Question about HP Office Equipment & Supplies
Manual was accidently destroyed and I need to change a ink cartridge
    President:
  • 1,113 Answers
Hi - Please give the model number of the printer.
Thanks.
Posted on Jul 04, 2008
Kodak esp 9 printer is out of black ink, meanwhile all i want it to do is scan a paper and it wont do anything without new ink. The computer says the printer is busy, and the printer just says "error...
This is a common problem encountered by printer users and is in fact not a bug but considered a feature by manufacturers who build this function into printers to encourage consumers to buy their expensive ink cartridges. To fix this problem I would buy a 3rd party ink cartridge for use when your ink cartridge is empty. This way you can use your scanner when out of ink (be careful printing with 3rd party ink cartridges, many have mangled or destroyed their printers by using non OEM ink).
Feb 28, 2011 | Office Equipment & Supplies
Don't know how to change the ink cartlige
Hi
thank you for your query
Make sure the printer is on but not printing. Raise the printer cover, then press down the Maintenance button for six seconds until the print heads move to the center. Pull up the empty ink cartridge clamp all the way. The cartridge rises up from its holder and should be disposed. Unwrap the ink cartridges and remove ONLY the yellow tape seal from the black and color ink cartridge. If you accidently remove anything but the yellow seal you cannot use the cartridge or it will damage the printer. To install the new cartridge, tilt the ink cartridge forward slightly as you lower it into its holder. Hang the tabs at the back of the cartridge on the hooks on the holder clamps. Don't place the cartridge tabs under the hooks on the holder clamp; you may damage the clamp when you close it. Install the ink cartridge and press the Maintenance button to begin charging the ink delivery system. Charging takes about a minute and is complete when the power light stops flashing and the error light goes out
Sep 24, 2010 | Epson Stylus C40UX InkJet Printer
How to change ink
  1. lift the printer cover,
  2. Press the Maintenance button for about 6 secs - the print heads will now move to the center of the printer.
  3. Pull up the clamp all the way for the empty cartridge. The cartridge now lifts up from its holder, remove the cartridge.
  4. The New cartiridge ONLY remove the yellow tape seal from the the black and/or the colour cartridge. Note: If you accidently remove anything but the yellow seal you cannot use the cartridge or it will damage the printer.
  5. Install the new cartridge, tilt the ink cartridge forward slightly as you lower it into its holder. Hang the tabs at the back of the cartridge on the hooks on the holder clamps. Don't place the cartridge tabs under the hooks on the holder clamp; you may damage the clamp when you close it.
  6. Install the ink cartridge and press the Maintenance button this will purge the ink. This takes approx 1min and is complete when the power light stops flashing and the error light goes out.
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 31, 2010 | Epson Stylus C40UX InkJet Printer
Its showing error while the ink light was blinking, but I just refilled the inks
try cleaning the contacts with a wet towel
if thats not working
change the fault cartridge
for better refill in order not to destroy cartridges
try removing air as in this video
http://inkfilling.net/instructions-on-how-to-refill-hp-21-c9351a.html
Jan 08, 2010 | HP DeskJet F380 All-In-One Printer
I cant find the manual to canon pixma mp150.
Hi Irene
You solve the problem by replacing the empty ink cartridge.
Most printers (not just Canon) are designed to stop working if an ink cartridge is empty. This is to prevent the nozzles for the empty colour overheating and destroying themselves - the ink passing through acts as the coolant.
Dec 11, 2009 | Canon PIXMA MP150 All-In-One InkJet...
How do I extract the ink cartridge from the printer?
Make sure the printer is on but not printing. Raise the printer cover, then press down the Maintenance button for six seconds until the print heads move to the center. Pull up the empty ink cartridge clamp all the way. The cartridge rises up from its holder and should be disposed. Unwrap the ink cartridges and remove ONLY the yellow tape seal from the black and color ink cartridge. If you accidently remove anything but the yellow seal you cannot use the cartridge or it will damage the printer. To install the new cartridge, tilt the ink cartridge forward slightly as you lower it into its holder. Hang the tabs at the back of the cartridge on the hooks on the holder clamps. Don't place the cartridge tabs under the hooks on the holder clamp; you may damage the clamp when you close it. Install the ink cartridge and press the Maintenance button to begin charging the ink delivery system. Charging takes about a minute and is complete when the power light stops flashing and the error light goes out. For more information on installing an ink cartridge please refer to your Start Here Poster or your Printer Basics Manual.
Nov 15, 2009 | Epson Stylus C40UX InkJet Printer
Installing a new ink cartridge
After working with the copier for over an hour, my husbband discovered quite by accident where the ink cartridge was located. It is inside on the left hand side, above the try that holds paper, and is next to impossible to see. It pulls out to the middle of the tray, and the cartridge can then be changed. Thank you so much for you time.
Sincerely,
Becky LaCour
Mar 03, 2008 | HP OfficeJet D135 All-In-One InkJet...
Dell 725 printer no manual need to change ink cartridge
Here is the manual
http://support.dell.com/support/edocs/systems/725/en/index.htm
Replacing an Ink Cartridge
  1. Turn on your printer.
  2. Lift the front cover.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Close the front cover.
Feb 09, 2008 | Dell 725 InkJet Printer
Changing cartridges
Did you get the answer for how to replace the ink cartridge, because I don't have a manual myself and I can't even figure out where the ink cartridge is located?
Dec 11, 2007 | Office Equipment & Supplies
13 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
