Question about Vacuums
I have a Hoover steamvac that will not spray or pick up water. Earlier it worked fine, but stopped.... I ensured it was assembled correctly and checked the filter in the lid to ensure there was no debris....what more can I do??
  • Anonymous Mar 25, 2009
    Wont spray or steam. only clicking noise
I re-checked all my steps, the lid looked like it was on securely, but wasn't. I re-attached the lid correctly and had no further problems.
Posted on Jul 05, 2008
My Hoover Steamvac won't suck. I checked the front door thing on the dirty water tank and found a crack where the bottom of the door meets the tank. Would this stop it from working?
From your description, this would certainly need to be corrected, and yes may be the problem. Also, check the recovery tank lid to make sure that is on and latched properly. Ensure the round tube that is under the recovery tank has the gasket seal installed.
Sep 26, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac LS F5899-910
Did you try to clean first the unit..
Jun 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
My Hoover Steamvac Widepath will NOT pickup the water after dispensing. I checked the hose inside the cleaner, there was a cut in the hose so I put electrical tape and completely sealed the cut. Still...
Hi, empty the recovery tank of the Hoover SteamVac if the cleaner fails to pick up dirt. Once the tank is full, many Hoover models have an automatic shutoff that stops the cleaner. If the does not resolve the pickup issue, check the hose of the machine and remove any blockage.
Examine the water tank if water does not dispense from the SteamVac. It could be empty and need of a refill, or you may not have locked the dispenser firmly in place. The detergent tank should also be looked at and filled if empty.
Take care
Apr 12, 2010 | Hoover F6213-900 SteamVac Agility...
My steamvac will spray out water
Assure the ring gasket is in place under the hood. A round rubber gasket must be in place on the round tube under the hood where the recovery tank sits to connect the vacuum from the motor to the round tube on the bottom of the tank.
Sep 20, 2009 | Hoover SteamVac F5914-900 SpinScrub...
My hoover steamvac turbopower 5000ls will not spray for hand tool
my turbo 5200 will not pick up the moister into container to dry does anyone know what the problem may be
Sep 12, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steamvac not picking up water
you don't have the recovery tank lid on correctly.
Jul 19, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Carpet cleaner pick up water
water outlet are pluged soap residue seal broken or miss alined
Apr 05, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
I have a hoover steamvac dual v and is leaking, bristels not working very food only two are speaning and is not sucking any water Very little solution comes out, or comes out in streaks when pressing the...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=41020&thid=634728
I have a Hoover SteamVac
Posted by albazo on May 30, 2008
I have a Hoover SteamVac Dual V and it is leaking, bristles not working very well and only two are spinning and is not sucking any water
Very little solution comes out, or comes out in streaks when pressing the solution dispenser button on the handle. I think the lines may be stopped upped.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover F5866-900 SteamVac Deluxe Wet/Dry. You probably have a couple of brushes that are broken – the brushes are and assembly unit and would have to replace the entire brush assembly, and you are correct that the suction part of the vacuum is probably plugged up. You can take a wire hanger and use that to try to clear the clogged opening, but to be honest you may have to disassemble the vacuum and clean it entirely and replace the brush assm and any type of belt if needed. Pleas, feel free to check with your local vac dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 30, 2008 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Steam vac will not pick up dirty water
My Hoover Steamvac problem isn't with the bruches--it's with the suction. Dirty soapy water stays in the carpet instead of being returned to one of the holding tanks.
Oct 21, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Steamvac quit spraying
Check the seal that the clean water tank sits on, may have come loose. The filter inside the dirty water tank has been pushed up too far, needs to have a 1/4 in. gap from the top to the top of the filter.
Sep 12, 2007 | Hoover F7431-900 SteamVac Vacuum
Vacuums Logo
47 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
