Question about Nokia 5200 Cellular Phone
Nokia 6085 has a blue screen
I have a nokia 6085 and it works great exept yesterday the screen went blue and the display screen on front works and everything works fine its just my screen and i can read mesages or write them or call people or anything because i cant see what i am doing. please does anyone know how to fix this?? Nokia 6085 Cellular Phone
Nokia 6085 Flap handset working properley but screen is blue unloack solution
  • 7 more comments
  • church man Jul 15, 2008
    Yea I have the same problem
    I need to get it fixed or I have to buy a new phone because my cellphone is my life line
  • Anonymous Aug 07, 2008
    blue screen
  • Anonymous Nov 07, 2008
    I have same problem problem & warrenty period is expired !
    I opened mini display body & found flexacable has got some problem !
    either it is crunching in the way while flap is being closed or opened !
  • Anonymous Jan 19, 2009
    this is buttholish
  • stormygirl92 Feb 08, 2009
    yea mine worked fine the mornin before i was even tlkin to my boyfriend.... but i did drop it when i was on the phone, but it still worked fine and everything. Then the next mornin i woke up and grabbed my phone to see what time it was and it was just a blue screen, so i took it apart and tried shutting it off and turnin it back on and nothing worked. I still can make phone calls though and still do stuff on there i just cant see b/c of the blue screen.
  • Anonymous Feb 26, 2009
    i called my phone to make sure the ringer was working. it was still on the charger. i hung up the other phone then i picked my my nokia 6085 and it was on a normal screen of 1/2 a second then went blue. it'll turn off and on the screen will just be blue. i can't even do anything with my phone (call etc) like y'all can! and on a personal note: i'm going on a trip tomorrow morning, i need my phone, and i cant exactally make a stop at the at&t store!
  • Anonymous Apr 11, 2009
    same problem, my nokia 6085's screen wont work, is just a blue screen, I still use it because I memorized my phonebook, but I cant see !#$%. please if anyone knows about this help me out
  • Anonymous Apr 25, 2009
    my nokia 6085 had a solid blue screen
  • PlantedRug Apr 30, 2009
    I've got the same problem its annoying as hell.
    Sniper:
  • 57 Answers
I have repaired this problem time after time you need to replace the flexcable which is located inside the phone between the top and bottom of the phone the problem is that these phones are very poorly made and the cable inside gets crunched up with opening and shuting of the phone its very easy to replace and change and with ebay you can find the cable for around 4 pounds inc postage if you need help opening the phone please email d12_eminem_cent@hotmail.com i have had around 10 of these phones to fix and only 1 out of the 10 the screen needed replacing change the cable first its cheapest option! hope this helps all!
Posted on Feb 03, 2009
    Brigadier General:
  • 7,752 Answers
You need to have the LCD or flexcable replaced on the phone
Posted on Jul 07, 2008
I just had the same problem, when though tech support and they said it may be a manufacture problem. If your phone is still under warranty(i believe its a year) talk to your service provider about having them fix it. They are fixing mine for free, under the warranty.
Good Luck!
Posted on Jul 09, 2008
2 Suggested Answers
Bajanguru
  • 7752 Answers
SOURCE: nokia 6085 has a blue screen
take the phone to a mobile service center and have the LCD replaced on the phone.
My nokia 6085 main and mini display went blue and won't show me anything but I can still call people if I remember their number
I had the same problem and mine was 2 months over the year warranty. I took the outer screen casing off and slightly tapped the connector that connects the screen to the keypad. Voila! I had a screen and now I can at least move my info. The top of casing on the screen pops off near the hinge (there should be a notch). Do this gently and lightly move the black connector on the right side as you're facing the hinge. It may buy you a little more time. We'll see how mine does.
Jun 03, 2009 | Nokia 6085 Cellular Phone
Blue screen on main display
its a hardware problem, its FPC cable is tampered plz get it replaced by Nokia Care or call me at 99999-16148 India
You most likely need a new ribbon cable, which is the cable that connects the two halves of the phone. They are not expensive and can be ordered on eBay, and they come with the tools required to disassemble the phone and replace the cable.
Jun 01, 2009 | Nokia 6085 Cellular Phone
Hi. this reoccurring error is due to programing and hardware failure. you will need to remove the battery for 5 minute. if the error continues after you re insert the battery, this will confirm this fault in the hardware. your phone will require repair in this case.
May 22, 2009 | Nokia 6085 Cellular Phone
try to replace flex,,, if no luck replace also crystal ic beside the connector....
Feb 06, 2009 | Nokia 6085 Cellular Phone
Jul 02, 2008 | Nokia 5200 Cellular Phone
The problem is in connector. You need to change that.
May 26, 2008 | Nokia 6080 Cellular Phone
I have the same problem with my Nokia 6085 phone. was working fine and then it started glitching after a month the glitching display went blue. after 3 days it started working again but I had to power it off and on again and when I did that my display was gone again. I cant text. I know my phone and where everything is so I tryed to send a text but it will not work but I can make and get calls.
Mar 30, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Nokia 5200 Cellular Phone Logo
5,703 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
