Question about NetGear DG834G Router
No dsl/ internet lights
My netgear router has been working fine for a couple of months, but when I came back home yesterday, the DSL and Internet lights were not lit up and I cant get internet access. I thought it may be a problem on my isp's part and left the router overnight, but the problem is still occuring this morning. Anyone know whats happening please? Many thanks!!!
  • livinginleth Jan 20, 2009
    I have just got a NetGear DG834GSP Router and I can't get it to work at all, being a mere female of 62yrs, do I need to get an "adaptor" too? My ISP is The Post Office.
    Genius:
  • 1,056 Answers
Contact your ISP. There are some companies that deactivate your internet connection after inactivity for a period of time. They have to reset the D-Slam.
They will also have you power cycle your modem.
Posted on Jul 23, 2008
Why i have to reset the dsl to get the internet to work on my netgear router
Changing NetGear FR328S DSL/Cable ProSafe FireWall Router through DSL in order to Roadrunner Cable television as well as cannot obtain link with web. For safety to own a Quality Security Equipment.
Jun 16, 2011 | NetGear WNR3500L Router
I have a netgear range max, it has been working fine. Just last night nothing wireless in my house works. Cable modem works. Power light on netgear box is green. "i" icon is flashing green,...
You need to reset and reconfigure router
please follow the steps to reconfigure router
RESET THE ROUTER:
1. Make sure router is connected to power supply and is on while you perform the task below. At the rear panel of the router, near the antenna, there is a very small round pinhole that contains the reset button.
2. Using a pen/pencil/paper clip, hold the reset button for 60 sec. so that the test light starts flashing.
3. After few seconds when the test light stops flashing. Turn off the router and turn it back on after a couple of minutes.
RECONFIGURE THE ROUTER:
1. Please remove all the connections from the router. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router. Make sure the modem should not be connected to the router or to the computer.
2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
3. Put http://www.routerlogin.com/basicsetting.htm in address bar.
4. On the basic setting page scroll to the bottom and click on Apply.
5. When prompted for Username and Password, please enter 'admin' for the Username and 'password' for Password.
6. Click on lan ip setup under advanced.
7. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise.
8. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
9. Power off the dsl modem and the router after making the connections.
10. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
11. Open a web browser like Internet Explorer, Mozilla Firefox or Safari.
12. Access the router (http://192.168.10.1).
13. Login to the router (Username = admin Password = Password).
14. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
15. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
16. Click Apply.
17. Logout of the router.
18. Open up another browser window and try to access internet.
Regards,
Prakash
Apr 08, 2011 | NetGear WGT624 Wireless Router
Followed all the set up steps but my DSL light would not stay on
  • 1 Plug the Ethernet cable into the Internet port on your wall. If you do not have Internet ports installed in your home, connect a phone line adapter to a phone line jack. The adapter makes the phone line wider so Ethernet cables can connect to it. This does not block your phone from use.
  • 2 Plug the other end of the Ethernet cable into the Internet port on the back side of the Netgear DSL modem.
  • 3 Connect the Netgear DSL modem to a local power source. The power plug inserts into the modem via a small port on the rear of the modem.
  • 4 Insert a second Ethernet cable into one of the numbered ports on the back of the modem. Run the cable to your computer and plug it into the Ethernet port on the computer.
  • 5 Look on the back end of the DSL modem for an HTTP: address. Type this into your Internet browser's search bar. The Netgear DSL modem menu appears on the screen.
  • 6 Select how many computers are to use the modem, if you are using it with other DSL modems and set up a password (the default username and password is "admin"). Click "OK" to initiate the changes you made to the menu. You can now use your Netgear DSL modem to connect to the Internet.
  • Read more: How to Install a Netgear DSL Modem ' eHow.com http://www.ehow.com/how_5886784_install-netgear-dsl-modem.html#ixzz10lH4dl2y
    Sep 27, 2010 | NetGear DGN2000 Wireless Router
    I have a NetGear Wireless Router which wont connect to internet.
    Verify that you can connect to the internet without the router by hooking the cable from the dsl modem to your computers NIC.
    If you can connect to the internet that way the problem is with the router. press and hold the reset button on the back of the router to reset it to the factory settings. (this just makes it easy to determine the problem) if this corrects the problem you can setup your security again
    Aug 30, 2009 | NetGear RangeMax WPN824 Router
    How to add a netgear wgr614 router to dsl modem
    The NETGEAR router needs to be configured. Call NETGEAR. Try this also http://technicalsupport.blog.friendster.com
    Jan 05, 2009 | NetGear WGR614 Router
    Can't connect to the internet
    Had same problem just now but somehow power had been inadvertently disconnected at the source when cleaning the wire mess yesterday works fine now after plugging in. Hope yours is simple also, good luck. Chaslannen
    Nov 21, 2008 | NetGear WGR614 Wireless Router
    No DSL or Internet light
    Does your mac book has a phone port? You can try that to setup a dial up connection an see if it will work.
    May 20, 2008 | Zyxel Prestige 660R Router (91004397002)
    Lost internet connection
    Change the calbe from the router to the dsl modem. Make sure you check labels on the rear of these devices to make sure the connections go where indicated. Is there and ethernet light on your modem. If that is on then the connection is made. Also check if the DSL modem works directly connected to the pc.
    Jan 06, 2008 | Trendware TEW-452BRP Wireless Router...
    NetGear DG834G Router Logo
    133 people viewed this question
    Top NetGear Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
