WARRANTY 26" LCD HDTV W/BUILT-IN DVD PLAYER. Only 2 months old. Will not change channels by remote or manually. Shouldn't this be under some type of warranty? If not, who do I contact about parts?
  • herreraj Jul 05, 2008
    Genius:
  • 1,847 Answers
Give me the make of the TV, will let you know about the warrenty details ....
thanks
Kevin
Posted on Jul 05, 2008
  • 983 Answers
Ya you can make use of the warranty ... there may be some manufacture defect in it ....
may be some screw in the board has loosed ....
  • Dileep Keshavanarayana
    Dileep Keshavanarayana Jul 05, 2008
    as you still have the warranty you just dont have to worry about it ...
    you must contact the dealer with whom you have purchased & you can collect the procedure to make use of the warranty with him or you can contact the customer care number of the company & you can collect the details about it....
    the customer care number will be mentioned on the warranty card which will be given by the dealer during the time of the purchase...
  • 2,071 Answers
Do some resetting take out the plug from the outlet ,for about 5 minutes then plug again the cord and turn on the the TV go to menu setting search the factory default setting,and change the battery of your remote control so it function normally..By the way what is the brand of your tv., so you can bring your tv to the service center because it is under warranty...
Posted on Jul 04, 2008
    Master:
  • 726 Answers
Only 2 months old yes you should have warrenty in the box did u get a little warrenty card at all?
if not you may call the company whp made the tv and ask them about the warrenty or ask them to fix or quote a price if it is to expensive to fix that way
you can call in the yellow pages a compony or private repairers also very cheap
I bought a Sanyo 26 in lcd hdtv 7 months ago. No
Try explaining the problem to the manufacturer. They will help. They may change the software if needed. After the guarantee it will become a payable service.
May 24, 2010 | Sanyo DP46849 46 in. HDTV
I have a rca dvd recorder+vcr combo drc8320n i want to set up watching/changing cabletv channels on the dvd remote. i have tried buying universal remotes cheap& expensive but they no longer work on my
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
Apr 13, 2009 | RCA DRC8320 DVD Recorder/VCR
PROSCAN 26" LCD TV with DVD won't show all the channels
bought 26 in pro scan tv can't figure out how to connect dvd player,craziest thing i've ever seen.please help
Mar 14, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
26 inch Proscan with no manual
You can find the the manual in pdf form on the PROSCAN website. look under support for manuals and find the one you need and down load it for your use. The website is . www.oncorpus.com You can also call the PROSCAN customer support at this telephone number.1-888-977-6722. I hope this has helped you with your problem.
Mar 02, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
My Sharp 42" LC42D85U tv 1 month old no picture or sound
i would take it in and have it repaired while its got a warranty on it...or take it back to the store you got it from and ask them to replace the set.
Feb 01, 2009 | Panasonic PT-56WX53 53" Rear Projection...
No power to set - yellow light blinks
If your set is 6 months old, I would suggest to have it repair under manufacturers warranty. All the electronics devices have 1 year warranty.
The failure you have with your LCD is the power supply not working properly.
Let me know if you need further assistance.
Jun 12, 2008 | Toshiba 26LV47 26 in. LCD TV/DVD Combo
Remote not working
Check to see if there is a switch somewhere on the remote that allows you to select between the TV and the DVD player. If not, it is possible that the remote or the DVD player's IR decoding is not working properly.
If you cannot resolve this, call the tech support for the TV. If the set is under warranty, it is best to persue this right away.
Jerry G.
May 20, 2008 | Insignia 19 in. Widescreen Flat-Panel LCD...
My Insignia 26" lcd tv has a built in dvd player that doesn't work.
I would suggest to call the place where you bought it and ask them for an authorized repair center. You TV still under manufacturers warranty.
I could fix it for you. I live in Brampton.
Good Luck.
Mar 18, 2008 | Insignia LCDTV26 26 in. Television
Mintek 26 inch LCD HDTV with built-in-DVD remote not working
The reason you can't pull-up the Mintek website is because the company is out of business. I have one that is frozen on one channel and none of the buttons or remote will work. I took it to a repair shop and the said one of the circuit boards is bad but since the company is out of business they can't get the needed part. The only way to get the part is to find a set which can be cannabalized for the needed parts.
Feb 10, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
