Question about Pioneer Car Audio & Video
Im not getting any power to the stereo after connecting all wires.
    Master:
  • 726 Answers
Ok i dont no if its a stock one or a cd player so ill tell you wat i no
if its a stock one check all your fuses and on the back of the head unit and the radio fuse
if its a cd player there will be a fuse on the back of the unit also
remeber red (positive ignition) and yellow memory constant power it wont turn on unless yellow is hooked up
black ground
another way to do it is have red and yellow joined straight to the battery with a fuse but u will have to turn the unit off by your self instead of turning the key if u need more assitence tell me more of the car and how u have done it so far and if ur using a wiring loom that was with the car
Posted on Jul 04, 2008
No power coming thru power wire to my stereo decks any ideas?
You have two wire of 12V + going to your stereo, one is hot all the time and one comes from the ignition switch ( which turn on the stereo when you switch on the car), if it's the +12V one which is hot all the time, you can take another wire from your car's cigarette lighter 12V outlet. if it's the ignition +12V one, you can trace back the wire to ignition switch and change the wire if it's broken.
Hope it helps and please rate the answer if it was helpful, thanks!
Mar 08, 2010 | 2003 Kia Rio
Im trying hook up a subwoofer to my reciever and its getting power to the amp, however the amp is not powering on.. do you have any idea?
did you hook up the power antenna or amp. turn On wire? make sure you should ha a wire that is to power an antenna and this is the wire that has 12 volts as soon you turn On your stereo and send 12 volts to your amp. but if you don't connect this wire, the amp will never turns On
Jan 04, 2010 | Kenwood KDC-MP438U Car CD/ MP3 Player
Jvc deck same problem, powers on and functions but no sound
the car is equiped with an amplifier. there is a black wire that you didn't connect. just connect it to the blue with white wire from your radio and it should work.
Sep 06, 2009 | JVC AM FM CD DET FACE CAR STEREO
After replacing my battery i have to put the code in every time i start the car for the radio is this electrial or fuse problem
ok , as you may know, your car has a security feature that disables the stereo every time the power is disconnected from it. so that is your problem. you have 2 power supplies to your stereo. one is a wire that is connected to your ignition switch, so that is like an electrical switch so to say, that powers up the unit when you start the car. the second is a slightly larger wire that supplies a constant current to the stereo, even when the cars off. this wire allows the stereo to save your sound and radio presets, and other memory when you turn the ignition off. this constant wire is most likely your problem. im not sure where this wire is spliced into your battery. it may be at athe battery, or it may be a wire leading into your under hood fusebox. check the owners manual for the fuse locations, and check to see if they are bad. then, check to make sure there werent any wires or connecters that may have been left off by accident when the stereo was disconnected. finally if that doesnt work, you can locate this wire, and replace it, if you know how to use a digital multimeter. just determine what wire is the constant, cut and splice a new wire into the stereo-end of the old constant, then run that wire to a constant power supply, like directly to the positive battery post. if you do though, just make sure that the wire will be clear from any moving or hot parts, and dont forget to install some kind of fuse near the battery. im guessing a 10 amp fuse should be sufficient. hope this helps you, or at least gives you a good starting point.
Aug 03, 2009 | 2004 Mitsubishi Galant
Im installing a stereo in my 92 subaru legacy but dont know which wires connect to which
generally u have 2 power wires. one is a constant power to the battery for backup memory for stations etc. the other goes to ignition. then just the speaker wires and a ground.
Jul 31, 2009 | Car Audio & Video
No power to stereo.
use wiring diagram back of stereo. check 12volts supply by multitester dc.
May 30, 2009 | Kenwood KDC-5011 CD Player
Diagram on what wires go were for 2003 chevy cavalier / gm radio interface to sony xplode cd player
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Apr 29, 2009 | Car Audio & Video
Problem with aftermarket stereo wireing
seriously the answer is very easy the yellow wire from the deck is constant power weather the truck is on or off it should always be hot. The red is the ignition wire which simply turns the deck on when the ignition key is turned on and the black is ground besides the actual speaker wires these are the only wires that need to be connected. if they are properly connect there is a good chance that there is a short somewhere
Mar 16, 2009 | 2006 Ford F-150
Stereo wireing
go to advanced auto parts and buy a connector for your car. just go and give them year, model and make and when you get it connect the same color wires from the stereo to the stereo harness. all of the colors are the same.
Jan 07, 2009 | 1998 Oldsmobile Intrigue
Car Audio & Video Logo
43 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
