HDMI not working
I had some work done on my house and had the cables channel into the wall, so that the wires were hidden. the scart lead for the Sky and the HDMI for the sourround sound DVD, Well the HDMI lead was not long enough so i purchased a SLX 2 way gold home selector, fitted it all together and it does not work, can you help me please?
Rob.
  • lucia78 Jul 04, 2008
    The TV is a new hd Samsung with the red border, connected by a HDMI gold lead, connect to the 2 way SLX gold home selector into the Samsung HT-Z310 Digital home system.
    Genius:
  • 1,673 Answers
It is possible that one or more cables were damaged or are defective. You will will have to test everything with an independent set of cables, and substitute to find the defective ones. This also included testing the selector box.
Jerry G.
Posted on Jul 05, 2008
Connect hdmi goodmans tv
Forgive on this one but I do not have a soundbar but wonder if it has any other connections like phono for input as to me hdmi would be a strange choice. Hdmi leads are mostly alike in they are fully wired and carry a wire which directs a device to listen to it when turned on, also some hdmi sockets (like the old scart) are blessed with options.
Some may be input only while others set for in and out so it may be worth swapping connections on your TV to see if this changes the habit, though for me I would look to see if this soundbar has other sockets to use like phono (same with your TV if it has phono or scart socket options). Your TV instructions may show their ideal connection setup, otherwise you will have to shutdown your other item to stop it commanding the TV to switch through its sound. This "problem" is an old one with people using scart leads then I used to cut pin 8 (its control wire handing the descision to a user) but this new lead combo I do not know.
Hope this helps.........
Aug 29, 2017 | Samsung LN32A330 32 in. LCD TV
How to connect Sky digibox & DVD recorder to Samsung UE46ES6300 TV
Buy 2 hdmi leads and use one to connect sky TV decoder to the hdmi 1 socket on the back of the TV and if your DVd recorder has an hdmi socket attach it to hdmi 2 or leave it on the scart socket
as you don't name your dvd recorder the connections available are unknown
hdmi is the best followed by component which requires a 3 cable lead 3 video (video is red green blue plugs ) audio is red and white which is a 2 wire lead which all are needed to get video and audio to your TV
scart is the lowest quality along with composite video
Jul 04, 2017 | Televison & Video
I have skyhd connected to Lght-805sh via optical connection but when i turn sky over from a hd channel to normal channel there is no sound
Not sure what you mean by "optical connection" but you need to connect your SkyHD box to your TV using both HDMI and SCART cables. Your Sky HD box will then send the signal via the HDMI cable for the HD channels and the SCART cable for the SD channels.
Hope this helps
BElectric
Nov 06, 2010 | LG Televison & Video
I need a wiring diagram to connect a samsung tv, sky+HD, DVD recorder, Wii and Playstation 3...thnx
all you have to remember is out of one into the other IF got Ariela on house that goes into sky then out of sky in to DVD recorder and out of that and into tv
on back of sky hd if you are going to use HDMI cable put cable into sky box and other end into tv ( you will have ot put tv on HDMI input/source)
or use scart lead in stead
THIS DEPENDS ON HOW YOU WANT TO CONNECT PLAYSTATION
everything else is colour coded
Nov 08, 2009 | Samsung 37" 720p Flat-Panel LCD HDTV
How do i set up my plasma tv just to watch sky on the tv i was given a tv pioneer pdp-42mve1 and have got the power lead and a lead with a scart and 6 push in leads coluers are green blue blackyellow red...
Hello Paul,
all you need to do is plug the power in, put the scart lead into the back of your Pioneer tv, the other end of your scart into the bottom scart of your sky box named TV.
you will also need to connect the sky cable to the box to receive your signal. its a F type connector ie it screws on.
The other cable you have with the 6 push in coloured leads they are Component cable and the red and white ones are Audio cables. You will not need these cable unless your sky box is a HD box then i would suggest you get a HDMI cable instead of using component (less cables showing) dont be fooled into buying gold plated HDMI cables as they do not make any difference to the picture Quality as the back of the sky box is alley and so is the telly. So please dont waste your money on that type of cable.
Hope this Helps
Little Dish Fitter.
Sep 02, 2009 | Fujitsu Plasmavision PDS-4222 42 in....
HDMI conneection wont override tv picture
I am a sky engineer (not a subby)
the reason this does not come on straight away is because a Scart lead send power upto your telly when it is turned on. Telling the telly that this is what you want.
Unfortunately HDMI does not send power upto the telly. There are ways around this. ON Samsung, Panasonic and Lg tellys you can go into a secret menu and apply something called HOTEL MODE this allows you to change the av input so it would automatically come on your hdmi 1,2,3, etc
In your case follow my instructions below
go to the hdmi you are using for your Hd
on the sky remote
Press SELECT and GREEN until LED flashes twice.
Press HELP then SELECT and the LED will flash Twice. what this mean is when you press your Sky button, tv guide, services or interactive button to turn the sky on this will automatically change your av/source on your telly to the sky HD for you
You owe me a pint
Have a good one
Little Dish Fitter
Jul 19, 2009 | Microsoft Xbox 360 Console
Equipment and Locations (Denons are physically 15ft apart) Room 1 Sky Plus Satellite Digibox; (without HDMI outlet), but with one optical, one scart-video, and two Scart outlets. Panasonic DMR-EX77EB DVD...
Hi Martin,
A wiring Schematic is not that you should be looking. What you need is large feeders to understand hot to connect to various ports to give your desired output.
Jul 03, 2009 | Denon Audio Players & Recorders
No sound through ps3 hdmi
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
Oct 19, 2008 | Televison & Video
87 people viewed this question
 Grubhead
Grubhead
