Question about GE Profile JTP56 Electric Double Oven
GE Smallworld **** Error: Object unset does not understand message draw_prim() with arguments: 3, unset does_not_understand(object=unset, selector=:|draw_prim()|, arguments=simple_vector:[1-2], iterator?=False, private?=False) ---- traceback: cli ---- sw!version=3.2.1. os_text_encoding=cp1252 graphics_view ().deal_with_changed_view({:dont_redraw, True, :centre, coordinate:(2.726e+008,2.122e+009), ... }) graphics_system (ace:(O&M_General_User)).init_graphics(graphics_view, pixel_coordinate:(0,0)) graphics_system (ace:(O&M_General_User)).re_realise() graphics_system (ace:(O&M_General_User)).select_ace("O&M_General_User", True, True) a gis_program_manager.start_or_restart_application() unnamed() proc unnamed.invoke() rope:[1-1].fast_elements() a smallworld_product.start_application() a smallworld_product.startup() startup(simple_vector:[1-0]) invoke_with_bombproof(proc startup( gather options)) a system.run_startup_proc(proc startup( gather options)) a system.save_delta("c:\GIS_Application\images\mgl_auth_2_1.msf", {:redirection_file, "mgl_auth_2.msf", :startup_proc, proc startup( gather options), ... }) save_image_startup() *** top level ***() a magik_rep.process(simple_vector:[1-5]) a magik_rep.super(magik_rep).cli(a terminal, "MagikSF> ") cli() light_thread_launcher_proc_990928() False ".\mgl_auth_2_1.msf"
SOURCE: replace upper grill element in a old GE wall oven
Replaced selector switch...problem solved.
Posted on Dec 05, 2008
  • 14 Answers
SOURCE: Oven top element gets SUPER hot without warning
the sensor in your oven is picking up the high heat and posting error message which displays F2 ,at least the sensor is working but lets look at the problem isuspect one of two the first is your control switch needs tested i would say this is the problem and number two the elemant could be on its way out either of these problems are going to need a electrican to fix ,sorry i cant give you a simple answer to your problem.adrian
Posted on Feb 14, 2009
MNTECH
  • 1543 Answers
SOURCE: GE True Temp oven won't turn off.
The sensor is a part number WB23T10002 and goes for about $60. The paper inside the control area of the oven will state the normal resistance values of it. (probably about 1080 ohms at room temp, about 2650 at clean temp.) If you cut a lead to it, you would just get a F3 code, and if you cut the other and wire them together, just get a F4 code, so that wouldn't help diagnose the problem, but if you could use an ohm meter on the probe it would. BUT the oven should not come on without it being set to bake, SO I conclude that the ERC is indeed the problem (with the welded electrical contacts), which is a part number WB50T10043 which might go for about $125 or so. If you are careful when you replace it, you can probably peal the faceplate (part # WB27T10125) off and reuse it, so you should just need the ERC.
Posted on May 07, 2009
fixyourboard
  • 310 Answers
SOURCE: I was cleaning my GE profile convection oven and
We frequently see this symptom due to a failure in the electronic range control (ERC). We repair a lot of these.
- www.fixyourboard.com
Posted on Jul 25, 2009
heatman101
  • 43501 Answers
SOURCE: Oven/ broiler will not heat and bottom element slow to reach temp
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Apr 28, 2010
GE oven displays an F 7 error message
Hi Mark, Why not search online for this error code + ge oven? You'll get the info you need but don't necessarily want!
Jul 15, 2015 | GE Ovens
I have a GE True Temp Stove/Oven and the oven will not heat up past 175 and the broil does not work either. It is approximately 13 years old. Any suggestions?
using a multimeter set to measure amperes check each ignitor they should be drawing in between 3-3.3 amps any less then this would be considered a weak ignitor and you would have to change the ignitor if you have any further questions message me back and please rememeber to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Mar 14, 2011 | GE Ovens
F9 error message during self cleaning cycle
Hello,F9 error means there is a problem with the lock switch.Check the wiring to the door lock switch (the wire harness may be connected wrongly).Check for stuck lock switch.
Thanks
May 31, 2010 | GE Monogram ZET3058SHSS Stainless Steel...
What is error message F7 mean in GE Wall Oven?
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Jan 31, 2010 | GE Ovens
I was cleaning my GE profile convection oven and after the 3 hour cycle, an error message F 1 started flashing, and the oven started beeping.
Jul 24, 2009 | GE 30" Built-In Single Electric Convection...
I CAN'T FIGURE OUT HOW TO CHANGE THE LIGHT BULB IN MODEL JT910 WALL OVEN.
if i'm correct it should be on the left side of your oven or maybe on the right lol but there is a glass object that looks like a light bulb its thick glass you just twist that offf as its a screw lefty loosy righty tighty and there you go you also might have a litle wire across the big thick glass bulb looking object which you have to just move out the way no snapping of or anything
Jun 07, 2009 | GE Profile 30" Built-In Single Electric...
GE JT912-30 single wall oven "help" with F7 - F0 error
I have a double oven GE Profile. The error message FO appeared. I shut off the circuit breaker for 30 minutes or more and the oven works but without warning FO reappears. FO message means there is short in the clear Off touch button. The only solution replace the complete panel. My cost delivered $328. Ouch!
Jan 19, 2009 | GE Profile JKP56 Electric Double Oven
Error message
Webgenie, the code should read F3, which indicates a open oven sensor (over 2900 ohms). The sensor should ohm out at 1080 ohms at room temp. Best thing to do is replace the oven temp. sensor. Easy job..Catriver..post back.
Sep 24, 2006 | GE Profile JTP56 Electric Double Oven
GE Profile JTP56 Electric Double Oven Logo
63 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
