Computers & Internet Logo
Posted on Dec 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I turn my computer on it says configuring updates stage 3 but shuts down and restarts again saying the same thing
Adaptation41
Level 2:
Scholar:
New Friend:
  • Expert 48 Answers
  • Posted on Dec 22, 2010
Adaptation41
Expert
Level 2:
Scholar:
New Friend:
Answers
48
Questions
0
Helped
7360
Points
136
That is a common fault of Microsoft where the updates aren't compatible with your system or a patch doesn't finish and may have shut down prematurely and corrupts it. You should try to boot with safe mode when you power on the computer hit f8. Then go into the control panel>add remove programs. There is a way where you can sort to only see Window updates that start with kb and you can delete the recent ones by date and then restart and try again.
1helpful
Inspiron 1525 crashed during stage 3 configuration
Follow the instructions here to repair the OS, then manually install the update that causes the issue before enabling automatic updates
http://news.softpedia.com/news/Get-Vista-Out-of-the-Infinite-Reboot-Loop-Configuring-Updates-Stage-3-of-3-0-with-Vista-SP1-78933.shtml
7helpful
5answers
Keeps coming up with configuring updates stage 3of 3 0% complete do not turn off your computer then it shuts down and comes back on again
Please use this solution thta I have placed on this forum.
Please follow exactly these steps then you computer should be working again.
I have used the following solution.
Restart computer.press f8 then choose option restore computer.
choose option open command.
type: prompt winsxs (press enter)
type: move C:\windows\winsxs\pending.xml text.xml (press enter)
type: exit and restart computer.
Computer should be working again.
good luck.
hope it works for you.
pieter.
1helpful
My new lenova thinkpad t400 seems to be caught in a loop. I've taken the battery out and ctrl alt delete but still goes back to configuring updates: stage 3 of 3 screen and then says shutting down, but it...
Hello!
This is a tough one. I've seen this recently and had to just press and hold the power button to shut down. Not good!
I'm assuming you're using Windows of some sort since it shows "Stage 3 of 3" when it does updates during shut down.
What has happened is you downloaded some sort of "fix" from Microsoft and it's getting stuck while trying to install. I've had this happen and have never found a good solution for it.
1. Turn you computer off.
2. Turn your computer on
3. As soon as the power comes on, start pressing F8 repeatedly.
4. When you get a black and white menu, use your arrow keys to move up and down, select "Last Known Good Configuration" and press enter.
What the solution I've provided does is revert your computers software to a point in the past, hopefully just before you received the screwy update.
Make sure to rate the solutions you get!
Acer5920 stuck in configuring updates.
This is generally caused by bad blocks in the Master Boot Record(Table). The drive itself is probably not salvagable. You'll need a reputable reapir person to slave your drive to another system to get the data off.
Good Luck
1helpful
My Toshiba Satellite L300D keeps shutting down when I start it up
restart in bios setup
then click to default settings press f10 to save and exit
if problem persists let me know
don't forget to rate
The laptop will not start up
This sounds like a bad battery. If the battery has a short within it, it will cause the power system to shut down. Replace the battery and see if that works.
1helpful
2answers
My emachine is stuck cycling at start up
no computer is trash when you are dealing with a software issue.
boot up and tap on the f8 key... when you get to that screen... choose safe mode... if it successfully boots.... go to start menu... and restart again... it should boot... if it wants to do the update let it.... if still nothing.... f8 again and choose last known good configuration
Robert
I have an acer aspire laptop, when i start it up its says configuring updates stage 3 of 3 0% complete then it will shut down come back on say the same again and shut down again. it will keep on doing this
Maybe you could try the last known good configuration. When the laptop is starting up, wait until the acer screen disappears and then tap F8 on the keyboard before the windows screen comes up. You should get a black screen with some options that say safe mode. The fourth or so option on the list will be "Last Known Good Configuration". The computer should try and load windows. Hopefully that will restore the machine before the update.
If it works it would be a good idea to go to http://windowsupdate.microsoft.com/ and fully update your laptop. This will download the update manually instead of doing it with automatic updates.
When i turn my laptop on it goes to through its usual process but when it gets to the point where i type in my password it says "configuring updates stage 3 of 3 0% complete" then it shuts itself...
need new windows to insatll
maybe u installed some mawares that corpted and damaged windows files
intall new windows
but give me fix ya rate!!
XD
2helpful
Configuring updates
If it is windows xp OS plz do the following these step.
start the pc in safe mode and select the administrator login then
go to start programme go to acssories select the system tool- selcet the restore option, turn on windows in previous back day and resloved the porblem,.
bye
Grand Canyon Tech
Grand Canyon Tech
