Question about Audiovox GMRS6000-2CK (14 Channels) 2-Way Radio
Gmrs6000-2ck one unit is fine but the other is off frequency.I would like to get asrvice manual or at least alignment procedures and test points have test equipment(freq counter dmm etc.Thanks
  • blueeyes4u Jul 05, 2008
    I am having the same issues. One works, the other doesn't.
  • 127 Answers
Http://safemanuals.com/ please rare me let me know if i helped.
Posted on Jul 16, 2009
My kenwood kr-v7030 won't turn off anymore with remote or manually.
Either the remote battery are flat or the frequency settings have changed. You can check with the manual the type of frequency it uses to match the that of the Kenwood. Sometimes there are switches you can change to adjust the correct frequency. Others have a learning code set by the manufacturer and are usually in the operation manual. If you want to test whether the remote is transmitting the signal to the Kenwood or not, Please do this...
If you have a digital camera or smartphone camera, switch the camera on and look at the viewfinder or camera screen; for smartphone, in a moment, then point the remote to the camera lens and press the volume button, which keeps sending the signal to the to control the volume of Kenwood system. If you see the infrared light on the remote flashing, then the remote is fine.
Now, about the smartphone camera. Start the camera and switch it for video capture (filming) and then point the remote towards the camera lens, and likewise you should see the remote light when doing the same tests as you with the video camera. If the infrared light lights up when pressing on the volume, the remote is fine.
It could be Kenwood, which requires factory repairs, not by you.
Dec 22, 2014 | Kenwood Audio Players & Recorders
Is there such a thing as a reset for the Autohelm WIND ST 50? I purchased a boat with one that showed proper wind angle but not speed. I removed the sender, greased both the wind vane and cuos. now
I assume you have an ST-50 or ST60 windvane setup. These are the calibration instructions from the unit manual for the ST-50. They are the same for the ST-60 and ST-60+ units.
Hope it helps you.
Initial Calibration Windvane Alignment
Before the unit is used for navigational purposes the masthead transducer must be accurately aligned to the vessel. Before this procedure is carried out the windvane should be linearised as follows.
1 . Powerup lhe ST50 Plus Wind instrument.
2. Tum the vessel through two complete circles, making sure that the windvane remains in line with the wind -the instrument will automatically linearise the windvane.
Alignment
1. Press and hold CAL for 2 seconds until CO is displayed by the LCD.
2. Press < > to move the pointer to the correct wind angle.- WIND
- Press < > once to move the pointer by 1 degree.
- Press < > for 1 second to move the pointer by 10 degrees/second.
The LCD will now display the applied correction.
3. Press and hold CAL for 2 seconds to exit and store windvane alignment.
Windspeed Unit Selection
1 . Press and hold CAL until Ul (Knots) or U2 (Meters/second is displayed.
2. Press CALwithin 8 seconds to change the windspeed units selection.
3. After 8 seconds the wind instrument returns to normal operation.
Nov 22, 2014 | Boating
How do I set up my go-to telescope
A "Go To" telescope needs a couple of things to work. First, it needs to be pretty level on the tripod or mount. Set the scope up in an area where you will be able to see a large portion of the sky without obstructions as you will need to align it using well-known sky objects at widely separated portions of the sky.
Follow the align procedure in the manual and enter the time, date and location. Then using either two-star align or solar system align, let the scope come close and then fine-tune it onto the objects you're aligning with. Until you either move the scope or power it off, it should continue to track from that point. Of course, you need to be able to visually find the alignment objects yourself first... Go-to is sort of a misnomer in this case - you have to find them first during the alignment and then the scope will continue along on its own.
Apr 30, 2014 | Optics
Transmitter Frequency alignment
look I'm going to tell you now. If you have no idea where to measure the voltage then you shouldn't be playing with that radio. First ,you need a scope,a frequency counter,a distortion meter,a signal generator,a watt meter,a voltmeter,a sinad meter and patience. If you have none of these then don't mess with it.
Jan 17, 2014 | Galaxy Radios Dx-949 40-channel Ssb Cb...
Xerox Phaser 7300 color misregistration
Apparently, turning the unit off for 30 seconds, then back on will force the Phaser 7300 to do a color alignment procedure (according to Xerox support).
Then, if the problem persists, you are instructed to follow a very detailed troubleshooting procedure which I will leave with you in the following link:
Xerox Phaser 7300 Misregistration Issues
I hope this helps!
Mar 15, 2010 | Xerox Phaser 7300DN Laser Printer
Panasonic SA-AK57 alignment of CD tray and disc changer
There is a particular procedure for rebuilding these units that must be followed to insure proper alignment. This procedure is available to authorized service centers only (as far as I know). Your only alternative is to purchase the service manual that contains this procedure from Panasonic.
Dan
Apr 02, 2009 | Denon D-M50S CD Shelf System
Marconi 2951 radio test set vintage
possibly a power supply problem - check current drawn from the power line compared with your other 2951. any disturbance in power supply voltages can kill the afc/pll in older service monitors. if you have the manual check the ps voltages
Sep 21, 2008 | Radio Communications
Missing manual
Here are links to the manuals. You will need a PDF viewer such as Adobe Reader or Foxit Reader in order to open them:
Users Manual
Quick Setup Guide
Software Users Manual
It seems to me that you are missing part of the print alignment procedure. See page 12-18 in Chapter 12, Troubleshooting and routine maintenance, of the Users Manual.
If the unit fails after two or three proper and complete attempts, the unit might need service. Contact Brother Customer Service for further troubleshooting -- see page i of the Users Manual.
Jun 01, 2008 | Brother MFC-3240C All-In-One InkJet...
Uniden washington pll8719 frequency alignment
YOU CAN GET SCHEMATICS FOR THAT MODEL
I JUST LOOKED IT UP FOR YOU........THE BOOK IS SAMS PHOTO FACT.....THEY HAVE THE ALIGNMENT PROCEDURE IN THERE....
WEBSITE IS
WWW.SAMSWEBSITE.COM
THEY HAVE EVERY CB RADIO EVERY MADE
Apr 21, 2008 | Radio Communications
Programming Bearcat BC 55XLT Scanner
Ok doc, I'll see if I can walk you thru this as there don't seem to be a manual available for download.
* Push manual button and bring it around to channel #1
Enter the freq including the decimal point. Push the E button to enter the freq into the first channel.
* Push manual again and move to channel #2 and repeat.
If you need some new freq's for your area, go here, click on your state, county, and it'll give you a complete rundown.
http://www.radioreference.com/apps/db/
If you need 10 codes for your area, go here and click on your state.
http://www.nat-com.org/radio.htm
If you need anything else, let us know,, Mechanic
Feb 19, 2008 | Radio Communications
Audiovox GMRS6000-2CK (14 Channels) 2-Way Radio Logo
105 people viewed this question
Top Audiovox Radio Communications Experts
eradiostore
eradiostore
john milligan
Computer Repairing
Computer Repairing
Are you an Audiovox Radio Communication Expert? Answer questions, earn points and help others
