Question about Nintendo Wii Console
Wii turns on but has no picture or sound
My wii is brand new (2 days) and i've been playing with it quite a lot. One time after playing with it for a few hours, i tried to get back to the menu screen from my game and the screen went black. After 15 minutes when it hadn't changed i had to force the wii to turn off.
Now, when i turn on the wii the light goes on and if theres a disc inside it starts turning, but there's no picture or sound on the TV. I've tried another TV and it did the same thing. Also, the remotes now don't respond to the wii. They can turn it on but they can't turn it off. Also, once the wii is turned on and any button on the remote is pressed the remote buttons flash a few times. Also, the wii can't be turned off properly, the button has to be held down for 5-6 seconds.
Does anyone have any ideas? i left it for about 1-2 hours and it still does the same thing.
The fact that the wii remotes don't respond properly makes me think its not the cables from the wii to the tv, as if the wii itself worked properly so would the remotes.
Any help is much appreciated :) <3
    Guru:
  • 155 Answers
You could try resetting it by taking out the motherboard battery.
It is on the bottom at the back under a plastic cover.
You may need a tri wing screwdriver to remove the cover.
Try taking this out for a couple of hours and it will reset it.
Hope this helps,
Mowcius
Posted on Jul 04, 2008
4 Suggested Answers
  • 6 Answers
SOURCE: Every time a game is put in the Wii says 'unable
You could try a 3rd party slot cleaner, or use the tried-and-true retro Nintendo console method of blowing into it.
How scratched is the disk? If it's really beat up, that might be the problem right there.
I had a similar problem before, and neither of my methods worked. I had to get it fixed by Nintendo themselves. Hopefully you don't have the worst-case scenario!
Posted on May 07, 2011
  • 1382 Answers
SOURCE: wii console is not responding
If there is no LED on, then the most likely reason is, that your wii isn't getting power. So the problem, is with the plugs, and the power adapter. If you have a friend who has a wii, try testing his power adapter on your wii. Make sure your cords are completely plugged in, on both sides, (the outlet and the wii) then press the power button on the wii. If that do-sent work, try turning it on with one of your wiimotes. If that dosent work, that means your wiimote is not synchronized with your wii. To sync. it, open the sd card cover on the front of the wii, press the red button above the sd card slot. Then open the bottom of your wiimote, (where the batteries are) and press the small red button that should be beside the batteries. Then hold the wiimote close to the wii,then after its done flashing, press the power button on the wiimote and also, try plugging your power cord into another outlet. If it still won't work, you've got a broken wii, so you better send it to get replaced or fixed, again as suggested. DON'T OPEN IT! You could loose your warranty if you open it, so it's safest not to. Hope you get it to work
Thank you !!
Posted on Jun 18, 2010
SOURCE: wii remote hand not showing up on screen
I had the same problem where the hand would only show up on the wii menu by pointing it due left. I tried syncing it, replacing batteries, turning on/off the console. It finally started working when I just unplugged and plugged back in the sensor bar from the console while it was on. Hope it helps.
Posted on Jun 07, 2008
When I was playing my wii there was a loud buzzing noise I tried to turn it off but it wouldn't so I unplugged my ac adapter and now it won't turn on what is the problem?
Your Nintendo Wii seems to have some technical issues which needs to get repair. You can either send it to repair shop for repair and wait for 2-3 weeks time and a huge bill; OR you can repair it yourself at home.
I would suggest you to try Nintendo Complete Repair Guide that would save you both time and money. It is easy to understand with lots of pictures and user friendly instructions. I used it myself and am fully satisfied with what I got! This Wii Repair Manual works like magic very efficiently.
Apr 01, 2011 | Nintendo Wii Console
Wii makes a buzzing sound when discs are running
The noise is the wii working extra hard to read the disk the lens might be dirty. Your wii might also have a bomb in it.............Just kidding. I would try cleaning the inside and if all is bad send it in to get fixed
Apr 10, 2009 | Nintendo Wii Console
My Wii stopped playing some games.
Check the system menu for any system updates.
Jan 01, 2009 | Nintendo Wii Console
BRAND NEW WII-HAVE SOUND BUT NO PICTURE
When you turn the Wii on, and the light goes from red or orange to green, press A a few times (this would be to get through the warning/safety screen) then wait a minute. Then when you wave your remote about, you will feel it vibrating as it goes over the channel icons on the wii menu screen. Plus a blue light will be lit at the bottom of the remote to denote player 1.
If all of this happens, it is just a lead or TV input issue. If these things do NOT happen, the Wii is broke and needs fixing by Nintendo!
Also, check the refresh rate on your television an make set to be compatible. That may also cause a picture not to show up.
Dec 25, 2008 | Nintendo Wii Console
Wii frezees after inserting Wii Fit Disc!!
You may check out Wii Fix Guide to fix the problem yourself. This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.
Dec 06, 2008 | Nintendo Wii Console
Error
it`s probobly the disk some how got an error or the disk is scratched check if there is any scratches ok
Nov 21, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
524 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
