Question about Freezers
Frigidaire FRF170FF Freezer beeping
Periodically, the display ups from showing -19C to -10C, beeps with 3 shoort beeps for about 30mins, then cools back to the set point of -19C.
Is this the defrost cycle, and if so why the beeps ?
Thanks
Alun
  • alunj Jul 09, 2008
    Many Thanks,
    Problem fixed by service engineer ... sensor was in the wrong place, known issue. Sensor position caused fast defrost cycle, that only defrosted the bottom 6" of cooling chamber.
    This is a manufacturers known issue.
This is probably the defrost cycle. The beeps are the high temp alarm. It is probably overly sensitive.
Posted on Jul 09, 2008
My Frigidaire up right freezer is showing an error code "FF" and is beeping. What is the issue?
Hey friend, thanks for your inquiry!
Within your Frigidaire freezer the error code "FF" stands for freezer failure. I would perform a reset on your appliance which can be done by either unplugging the power cord or flipping the household circuit breaker. Once the freezer has come back on you should be able to push the "Down" button three times to start it back up.
If that does not correct the issue Please respond back I would like to assist you with any additional information. Hope this helps to some degree. -Matt
Sep 26, 2014 | Frigidaire Freezers
Www frigidaire com MY FFHS2313LM6 the temperature is sky high and won't cool down.
Thank you for your post, friend!
I see your Frigidaire refrigerator is not cooling and you have performed a reset on your appliance by unplugging it. You could be experiencing an issue within your control panel or sealed system. I would recommend seeking assistance from a professional to come and diagnose your appliance for the proper repair. Hopefully this is helpful. -Matt
Aug 25, 2014 | Frigidaire FFHS2313LM 22.6 cu. ft. Side By...
Frigidaire freezer M# ffu17f5hwh, is there a recall on control board?
Hello friend, thanks for the post!
I see that the red light stays on and your Frigidaire freezer continues to beep. From what I have researched there is no recall on the control board of FFU17F5HWH. You could try resetting your appliance, which could be done by unplugging the power cord or flipping the household circuit breaker in the off position for ten minutes. Please comment back I would like to know if this information has been helpful. I look forward to your post. -Matt
Aug 06, 2014 | Frigidaire FFU17F5H Upright Freezer
Why wont my refrigerator run. Constantly beeps.
The beeping is typically a code. Is there an addition of a led flashing anywhere you can see?
Jun 15, 2014 | Frigidaire FFHS2313LM 22.6 cu. ft. Side By...
Frigidaire Freezer keeps making 3 beeping sounds then displays a 1
Hello Melinda, when the refrigerator is beeping or buzzing, it may be a warning sign of a possible malfunction or an unsafe, interior temperature. To silence the buzzer, you can depress the ALARM OFF button. However, if you have already done this, try unplugging the unit or flipping the household circuit breaker for about ten minutes.
If the alarm continues, it could possibly be experiencing a communication problem with the temperature control/board, wiring failure or faulty compressor since error code 1 typically indicates an issue with the compressor. I would recommend connecting with a professional appliance tech for a clear-cut diagnosis.
I hope this information helps to some degree.
Jul 30, 2013 | Frigidaire Freezers
Frigidaire upright freezer: freezer stopped working (no power).
Hi Kevin - it sounds like your freezer may possibly be stuck in diagnostic mode. Press and hold the Up (+) and Down (-) keys simultaneously for 3 seconds or more. The buzzer will beep at the end of the 3 seconds. Hopefully that will resolve the issue.If you continue experiencing this problem, please provide a model number to your freezer and any additional symptoms it may have experienced prior to shut off. - Best of luck!
Aug 25, 2012 | Freezers
Beeping coming from freezer
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Apr 18, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Only cool air and the food will not freeze.
I'm having the same problem. What do you recommend?
Oct 26, 2009 | Frigidaire Freezers
Frigidaire Upright freezer with Beeping Display
First make sure you have a good 9v battery installed. If it is ok then the problem will probably be in the display board or the wiring connectors between the boards. CE is communication error. If your model has the electronic tempature control instead of mechanical thermostat the problem could be in there. My bet is a bad connection at display board.
Sep 05, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Freezers Logo
687 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
