FixYa.com
Tags:
OKI C5150n Led Printer
Void streaks in magenta and cyan areas only 2" wide...
posted by venture717 on Jul 04, 2008
One day, my Oki c5150n began printing void streaks on side of the page but only within the cyan and magenta color areas. I swapped the magenta drum/toner with a new one and still the void streaks remained. There is no error code. I infer an electronic issue but not the 32K base memory since I assume there would be an error code for a memory failure. So, could there be an LED driver chip failure that is affecting 2 colors for a couple of inches on 1 side of the page?
If it is an electronics failure, is it advisable to repair? I like this printer and it has only about 25K sheets on it. Are replacement boards or parts available? Suggestions? Thank you!
Comment by venture717, posted on Jul 09, 2008
Solved! Diagnosed problem to a bad LED print head. Easily replaced. Thank you.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Can you Help with these Printers problems?
Toner problems
The message says Check Toner... Answer This...
attention light is light
why is the attention light lit.... Answer This...
OKI C5151
My OKI C5150 printer recently... Answer This...
Okidata C5150 printing problem
My printer is printing the... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
