Question about Philips DVP5140 DVD Player
Help dvd isn't tuned into the t.v i think?
When dvd is playing the screen on the tv will roll occasionally, and go light and dark
    President:
  • 173 Answers
Try checking your dvd cable connections. Disconnect all of them and check for defects such as bent ends, frayed cable, cuts and sharp kinks in the cables, loose AV ports on the back of tv and dvd. I would even replace the cables. Try wiggling the cables up and down, side to side while they are plugged in to see if it has any effect on the picture quality, but remember to wiggle them gently. Hope this helps and let me know if it doesn't.
Posted on Jul 04, 2008
Vizio E480i-b2 LED TV loosing picture and sometimes shutting off
I don't think you had backlight issues like you thought you did as the set should have shut down the backlights totally as soon as it sensed over voltage or over current, I'd try a new main board and see if that fixes things up for you
Dec 09, 2017 | Vizio Televison & Video
Tv screen rolling vertically when trying to use my DVD player
that's a synch issue..is the cable tightly installed? do you need to have that on another channel, by chance?
Apr 28, 2008 | Apex Digital AD-1110W DVD Player
How do I connect an external DVD/VHS player to an old Coby Cx-Tv1 television with no RCA cable?
It should have also an Audio in jack . Take a photo of it and go to some radio/tv parts shop for a converter. They know
May 17, 2015 | Coby CX-TV1 5 in. Portable Television
My Vizio LCD TV screen fades to dark. Sound stays on.
I w having this same issue when watching a Blu-Ray disc. I found it to be dependent upon what picture mode the TV was set to. By this I mean certain picture modes would cause the TV to dim during dark scenes of a movie. Changing the picture mode helped a lot.
Feb 28, 2010 | Vizio VW42LF 42 in. LCD HDTV
Dark picture on RCA Scenium 61 in DLP
Yes, the lamp will gradually get darker as it nears it's end. The rolling lines sounds more like the set is on a local channel for the cable hook up. If your local area has a channel 3 or 4 live terestrial broadcast simply tune the cable box output to the other one, the same for the tv.
If this is cable/local broadcast issue it will go away in Febuary when the NTSC broadcast ends.
Jan 15, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Lightning mcqueen tv and dvd set-up, won't play, have direct tv hook-up
i guess there a built in dvd player on the set and it could play most DVD format.
but if you wish to use another dvd player
hook up the dvd on the tv
video output (DVD) to video input (TV)
audio output to audio input
the find the auxiliary button from either the tv or dvd
Oct 30, 2008 | Disney DTD1363-CAR 13" TV/DVD
Panasonic PV-7451 VHS
I don't recognize your first problem.  The "light to dark" issue I believe is intentionally engineered (mine does it too); it prevents recording DVDs on to tape.  Try running the DVD player directly to the TV.  Radio Shack used to have a box that would correct this issue too, you might check there.
T. R.
May 18, 2008 | Panasonic PV-7451 VHS VCR
Samsung HT-X70 DVD player
i have this system set up to a sony bravia kdl40v2500 tv and sometimes when playing a dvd the screen will go blank and in the corner 1080i will show. I do not know how to change the resolution and does this need to be done on dvd player or tv. Can you help me.
Thanks
Tom
Feb 20, 2008 | Cell Phones
Screen goes light and dark
sounds like you have bad caps in video area. Will need repair by experience tech.
Sep 07, 2007 | Sony KP-46WT500 46" Rear Projection...
Philips DVP5140 DVD Player Logo
29 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
