Question about Motorola Mobility RAZR V3
Phone dying Not recharging. Tried putting in old battery that shop had on hand as have been told can't get another battery. This also did not work.
  • 983 Answers
I think there is some problem in the charging port just open the handset(if you are good in opening) check whether is there any loose contact near by the charger port .....
if so just remove it and readjust it again ...
this solves your problem ...
if you are not good in opening the handset then just visit the technician ....
it is just a matter of some bucks....
& also try charging with other charger there may be some problem in the charger...
any doubts reply me
i am always here to assist you
thank you
bye
Posted on Jul 04, 2008
My shaver turn off immediately after it turn on
How old is the shaver? What model is it? How handy are you? It is possible the battery is dead. As with most electric shavers they try to tell us the battery is not replaceable, but if we take it apart the battery has either a model number or specifications on the side we can hunt down and purchase.
Even if you can't find the exact same model, make sure the specs are the same as the ones on the original battery and it's the same size roughly. Then it's only a matter of re-connecting the new battery in place of the old and away you go.
Popular sources for unconventional internal battery replacement is places like eBay, or if you want local, try an electronics store. If you can't find the exact battery as a replacement, you can use any as long as the chemistry, and battery specifications are the same you shouldn't have a problem.
My portable hand crank radio (for camping and power outages) had an internal NiMh battery pack which died after a few years of lack of use. Buying a new one from the manufacturer was a ridiculous price. Simply matching the specs and size I found a similar battery for a wireless home phone and used it instead. It works great and it cost a lot less than buying original.
My cordless Shark 14.4v hand vac rechargeable battery died, and there was no replacement battery. Taking it apart I discovered how the 14.4v internal battery was composed of. Several (12) 1.2v cells linked in series. So I simply bought 1.2v cells and linked them myself and put them back into the hand vac. Works great now.
Aug 30, 2015 | Health & Beauty
Radio shack walkie talkie 21-1914 replaced batteries will not charge
Hi pearl,
A simple problem to solve at last!!!
Inside the battery compartment you should find a switch, which indicates Recharge/Normal, make sure you select recharge if your using these batteries, otherwise no charging occurs.
If this does not work, take out the recharchables and select normal on switch, place fully charged normal batteries into the compartment, making sure you put them in the right way around, close the flap and turn on the radio, if this works, then your battery switch is faulty, however, you can get lithium ion batteries, which will last longer than most other high duty batteries.
The cost of getting these radios is not worth the money, unless you are technically minded and buy the repacement switch and repair it yourself.
Otherwise try all of the above, and remember, when charging batteries that are rechargeable, never leave the radio on, as this can wear out your batteries quickly.
I hope this advice is helpful to you.
Best regards,
Peter
Jan 12, 2013 | Radio Communications
Phone shows samsung logo and then goes blank
did you get your phone wet? same thing used to happen to my samsung prevail when i accidentally dropped it in a bucket full of water, after maybe 3 days of it doing that (showing logo, then black screen) it finally died, i put a brand new and charged battery but it didn't work, my friend who works for sprint, told me smart phones sometimes "burn out" meaning they overheat and eventually give out... I just bought me a new one when he told me that, cause I did use it alot and it did tend to overheat. Check your battery for any leakage, for some reason mine was...
Aug 17, 2012 | Samsung Focus i917 (8 GB) Smartphone
So i was walking outside and then it suddenly started raining and i tried to cover my nokia n97 but it got a bit of rain on it. I ran back to my house with my phone in my hand. It worked until the battery...
hi have you tried other battery? if not, kindly replaced it. if yes, pls bring it to service technician to open it i guest inside board is wet due to rain, they will used hot air blower to dry it. thanks
May 09, 2011 | Nokia N97 Cell Phone
My samsung batteries keep dying. I just put new
Hello :
Try to clean the base where the batteries set . Maybe the base became rusty or got some isolation stuff on it . If that didn't help , then there must be a problem with the main PCB [ printed circuit board ] . For that you need to take your CAM to a repair shop .
good luck .
please don't forget to rate !
Apr 05, 2010 | Samsung Digimax S630 Digital Camera
Cordless Battery-Powered Soldering Iron wont turn on anymore
You can replace the battery with other new batteries, that way, you can tell whether it is the rechargeable batteries or the iron that are faulty.
Mar 09, 2010 | Weller BP860MP Dual Heat Battery Powered...
Samsung u900 limited service
Is the battery fully charged now???
Limited service, is when your not getting any reception, Samsungs usually always get low reception or no reception at all if the battery is low or dying... Remove the sim card, reinsert it into the handset, charge the phone and try again...
If it still doesnt work and the sim card does work in other handsets, its still covered under the Samsung warranty if its less than 12 months old.
May 14, 2009 | Samsung U900 Soul Cellular Phone
My cell phone battery died. When I went to
This is not a regular thing. Maybe if you buy a new battery that might work.
May 09, 2009 | Samsung Highnote Cell Phone
DEAD 12 MONTH OLD KATANYA PHONE
how did it die? was it put in water? did it get smashed hard? did the battery die?
Oct 01, 2008 | Sanyo Katana SCP-6600 Cellular Phone
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
