I have a Astro Start Car Starter and after the 15 minutes of running when the car stops the head lights stay on and then the battery goes dead if i dont check it.
THAT IS CALLED A DEAD STARTER OR NO CRANK . condition. period.
6 TO 10- CAUSES of dead starter.
WHAT WORDS AND GOALS (stages)
CRANKS (key to start/crank) or button start /stop pushed for start.
STARTS (loud cranking heard if engine is dead)_
AND RUNS (grins)
AND STAYS RUNNING, (bliss)
IN THAT ORDER ONLY, MY CAR PUSH STARTS SO GOES FROM PUSH TO RUNS,. JUST 2 STEPS(stick shift bliss this) M/Tbox.
when kid 15yo id park on a hill and do rolling starts. 3 speed manual box then./
turns over means zero, (turns = spins the starter spins and if lucky the engine crank shaft spins or turns and if lucky starts. turns never means runs. ever. it is called RUNNING.
some call running at idle others (old) say engine ticks over.
yes heard all the slang but do avoid TURNS. and OVER.()roger over and out)
I just fixed my neighbors, the hood knows i diagnose cars for free, retired me.
her car the battery reads, 10.7vDC (truth here is only discharged)
2020 Nissan.
head lamps bright, proves nothing here. at all (unless fully dead lamps)
the battery pushes 5 amps to head lamp but can not muster 100amps to the starter. so starter is dead or after 10 tries. tiny clicks heard under hood.
I see dash lamp dim a bit at crank attempts, a huge clue there.
causes. are: in order.
including lies the BCM dash lamp tells. (key IMMO failure lamp glows)
a huge lie there, 2020 car, and I know why the 10.7vdc battery causes most computers on board to lie or be dead.
(fast forward, only here the battery is dead. and no DTC ever stored, after cure.
PCM OBD2 jack we scan the under dash jack, shows comms dead, CAN_bus dead (her car)
and expected by me. (took 20min after my full charge the cars electronics to work again, ) NOTE THE DELAY.
now your causes all and in order
battery lugs, loose or rusty or both no battery ever lasted 17 years, so is on 2 or 3 battery now. or due for 3rd !!!!!
on the gals car above the tag top-o-bat reads 2020 see? I always look at tags.
battery lugs ok, and clean', battery not 7 years old or more.
battery voltage not 10v but 12.6vdc , rested 1hr. is it? if not charge it.we ran a 75ft extension from her house to street to charge it. with my charger.
or drag the battery to the work bench and charge it. or to any shop,say test it. this battery in hand,.. (way cheaper than any tow truck) or jump start it.
my load bank test shows hard failure, even no load, and BAD shows on dial loaded, but the battery in here car is good, and fails this test.
next up, charged, the IMMO key lamp must not show failing key,we tried both. keys.
starter relay bad.
PRNDL fails at start in Park and Reverse both, or just park. bingo SOLVED
the starter is bad, even hot wired it fails keys not near car.
simple failures here, just a starter not the 50causes of engine failure.
I only jumper cable start cars if in some kind of panic (stalled in snow bank)?
I charge the battery first with the tool called a battery charger.
this is more safe for electronics old relic chargers can push 20vdc and never is that safe for modern cars(computers max).
my charger is a smart charger.
this one is real good, 1hr charge and it is 90% charged, from 10.7v.
2008 Grand Caravan 3.8 SXT
car stalled driving, or starter dead 6am,
IF runs is the Charge/battery/gen , cluster lamp off
1: the batter lugs clean and tight, first.
2: fuses good
3: stater motor dead/ (silent, clicks , chatters or?)
HEad lamps are first
they work even no key near the car they work even engine missing.
so when HL fails the battery is dead
no battery ever lasted 15 years, is it?
my wild guess is this is battery #2nd one failure day!
died at 6/7 years now again. ( common as nails)
or alternator is/was dead, and now the battery is dead
or just DISCHARGED
4: so call AAA TOW AND ASK FOR A JUMP
OR BUY YOUR OWN JUMPER CABLES AND JUMP START IT/
OR CALL MOBILE AUTO TECHS. YP.COM
ONCE STARTED WE CHECK THE ALTERNATOR NEXT.
OR IT WILL HAPPEN AGAIN FAST.
Probably your battery is dead,enough for the lights or your alternator is bad which is what keeps the battery charged. Or your car is out of petrol.
Try to start the car with the lights on...if the lights go dead when you turn the key then the battery has low voltage. Try jump starting the car.
if the lights stay bright and you hear click, the starter is bad. Try hitting the starter with a hammer a few times. If the car turns over, then get at starter. -
Did you check for B+ voltage at the heavier gage wire on the back of the alternator ? When yor turn the key to run , not start , does the charge indicator light ? When the vehicle is running is that charge light lit or off ? There is a fuse that supplies B+ voltage to it . Fuse # 30 located in the central junction box , it's a 30 amp fuse ! Plus one more fuse located in the battery junction block # 11 20amp . With out B+ voltage at these connections on the alternator it will not charge .
try getting a boost for your car.... the battery may be failing. it doesn't take alot of power to turn on the lights... but a huge drain on the battery to start it. if it will not start with a boost i could very well be that the starter has failed. as you attempt to start it... have someone tap the starter with a hammer. if it starts... replace the starter.... if it starts normally with a boost you likely need a new battery
1. Put the newly cut Master key into the keyway and turn it to the ON (RUN) position. A "security" indicator light on the dashboard will stay on for 10 minutes. 2. Within 1 minute after the indicator light goes off, turn the ignition to "OFF", then return to the ON (RUN) position. The indicator light again will stay on for 10 minutes (Do not remove the key.) 3. Again, within 1 minute after the indicator light goes off, turn the ignition to "OFF", then return to the ON (RUN) position. The indicator light again will stay on for 10 minutes. (Do not remove the key.) 4. When the light goes off the third time, the new key is programmed into the computer and will start the car. Remove the key and then re-insert it into the ignition lock and start the car. All previously stored codes will be erased. To stop the process at any time, simply remove the key and use an existing key to start the car.
