Question about E-Machines eMachines Desktop PC
The lights are on, but nobodys home
My emachine will turn on, but it wont boot up.  I get the lights on the front of the box, and you can hear the fan.  I have tried to replace the monitor and the effects dont change
  • jkho47 Jul 04, 2008
    Have emachine model t5216 with similar problem. One day worked next day power up, fan is on but nothing happens. A yellow light comes on the case but the usual blue light does not. Any help would be appreciated
    Problem Solver:
Im having the same problem with mines, so im on my laptop now. I've done some research and it turns out that eMachines has a habbit of blowing out their motherboards, and that its being caused by the design of the case for which the board sits on. So right now im debating to replace my motherboard or not. Overall I think its best to just get a new computer as the board will go out again in less than a year.
Also try replacing the power supply and the video card if you can. If switching them out doesn't work then its your motherboard :-(
Posted on Jul 05, 2008
Emachines tower turns on but doesnt boot up
When you turn it on, what happens, give as much detail as you can.
Dec 19, 2012 | E-Machines eMachines Desktop PC
Emachines t2042
Whenyou plug in the power cord is there any lights whatsoever on the laptop, wherethe plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the computer is trying to boot or may have booted,but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe you have a Static ChargeBuildup. Remove the Power Cord, then Press and Hold the power button for30 seconds. After 30 seconds plug the power cord back in and hit thepower button to see if it boots. Maybeyour memory is bad or the memory slot is bad.Removethe Power Cord, Open the Case and remove one of the memory chips. Set thechip aside then try rebooting the computer. If it boots, then you knowthe memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and tryrebooting. If it fails take the chip out and set it aside, then put theother chip in and try booting it in both slots. If it boots, just toverify that the chip set aside is bad, mark an x on it and put it into the openmemory chip slot and try booting.
Jun 07, 2012 | E-Machines eMachines Desktop PC
Unable to boot emachine 350
It is possible the battery is an open circuit, so even with the power adapter plugged in there is not enough power to boot the machine. Laptop batteries last about 2-3 years.
Jan 13, 2012 | eMachines eM250-1915 Netbook
Emachine t6216 will not boot, fans stay on high and thats it. I do not hear hard drive spinning. It shut down a couple times while in use before this and came back on. also, it did not boot before and did...
hi Rpbarnhart.
this could be a few things wrong here.
the first thing i would get checked is the power supply.
Most likely either Motherboard or the CPU. Does this have a graphics card or built-in.
Standard procedure is to:
Clear the CMOS - chk manual for procedure.
Disconnect all cables from all drives and test.
Pull RAM and try with one module at a time in slot 1. Then try 1 in what might be slot 3, the 1st slot of second pair of slots.
Before giving up, I'd pull all the drive cables at once. Even carefully mark the front case wiring and pull everything but power switch if you can. You really want to remove all complications that might be an issue. Take it down to PSU, motherboard power, cpu fan and RAM.
Ok, there is Good news, and bad news. FIRST the bad news. You are not getting any power to the CPU. Fans and lights indicate motherboard power, BUT, power supplies ALSO provide power straight to the CPU, and if the CPU is not getting powered properly, it will not function.
or you could check these links out if the above does not work for you.
Build PC Emachine will not boot up
Dec 08, 2017 | Computers & Internet
Emachine wont start
I just had the same problem. Try replacing the battery on the motherboard, that seems to have fixed mine. The number on the battery is CR 2032.
May 11, 2010 | E-Machines Emachine T5026 power supply **...
Monitor light blinks but no pic when booted up
i can try to help you, do you hear the boot beep sound? if you are not able to hear the beep sound then i suggest you to open the machine and check with the cmos battery if it is working or no. if your cmos battery is working then have a check with Power supply. if the power supply working then there might be a problem with your motherboard or cpu. now let me talk about checking the ram. if you are able to remove the ram module remove it and see if u can hear a long beep sound if you are able to hear it try to clean the ram contacts with eraser and then try installing it. i think this might help you
Jun 09, 2009 | E-Machines eMachines Desktop PC
EMachine tower doesn't boot up. Only the fan is running
try replacing your ram.if your ram is bad you wont get no picture on your monitor but your puter will start.2 if you have a video card turn off you puter for a few minutes and plug your monitor to your original display.
Nov 24, 2008 | E-Machines eMachines Desktop PC
Boot up
You may try "Last Known Good Configuration"
Boot the operating system with the “Last Known Good Configuration” feature. To use this:
  1. Restart your computer.
  2. When you hear a single beep or after the bios has read your hardware settings press [F8], this will display the “Windows Advanced Options” menu.
  3. Select Last Known Good configuration and press enter key.
Let me know.
Oct 19, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
78 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
