Question about Epson Aculaser C1100 Printer
Toners c1100 epson
How to rotate spindle of toners
  • 1 more comment
  • soler Jul 04, 2008
    Again and last. The toner cartridge I intend to change is not visible and it does not come automaticaly. Is there in the world someone capable of telling me how to unblock the spindle to brig the black in front? It is a C1100 Epson
  • Anonymous Jul 22, 2008
    what is the answer to this
  • itryhard Oct 05, 2008
    My Aculaser C1100 printer is  giving me a message to "replace C Toner Cartridge", but I don't know which one is the C cartridge or how to get it out of the printer. I can't find a handbook or even an instruction sheet for the machine,  so I'm stumped!
Yes this one is a pain.
On the LCD display choose the 'Reset Menu'
Then within that menu keep going through the (many) options till you get to
'Change Toner M' (if it is Magenta)
or 'Change Toner C' (if it is Cyan)
etcetera.
Once you select the appropriate 'Change Toner' it will rotate to offer the correct toner. Open up the lid at the front (the word Epson is on it). Reach inside and change the position of the coloured part of the toner cartridge on the right to the Unlock symbol and then ease the cartridge out. It comes out at a slight angle as the part you move to unlock it comes out slightly in front of the other side.
Then put the new toner cartridge in and turn the coloured part to the locked symbol and close up.
The same process will allow you to move any of the toners in and out.
Cheers
Posted on Oct 16, 2008
    Sergeant:
    Champion:
  • 334 Answers
Lol help her
Posted on Oct 15, 2008
    Brigadier General:
  • 6,966 Answers
Hi again,
I have responded in your other post that the printer will automatically do so if and when you are replacing or inserting new toner cartridges.
Pls see your other post here.
ope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 04, 2008
  • Louie  Role
    Louie Role Jul 04, 2008
    Pls try:
    Version 0
    Printer Display "Ready to Print"
    Menu button
    after Tray Setting, arrow down
    Replace Toner, arrow right
    select cartridge color
    Close door
    Version 1
    Press menu
    Arrow down until "Replace Toner" appears, arrow right, Enter
    Arrow up/down until desired toner color appears, Enter
    Close front door.
    Version 2
    enter Menu
    select Information Menu, Enter
    Select Reset Menu, Enter
    arrow down
The black toner needs replacing but I can't get to it. The Cyan toner is at the front and I can't move it round to get to the black! It's an Epson Aculaser C1100
there maybe a cartridge replacement button to drag the print head etc out of the way so you can get at the cartridges.
I hope this was helpful
Jan 11, 2011 | Epson Aculaser C1100 Printer
Konica Laser says no toners installed. How do you
Take the tonner catridge and shake it left to right and reinsert then it will be ok
Dec 20, 2009 | Epson Aculaser C1100 Printer
Toner needs black toner how do i replace just the black toner
You shoulh have a button to rotate the carousel, or unplug the power cord and try again.
Mar 03, 2009 | Epson Aculaser C1100 Printer
I have a service req E527 error on my Epson printer. how to fix?
To fix the E527 error, close the front panel (cover A) and open the top cover (cover B). With the photoconductor unit removed, the toner carousel will rotate. It only rotates if cover A is closed all the way. You can easily rotate the carousel to a position where you can remove/reinstall the stuck toner cartrdige. report_dis_text_13954 = 'We\'re sorry but you must be signed in to report inappropriate material. Click the button below to sign in or register.
  • Sign In / Register »
  • Cancel »
Jan 17, 2009 | Epson Aculaser C1100 Printer
How to install toner chip on epson c1100
The toner chip is situated on the end of the toner cartidge - it's a circle, about 1.5cm in diameter.
They may have given you a new housing, in case you damage the one currently on your toner, when you try to remove it.
Nov 15, 2008 | Epson Aculaser C1100 Printer
Toners c1100 epson
Easiest way is to open the front door, poke a screw driver into the interlock on the left side and this will free the carriage to rotate.
You can also do this via the printer driver, and the printer control panel. It's all listed in the User Manual.
Jul 04, 2008 | Epson Aculaser C1100 Printer
Toner changing
Open the front door, poke a screwdriver into the interlock on the left side. Rotate the carriage as you wish.
You can also rotate to the correct cartridge by using the printer driver and via the control panel on the printer.
Jul 03, 2008 | Epson Aculaser C1100 Printer
Changing toner cartridges
Go to reset menu on printer LCD Panel
Hit enter button
Scroll down until you get to the "Change Toner M/C/Y/K" hitting the enter key when you get the appropriate letter.
This will rotate the appropriate cartridge to the opening!
Dec 19, 2007 | Epson Aculaser C1100 Printer
Epson aculaser c1100 cant access empty ink cartridge.
go to the reset menu (right arrow and then down arrow until reset menu is displayed) on the lcd display and then choose change toner #(right arrow until the desired toner is displayed) Hope this helps
Sep 27, 2007 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Logo
475 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
