My monitor doesnt turns on but noting happens
And the bulb inside the monitor turns on but very dimm light then shuts of but when i plug in a diffrent monitor everything is ok
I have try it with another monitor, Only want i can see on is the small box that has out scan range with a very dimm light.
Posted on Jul 04, 2008
The front blinker light bulb works but the same bulb doesnt work for parking light
Replace the bulb. There are 2 wires inside the bulb. One for turn, one for park. If you did this, then look to fix or replace the plug for the bulb.
Jan 07, 2017 | Cars & Trucks
My right front turn signal on my 2001 ford ranger doesnt work and my inside right turn signal light on dash doesnt work and flashes really fast. Buld on right side was replaced and works when lights
was the correct bulb used? this sounds like a single function bulb was used NOT the bulb that will light with the headlights and ALso produce turn singles
Dec 06, 2014 | 2001 Ford Ranger Regular Cab
My desktop turns on but my monitor doesnt come on its plugged in right but my desktop just shows a light that its on
use other monitor..if it would not work listen for beep codes from your cpu.continuous three beeps meaning change your memory cards or check your memory cards..see if your monitor has light
Sep 01, 2012 | Gateway GT5220 PC Desktop
E machine model T3626 turns on display doesnt work and doesnt power off???
Sounds like either the Monitor is bad or the Video Card is bad. Try plugging another monitor on the computer and if it can't show a display then more than likely the Video Card is bad. If it shows on the monitor you just plugged in, then the original monitor is bad.
May 01, 2012 | Computers & Internet
I have a ViewSonic VE910b 19" That the display stays black
What your both experiencing is a slow degradation of the inside light bulbs. Just like what happens to regular fluorescent bulbs, they slowly flicker out.
Best to buy a new monitor.
Take apart your old one, you'll find burnt out bullbs on the upper and lower chassis deep inside.
Apr 22, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
The inside light does not come on
If the light doesnt come on and it heats and the turn table spins then it is just a bulb.
If there is no light no heat and the turn table doesnt turn then there is a monitor switch that is bad.
Nov 26, 2008 | GE Advantium SCA1001SS Convection /...
Powers up but black screen shows
1st - Try pressing <Fn> + <BrithnessUP> keys a few times, (on HP <Fn> key is between <Ctrl> key and <Windows> key, <BrightnessUP> key is <F8> key and <BrightnessDown> key is <F7> key. If nothing happens try the 2nd one.
2nd - Plugin external monitor, (type and size doesn't matter). Turn on your laptop. If you can see desktop on the external monitor, your drivers are o.k., The problem is your laptop display, NOT the graphic chip.
Oct 21, 2008 | Microsoft HP Pavilion DV6276US Notebook PC
Wont stay on
I have the same monitor with the same problem, it would keep restarting up. I found 2 identical 470uF 25V caps that had vented and failed on the power supply board next to the edge. I replaced these and the monitor now works fine.
Feb 13, 2008 | Envision EN9410 19" Flat Panel LCD Monitor
Thinkpad T20 no boot
Dec 19, 2007 | IBM ThinkPad T20 2647 Notebook
Infocus LP725 projector
The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
Check the projector’s lamp to ensure that it is securely connected
in the lamp module. Make sure by removing it and reinserting it.
Check the cables for problems.
When testing, power up in this order. Projector, Computer monitor, Computer.
A minor power surge may cause the lamp to shut off. Turn the
projector off, wait at least 30 seconds, then turn it back on.
I hope these suggestions help
May 25, 2007 | InFocus LP725 and LP735 Replacement...
Computers & Internet Logo
582 people viewed this question
David Payne
David Payne
