Question about Epson Aculaser C1100 Printer
Toner changing how to rotate spindle
  • 3 more comments
  • soler Jul 04, 2008
    My problem it is not with HP but EPSON C1100.
    Must be something easy to unblock the spindle to put the black catridge un front
    Your instructions did not work. The rotating of spindle it is not done automatically. Perhaps I have to wait for a more exahusted cartrige?
    Again, how to get de black cartridge infront?
    NO SOLUTION GIVEN. A PITTY!
    The spindle of toners remain blocked and the black toner do not show neither automaticaly
    nor other ways.
    President:
  • 2,712 Answers
Found this solution elsewhere, hope it helps:
Method 1:
Remove the Photo conductor unit, use a pencil or similar to hold in the catch on the front door flap. This catch locks the spindle from moving, once it is pressed in you can rotate the spindle by hand from the top of the printer. Just be sure to line up the slots for each cartridge correctly before letting the catch go.
Method 2:
Go to reset menu on printer LCD Panel.
Hit enter button.
Scroll down until you get to the "Change Toner M/C/Y/K" hitting the enter key when you get the appropriate letter.
This will rotate the appropriate cartridge to the opening.
Method 3:
You will have to wait for a "Toner Low" message. Then do the following:
  1. Make sure that Ready or Sleep is displayed in the LCD panel.
  2. Select Change Toner X (The letters C, M, Y, or K appear in place of X, indicating the colors Cyan, Magenta, Yellow, and Black.) in the Reset Menu on the control panel.
  3. While the cartridge X you selected above moves to the cartridge replacement position, Please Wait appears on the LCD panel.
  4. Replace Toner X appears in the LCD panel when the cartridge to be replaced reaches the cartridge replacement position.
If you found my solutions helpful, kindly take a moment to "Accept" it.
Thanks.
Posted on Jul 04, 2008
  • Epson Master
  • 1,879 Answers
Greetings,
Instructions with illustrations to help you remove a toner.
http://files.support.epson.com/pdf/al1100/al1100q1.pdf
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
  • 2,071 Answers
Http://www.tradebit.com/filedetail.php/813599-Documents-eBooks-
Technical
    Master:
  • 848 Answers
This site may be helpful to solve your problem
http://files.support.epson.com/htmldocs/pho870/pho870u1/PAPER_5.HTM
  • gopinath pasupathy Jul 05, 2008
    check whether a piece of paper is blocking your spindle
    check whether your toner is placed properly
    Brigadier General:
  • 6,966 Answers
If you are referring to rotating the spindle in order to install the Cyan, Magenta, Yellow, and Black toners cartridges respectively, it is done automatically by the printer. Pls follow these steps:
1. Make sure the printer is turned on, then open front cover.
2.
Verify that the cover from inside of the printer has been removed.
3. Shake the new toner cartridge thoroughly.
4. Hold the tag and gently pull the toner seal upward.
5. Insert the toner cartridge firmly with aligning the arrow mark.
6. Lock the toner cartridge.
7. Close the cover the front cover.
8. Repeat 1 to 7 steps to install other toner cartridges.
Incidentally, FixYa has an illustrated Online User Manual and Guide for Epson Aculaser C1100 Printer here where the above steps were detailed.
Should you be interested, the user
/setup manual maybe downloaded from here whereas a service manual is available here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • 1 more comment
  • Louie  Role
    Louie Role Jul 04, 2008
    Hi again,
    You need to cycle the steps several times up until the black shows in the printer's display.
  • Louie  Role
    Either exhaust the contents of the cartridge or if you want to change a single particular cartridge, you have to go through several levels of the printer's menu system and select it so that the printer rotates it into an accessible position.
  • Louie  Role
    Pls try:
    Version 0
    Printer Display "Ready to Print"
    Menu button
    after Tray Setting, arrow down
    Replace Toner, arrow right
    select cartridge color
    Close door
    Version 1
    Press menu
    Arrow down until "Replace Toner" appears, arrow right, Enter
    Arrow up/down until desired toner color appears, Enter
    Close front door.
