Question about Dryers
No heat Estate Dryer model # TGDL400WW1
I have an Estate Dryer which was ion storage for several years. Its like new. I hooked it up to the gas line and it operates fine except there is no heat being generated. It has a tab on the front which says pilotless.
  • 525 Answers
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
http://www.repairclinic.com/0088_8_1.asp#Level1_14
If your dryer doesn't heat, check these:
Temp. Switch, make sure a positive selection is made.
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 04, 2008
Estate TGDS840JQ1 Gas Dryer NOT HEATING
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 20, 2010 | Estate TGDS840JQ Gas Dryer
Runs but no heat has good gas flow to dryer will not heat and makes a humming sound during what should be the heating cycle
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace. Here is a video at this will walk you thru the troubleshooting a gas dryer. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Sep 20, 2010 | Estate TGDX640JQ Gas Dryer
Whrilpool estate dryer model egd4400sqo not heating up
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 20, 2010 | Estate EGD4400SQ Gas Dryer
Estate TGDS740PQ0 gas dryer not heating and timer not advancing but still runs
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace.There is a video at t http://appliancehelponline.com/gdryertroublevideo.html his will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Jun 12, 2010 | Estate TGDS740JQ Gas Dryer
No heat gas smell
heatman101
Mar 08, 2010 | Estate EGD4400SQ Gas Dryer
I have a Maytag dryer that has been moved several times and been in storage for about 7 years. We hooked it up yesterday and the ignitor won't come on. It is an older model LDG7500AAL from 1991. Where...
The ignitor on a gas dryer is very sensitive. rough handeling (moving) usually will dammage it. Clean the underside of the machine inside with a vaccum. Check if the ingitor is glowing when on and in a heat setting? if not replace. The burner has a flame sensor that looks like a small window in the burner housing be sure it is clean as well. CLEAN unit first then trouble shoot.
Sep 20, 2009 | Dryers
Kenmore 80 series Gas Dryer
HI. you are correct. this dryer, although gas, is using a Glow igniter system. most older models used the snap igniter that clicks over and over to spark the burner but, this dryer is only 2 years old so, it should be outfitted with a glow igniter system. This igniter is powered by electricity.
It works in conjunction with a Flame sensor.
Jun 02, 2009 | Kenmore Dryers
Does not dry completely
how well did you clean that duct, the duct is problem 90% of the time when the dryer does everything else, pretty much if the dryer heats and tumbles its doing its job
May 04, 2009 | Dryers
Whirlpool Estate Dryer barely heating
Four wires on the new cord.
Red and Black go to outside screws on the terminal.
White goes to the middle terminal.
Green goes to the cabinet ground screw near the terminal plate cover.
Mar 11, 2009 | Whirlpool GEW9250 Electric Dryer
Estate drye by Whirlpool
The number one cause of insufficient heat problems with dryers is poor air flow. The first thing you need to do BEFORE assuming you have any defective components is to do a full inspection of the dyer to ensure it is not clogged anywhere. The easiest way to determine if you have a dryer clog is to leave the vent hose removed from the back of the dryer and attempt to dry a load. The air flow leaving the dryer should be forceful and about 140 degrees F. If the air flow is weak, you more than likely have a clog in the air blower assembly INTERNAL to your dryer. If the air flow is normal and warm as it is should be, you may have a clog in the vent ducting EXTERNAL to the dryer. This would be from where the ducting leaves the dryer to where it exits your home. If you have a vent line that runs through and attic or crawl space, they are notorious for clogging. If you haven't had the ducting cleaned or inspected recently, now would be a good time. You should also be using the semi-rigid (metal type) ducting. It resists crushing, kinking, is heat resistant, and resists rodents chewing through it. Another concern I have is that you mentioned the dryer was in storage. It is common for rodents to build nests inside the blower fan housing area and clog the dryer. Since you mentioned your dryer is getting warm, but not drying like it should, tells me the heating element is working. You may be right and you could have an operating thermostat that is failing and not allowing the heating element to stay on long enough to heat properly. However, I would recommend you inspect the dryer thoroughly first to rule out poor ventilation. The following link expains some of what I've mentioned in greater detail:
http://www.fixya.com/support/r385301-thorough_dryer_advice
I hope you find this information helpful. Let me know if you require further assistance.
Nov 18, 2008 | Estate TEDS840JQ Electric Dryer
Dryers Logo
104 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
