Question about Garmin eTrex Legend GPS Receiver
Etrex reset instrucitons
There is no page up button on an etrex
    Brigadier General:
  • 6,966 Answers
If your Garmin eTrex is a Legend and you want to do a "Reset", pls try:
Hard Reset:
With the unit turned off, press and hold the follow buttons: PAGE + Enter on the click stick. Then press and release the POWER. The unit will power up asking if you want to release all user data. Select yes, and the unit will be reset. After the master reset, place your unit outside, so that it has a clear view of the sky for 25 to 30 minutes for the unit to acquire new almanac data.
This was originally posted here and a wealth of other Legend information.
Alternately, this has been posted here at FixYa as well. Pls see this post.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 04, 2008
Vista etrex cx will not acquire satellites . It worked okay the last time I used it.It then says poor reception .Use with GPs off. Its a clear day and was yesteday when i tried to use it. There seems no...
My Etrex Legend would not aquire satellites and after several call to tech support, I finally reset the whole unit. First I saved the waypoints on Mapsource. Then with the unit off press and hold the page button (upper right) then push the rocker button in and then push the power button. Once it starts you can then release all the buttons and set the unit outside for about 20 minutes.
May 22, 2010 | Garmin eTrex Vista Cx GPS Receiver
ETrex Venture HC Car GPS Receiver: How do reset unit back to factory spec's...
Hi!
From your owner's manual, to reset to factory defaults (Page 34)
http://www8.garmin.com/manuals/eTrexVenture_OwnersManual.pdf
Select the route page options button and press the Thumb Stick in to access the options menu.
Select "Restore Defaults" and then press in on the Thumb Stick to restore factory settings.
Hope this is of some help to you.
Good Luck!
May 07, 2010 | Garmin eTrex Venture HC GPS Receiver
I just purchased a Garmin Etrex Summit GPS receiver. The function that I most need is the Sight 'N Go, but when I access the pointer page options list the Sight 'N Go option is 'greyed out', although the...
It is greyed out when the electronic compass is off. Switch it on by holding down the top right button for 2 seconds. A confirmation message flashes up on the screen.
Apr 19, 2009 | Garmin eTrex Legend GPS Receiver
Etrex vista will not display any map
I had the same problem for months. i don't know what part of this worked or if it was a fluke that it finally worked. I downloaded the newer firmware for the garmin and installed it ( http://www8.garmin.com/products/webupdater/ ) then tried adding maps, that didn't work, then tried 3-4 times resetting the garmin, and each time tried adding maps and it didn't work - turns out I wasn't really resetting it (I think) it appeared that the successful reset was holding down the clicker key and the pages key while starting up, and keeping them held down for a long time (15 seconds?) - there was no sign that it was resetting except a faint illumination, then when I let go of those 2 keys it went through the setup sequence. the only way I knew it had finally reset was when the page came my pointer was in the middle of the united states. I had repeatedly tried resetting before and the pointer/map page came up to where I was last at, so it hadn't really been resetting. I'm very displeased that it took 5-10 tries to get this to work and this happened on 2 units.
I reloaded the maps after it had properly reset and they actually display and are on the map list!
this is the second etrex unit ive had this problem with, and the first one was just as flaky - taking many reset events (see master and super master reset on other etrex threads at this site)
Mar 15, 2009 | Garmin eTrex Vista GPS Receiver
Garmin Etrex Venture doesn't aquire satellites
I have an eTrex and you can reset the defaults which may help. I don't see any 'reset' operation in the manual other than Restore Defaults.
After switching on and letting the unit go through its initalisation press the button on the front (next to the etrex name) until you get to the main menu. Select Setup and press. Select System and press. Move the button to the left and press. Press the button again to restore defaults.
HTH
Peter
Mar 05, 2009 | Garmin eTrex Venture GPS Receiver
Garmin etrex gps
Most reset would revert the unit back to factory default and therefore may and could erase all user stored settings and configurations.
Having been forewarned, Pressing "up"+"enter" keys while powering up the eTrex will reset the eTrex to factory defaults. So, all pressets and data will be lost.
Additionally, you may be able to do bypass and other tricks using the "Secret Startup Commands for Garmin handhelds".
Tight lines and hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 04, 2008 | Garmin eTrex GPS Receiver
Etrex - can't find satellites anymore. Just stopped one day after downloading Points to my pc
To my knowledge, a reset on a Garmin eTrex would require:
Holding down the PAGE and PAGE UP buttons while simultaneously powering the unit. The Garmin eTrex will enter the service mode/display:
- Bravo Version
- Software Version
- Time
- Internal temperature of unit
- Battery voltage
- External voltage
- Button presses
- Other tech info
You can also perform an LCD display/screen check by pressing the PAGE button 2X.
A firendly word of advice: While entering the service mode is interesting and useful, be careful which buttons you press because it is also possible to rest the unit to factory settings within this mode. Pressing "up"+"enter"+"on/off" keys in service mode will reset the eTrex to factory defaults. All presets and data will be lost.
To exit just turn it off as normal, and then turn it back on as normal. Unless you deliberately reset the GPS, nothing should have changed.
Alternately, you can try: Hold down the find, click-stick, and page buttons. Press the power button, and when the title screen appears, release the buttons. This will clear all memory (you will lose all waypoints, etc. back them up first).
Find button: bottom button on the left
Click stick: the button on the face of the unit
Page: the top button on the right
Power: the bottom button on the right
Jun 26, 2008 | Garmin eTrex GPS Receiver
Garmin Vista Shutting down and freezing up
People! The problem is that your software version needs updating. A recently added satellite creates a glitch in the older software. Go to the Garmin website, load WebUpdater if you haven't already done so, and the updated version (3.8) will automatically install to your Garmin unit. I had the same symptoms, they have now disappeared and my Etrex Vista is back to normal.
May 27, 2008 | Garmin eTrex Vista GPS Receiver
Resettting
Hard Reset
1. Hold the Page button down, the click stick in the down position and power up the unit.
2. Release either the Page or click stick to normally power on.
Apr 20, 2008 | Garmin eTrex Legend GPS Receiver
Garmin Etrex Vista Date problem
Thanks to a hint from a user on another web forum, I have found a fix, at least for now.
Specifically, a normal "master rest" on the eTrex Vista is accomplished by holding down the "Page" button and "Enter" (i.e. the click stick) while powering up. You are prompted that a full reset will occur, and after confirming, the machine is reset. However, in my case, this achieved a full reset, but did not fix the date problem.
However, the undocumented "super master reset" on the eTrex Vista is achieved by simultaneously holding down the "Page, "Enter" and "Find" buttons while powering up. You have to hold all buttons in for about 5 to 7 seconds, and you DON'T get the warning message, but when the machine finally restarts, it is fully reset. After acquiring a satellite fix (took several minutes) - lo and behold - my time AND date both seem to be correct!
Oddly, neither Garmin tech support nor the local reseller seemed to know about this method of REALLY resetting the machine - I will pass on the information to them, for future reference.
The link which documents the "super master reset" procedure is here: http://www.gpsinformation.org/dale/secret.htm#reset
Hope this might also help other eTrex Vista owners who are experiencing the same date problem.
Nov 17, 2007 | Garmin eTrex Vista GPS Receiver
Garmin eTrex Legend GPS Receiver Logo
3,371 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
