Question about Toshiba Televison & Video
I have a Toshiba SD-P1700SE Paortable DVD Player which keeps on sticking. It works again when I tap the dvd cover. Can this be fixed
  • Johnny828 Jul 04, 2008
    Thank you for your suggestions which I will try and let you kmow how I got on.
    President:
  • 173 Answers
Try and clean the inside of it out with compressed air and cu-tips. Remove the cover and open the cd tray > Unplug the dvd from the power source > Use the compressed air to blow out the inside of the dvd really well > Use a small light source to look inside to make sure there is nothing caught in the spindle like dirt, hair, dust, etc you need to look really close > Take the cu-tips and one by one dip them in a small amount of alcohol and clean the inside of the carriage and around the spindles and gears > Clean the optical lens also > Repeat this numerous times and with blowing the inside out and cleaning with cu-tips > Let air dry for 1 minute and replace the cover and plug back into a power source and check the disc (make sure your discs are clean and scratch free also). If this still does not solve the problem, it could be that your spindle is going bad. The good news is that it is not that expensive to replace. Hope this helps and let me know if you need further assistance.
Posted on Jul 04, 2008
Dvd player toshiba sd-350esb schematics would be great
Toshiba SD-350ESB Manuals
www.manualslib.com > Brands > Toshiba Manuals > DVD Player
... User Manuals. View online or download Toshiba SD-350ESB Owner's Manual. ... Manuals and User Guides for Toshiba SD-350ESB. ... DVD VIDEO PLAYER.
Toshiba SD350ESB DVD player - Instructions Manuals
www.instructionsmanuals.com/modelo-8363-en-DVD+player.htm
Download instructions for TOSHIBA SD350ESB. Toshiba SD350ESB DVD PLAYER. Click on the instructions manual you would like to download for the model ...
Nov 07, 2015 | Toshiba Televison & Video
SD-P1700SE just laods willnot play
Either the lens is bad or you have a bad DVD.
Apr 30, 2012 | Toshiba SD-P1700 Portable DVD Player
Toshiba DVD Player - How do I get the DVD out of the Tray when the power is no longer working?
Open the top cover by removing all the screws around the cover and the two screws on the sides.
Gently lift up the cover from the backside up and pull back to free it from the front.
Now you can see the DVD player is exposed. Gently lift the DVD disc out from the back.
Voila!
This does not fix the "try not opening problem though"
Good luck,
Steve
Dec 26, 2009 | Toshiba SD-V291 DVD Player/VCR
How do I get a DVD out of the tray if the DVD player has stopped functioning? The power still works, but the buttons on the player (and the remote) have no effect.
Open the top cover by removing all the screws around the cover on the back side and the two screws on the sides.
Voila!
Dec 16, 2009 | Toshiba SD-V291 DVD Player/VCR
DVD player will not open
try unplugging it for about 2 minutes to clear some memory and try it again. the tray motor may be shot or skipped a tooth on the gear and not hitting the switch. you may need to take the cover off and physically do it.
Dec 14, 2009 | Toshiba SD-K860 DVD Player
Sd-v392 claims incorrect disc on most dvd`s
I removed the cover,the dvd unit and cleaned the laser lens with alcohal. The two back screws were loose on the dvd unit. It`s working like new again.
Sep 18, 2009 | Toshiba SD-V392 DVD Player/VCR
Toshiba SD-220E
Have you tried unplugging the player completly for 2 minutes? Plug it back in and try again. Also, you could try a new remote code or just replacing the system. P.S. some players have a cap/switch or button that needs to be removed or pushed in order to accept input.
Feb 08, 2007 | Toshiba SD-220E DVD Player
Trouble with the disk tray
clean the tray, or replace the belt open the cover of your dvd
Jan 19, 2007 | Toshiba SD-3980 DVD Player
DVD PLAYER
Hi Koji, My Toshiba DVD player does the same. It stops playing the disc, and the icon for incorrect disc displays. Often I cannot even start a movie. I keep getting BAD on the readout display also. I try hitting the player, or the stand in which the player is sitting, and sometimes it goes away and the movie plays. I will never buy Toshiba again.
Dec 25, 2006 | Toshiba SD-3980 DVD Player
My Toshiba SD-3960 sound does not work.
First thing before a landfill is to go into the units menu and see if something in the audio got turned off if not then inspect the connectors on the back for breakage. Good Luck
Apr 02, 2006 | Toshiba SD-3960 DVD Player
Televison & Video Logo
154 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
