Most refrigerators with a water dispenser have a reservoir (tank) to chill the water before it gets to the dispenser. This tank is typically behind the crisper bins so the water should be the same temperature as the refrigerator. The water may start out room temperature but should be cold by the time you have filled 1/2 a glass or so.
Saying all that, there are a few newer models out there that have reduced the cost of the refrigerator by eliminating the reservoir. If you take the crisper drawers out and look behind them and do not see a tank or coil of tubing then you do not have chilled water.
Hi, yes the water line could be starting to ice up; maybe defrosting the fridge will cure the problem.
Mine has a coiled tube behind the lower drawer in the fridge, this is where the water line is chilled.
Hope this helps if you've not sorted the problem already. Kind regards jb
I have a whirlpool side by side. water and ice in front. ice working and water not. the hose is not frozen and it is not humming when you push the water dispenser. It would give us water and quit but now we have nothing.
Hi, Only thing you can do is check the temperature in the fresh food section and it should read 34-27 degrees. The temperature controls should both be set at half of the #'s on the dial. I hope this helps you. Please let me know if I can assist you further.
Hello pryorjonw. You may need a new dual water valve, because the part going to the icemaker may be bad, the ice sensing arm may be in the up/off position, the ice bucket may not be positioned properly not triggering the icebucket sensing switch, the condenser coil might be dirty, or the freezer may not be freezing enough to make ice while everything else seems to be staying frozen. To see if your freezer is cold enough, squeeze your icecream carton, as that is the first to thaw if there is a problem.
there is a tank in the refrigerator section that hlds about 1.5 gal of water as you dispense it refills and pushes out the cold water. if your unit is new it will need a day to cool down the tank of water before you will get cold cold water at the dispenser
Hope this help explain how it works
