Question about Dryers
Hotpoint ctd 40 is not heating up. It goes through a normal cycle for about an hour without heating despite selecting the high heat setting. After about an hour the lights of time delay, high heat and the actual drying light flash continuously . Still no heat!!??
  • 525 Answers
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
http://www.repairclinic.com/0088_8_1.asp
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 04, 2008
Washes indefinitely - water does not heat.
perhaps a call to a service man locally will be your best choice . none I have ever worked on had heating as an option .
Jun 02, 2015 | Bosch Washing Machines
Fisher washer stays on clen for over 3 hours
"Fisher washer stays on clen for over 3 hours" ???
I think you mean the "Dishwasher stays in the clean cycle for over 3 hours", right? First question is "What cycle?" If it's the Pots and Pans cycle, or "Pro-wash cycle" , or "Normal cycle with extra wash heat or sani-rinse options selected, then yes, this is normal! A Normal cycle (without added heat) will take about 2 hours. And a short or quick or 1-hour cycle will take less.
Sep 25, 2014 | KitchenAid Dishwashers
Not heating up
first thing to check is the heating coils,,if ok go to the censor just over the top of the door,,,this is most likely the dud part
Jul 10, 2010 | Hotpoint Dryers
Dryer will not turn off aafter it's 40 minute cycle.it will start over with 1 hour 22 minute cycle
You should check your thermostats, they can cause this problem.
Look for the air tube that goes from the blower to the drum, this is where the thermostats are normally located and the heating coil is normally located there also.
Hope this helps
Sep 30, 2009 | Maytag Dryers
This is a heating and cooling through the wall heat pump. It works normally when heating is selected - the heat pump runs and both speeds of the fan blow warm air. But nothing runs when cooling is...
You have a bad board or bad switch. I would say board. You can have service tech check this out. There is only so far you can go without knowledge of Controls ad electricity. Russ
Jul 21, 2009 | Heating & Cooling
Brand new Hotpoint Microwave doesn't heat
Brought microwave back to store. It didn't appear to be something I would be capable of fixing myself.
Got a new one which is working fine.
Mar 21, 2009 | Hotpoint RVM1535MMSA Microwave Oven
My hotpoint ctd 40 wont heat up
Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Jan 27, 2009 | Hotpoint Dryers
Hotpoint CTD 40
Thermostats do not have a reset
IF the dryer has failed by overheating, the device is called a thermal fuse, it is a one-shot protector, and needs to be replaced.
If the thermal fuse has blown the dryer is likely {expletive deleted} with lint and needs to be cleaned.
STILL require make and model details for replacement instructions
Oct 08, 2008 | Dryers
Help
stats come as a kit and often go faulty. if you are in uk, try currys masterpart
Aug 07, 2008 | Dryers
Printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Sue
Jul 14, 2008 | Hotpoint First Edition FEW12 Front Load...
Dryers Logo
287 people viewed this question
Top Dryers Experts
