktops
I'm having a few issues with differen types of modems RCS...
PC Desktops
I'm having a couple of issues, I have different modem...
Loading problems.
Repair Service
Find PC Desktop Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