    Version 2
    enter Menu
    select Information Menu, Enter
    Select Reset Menu, Enter
    arrow down
    Genius:
  • 1,142 Answers
What it the exact problem you are facing
    Guru:
  • 1,894 Answers
See this link
How to clean the magenta toner sensor on a canon imagerunner c5255 copier
Step 1Turn off and unplug your Canon copier. Put on a pair of latex or work gloves to keep toner and debris off of your hands. Cover a table, desk or other surface with three to four sheets of newspaper to protect the surface from spilled toner Step 2Open your copier's toner cartridge door on the front or top of the device and remove the toner cartridge. The cartridge contains the drum as part of its unit. Lay a flannel cloth onto the newspaper-covered table, desk or other surface and then shake the toner cartridge gently above the cloth to coat the cloth lightly with ton
Place the cartridge upside down on the newspaper-covered surface and open the drum's shutter door, which contains hinges. Rotate the drum using the spindle on the side and wipe the drum's surface with the toner-covered flannel cloth to remove any dust, dirt and caked-on debris. The drum only rotates in one direction. Work quickly so as not to expose the drum to light. Artificial and natural light can damage the drum's surfac Step 4Continue rotating and wiping the drum's surface until it is free of any debris and dirt. Close the drum's shutter door and reinstall the cartridge back in your Canon copier.
Sep 28, 2016 | Canon Office Equipment & Supplies
I have an old toastmaster bread machine model 1154, and I realized that the kneading blade does not rotate when the ingredients are in the bread pan. Either the kneading blade mounting shaft and the...
If the spindle is turning and the paddle is not then your paddle is worn out and probable slipping on the spindle. If the spindle isn't turning then your problem is underneath the pan or inside the drive and your paddle may be fine.
Dec 01, 2010 | Toastmaster Kitchen Appliances - Others
I would like to change the toner how to change it machine is toshiba e studio 45
You have to purchase genuine toner catridge from toshiba dealer . after purchasing the toner
1) Open the front toor
2) Toner catridge is there on above of the drum unit, there will be lock for toner catridge cover on the machine, it needs to be opened
3)Rotate the toner catridge in clock wise and pull the catridge ,it will come out
4)Insert the new catridge and rotate clockwise at a time it will get enhance with toner motor
5) close the toner cat cover, front door, TURN ON the machine it will get rotate for few seconds (adding toner) then it will becomes ready
May 20, 2010 | Toshiba e-Studio 45 Black and White Copier
Rotating toner cartridges to change
Every time you open and closes the door cover the toners rotate,open and close it untill she can see the black cartridge.
Apr 08, 2009 | Canon Office Equipment & Supplies
Can not get this to recongize toner?
did you change toner from printer menu or rotate toner rack manually ??? this printer toners must be changed from printer menu, because printer counts toner there is no chip on toner.
Oct 05, 2008 | Konica Minolta magicolor 2300DL Laser...
How do I change black toner? Blue is accessible but how do I get it to rotate?
I have opened and closed the front door a number of times so that the cartridges rotate to different positions. It's trial and error until the right color is in the position to be changed.
Aug 12, 2008 | Minolta magicolor 2300W Laser Printer
Toners c1100 epson
Yes this one is a pain.
On the LCD display choose the 'Reset Menu'
Then within that menu keep going through the (many) options till you get to
'Change Toner M' (if it is Magenta)
or 'Change Toner C' (if it is Cyan)
etcetera.
Once you select the appropriate 'Change Toner' it will rotate to offer the correct toner. Open up the lid at the front (the word Epson is on it). Reach inside and change the position of the coloured part of the toner cartridge on the right to the Unlock symbol and then ease the cartridge out. It comes out at a slight angle as the part you move to unlock it comes out slightly in front of the other side.
Then put the new toner cartridge in and turn the coloured part to the locked symbol and close up.
The same process will allow you to move any of the toners in and out.
Cheers
Jul 04, 2008 | Epson Aculaser C1100 Printer
How to rotate toners
To rotate the toners:
1 press the down arrow until reset menu appears press the right hand arrow once
2 Scroll through the menu until change toner appears.
3 Toner C appears first continue scrolling until you reach the desired toner eg K for black then.
4 Press the right hand button and the red light will appear on yhe main button.
5 Open front door and change toner.
Works for me after hours of searching. Hope it works for you.
Jul 03, 2008 | Epson Aculaser C1100 Printer
Changing toner cartridges
Hit enter button
This will rotate the appropriate cartridge to the opening!
Dec 19, 2007 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Logo
133 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
