Computers & Internet Logo
Posted on Jul 04, 2008
How to upload files
Dear Experts,
I currently trying to use the FileUpload control from asp to upload
files. The uploading of the file I would like to store it in the Access
Database. Unfortunately, I've no idea how I can do that. Can anyone provide
me some solution by writing the code in asp?
Many thanks in advance
A
Anonymous
How can i change explore page
Uploading files
More information needed. Where are you trying to upload to, what files etc.
2answers
Can't upload music on my t-sonik 840
MP3 players can only play music files in mp3 file format. You can download mp3 music files from the Internet to your computer and then copy them to your MP3 player using the USB cable. For your CD collection, you need to convert your CDs to mp3 music files onto your computer or download them from the Internet and then copy them to your MP3 player after you have connected the USB cable to the MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player will create a MP3 music file for each music track. Click on this link for instruction on converting music files to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
So im trying to upload this video i made to facebook and everything i try they say Sorry, that's not a video file that we support. We currently only support the following extensions: and they list a lot of...
you need to change the file extension so you can successfully upload it to facebook, right click the file and click rename, then enter the name of the filefollowed by a dot extension name, like .pdf .doc .jpeg .gif etc change the dot extension of the file to the ones supported by facebook
7helpful
NO MAPS
Follow these steps to fix the “UNIT CURRENTLY CONTAINS NO MAP! INITIATING MAP” ERROR.
Step 1: Download the firmware update for your Sportrak model from:
Magellan GPS. Extract the zip file to your desktop.
Step 2: Download the base map file, NA_B101.IMG. This one is hard to find but you might look
on the following yahoo group page for the file: m330 : The Map 330 Club . Look in their FILES folder for the file called, NA_B101.zip. You may have to join this group to gain access to this folder. Download the file and extract it to your desktop.
Step 3: Now that you have the files necessary to fix your unit, follow these step exactly to upload the base map file.
  1. Turn off the unit and connect it to your computer using the Magellan serial cable. If your computer does not have a serial port you can buy a, SERIAL to USB adaptor.
  2. Now simultaneously press and hold that button the looks like the world and the button with the man on it (GOTO button). While holding these buttons, press and release the power button. Two zeros will appear in the middle of the screen like this, 00. Using the central joystick, change the zeros to the number, 98. The press the enter button once.
  3. Go to the folder where you extracted the firmware update you downloaded first and look for the Magup.exe file and double click it to launch the Thales Navigation Firmware Uploader. Click NO on the UPLOAD pop up window. Now Click on EXPERT from the menu bar. The EXPERT SETUP window appears. On the EXPERT SETUP window choose your GPS model. Then choose the com port your GPS is connected to. Now check the box next to the word ON under EXPERT UPLOAD. Then click OK.
  4. [i]Note: If you do not know what your serial com port is, here is a way to find out. Click on START, and then on CONTROL PANEL. In the CONTROL PANEL, scroll down and double click on SYSTEM. Then click on DEVICE MANAGER. In the DEVICE MANAGER, look for PORTS (COM & LPT) and click in the + symbol to the left to expand the category. You should see your serial listed here and the com port it is on will be listed to next to it.
  5. On the Menu bar click on UPLOAD. Click OK on the reminder pop up window. On the SELECT UPLOAD TYPE window check the box next to BASE MAP ONLY. The SELECT BASE MAP FILE window appears. In this window Navigate to the folder on your desktop where the, NA_B101.IMG file is located (you should have already extracted it here earlier if you are following all the steps.) Select the NA_B101.IMG file and click OPEN. The window closes and the UPLOAD FILE window appears. Click on the box next to UPLOAD and the upload process begins automatically. The process may take several minutes. Once it is done, restart your unit and you are on your way.
Since you now have downloaded the latest firmware and your unit is now functioning properly, you might as well update your firmware if it needs it. Follow the instruction found on the page where you downloaded the firmware update for your unit in step one.cool.gif
1helpful
2answers
YouTube Problem Uploading
Did you try the YouTube Uploader? you'll first need to install it on a Windows computer. To do so, follow the steps below:
  1. Sign in and click the "Upload" link in the upper right corner of any YouTube page.
  2. On the right side of the page, click the "Use multi-video uploader" button.
  3. You'll immediately receive the following message: "YouTube Uploader app not running - you will be redirected to the install page."
  4. Click "OK."
  5. Click the "Install Windows Uploader" link.
  6. You'll be asked if you want to save the "YouTubeUploaderSetup.exe" file. Click the "Save File" button and specify where you'd like the file to be saved.
  7. Open the file once it's been saved to your computer and it will install the Uploader.
Once you've installed the Uploader, you'll be redirected to the Multi-Video Upload page.
Uploads
I believe the upload size parameters will have to be changed at the server end of the site you are trying to upload to. All the problems that I've dealt with in this area have been with trying to upload a file that exceeds the maximum upload size preset by the site, not under the size. I hate to say it, but I'm a bit stumped here. I'm going to recommend you ask Ekse. Ekse is another of our experts here at Fixya, and he is very good as well. He may have dealt with this more than I have, so, on Fixya's home page you will find Ekse in the top experts section. Go through his profile, tell him exactly what you have told me, and see if he can get you through this. I'm sorry that I am unable to help, I don't get stumped often, but I believe Ekse wi be able to help. You can tell him I referred you, so if he would like to get with me to share ideas, that would be fine. Again, I apologize.
Can't upload website to freewebs.com
make sure you create a directory in your Public Html file and upload to that. Try Filezilla. Try to contact your provider.
Try digitalcityhosting.com, i have 5 websites hosted from them and they are real dotcoms, not subdomains and I only pay $9.95 per year for unlimited use. Unbelievable. i am not a shill for them, I just love the deal.
Grand Canyon Tech
Grand Canyon Tech
