Question about ParkerVision SIGNALMAX WR1500 (884181000031) Router
Wireless speed The wireless router is sending out a real weak signal. How do I increase the signal? I am sitting next to the unit and its only at 11 mbps.
    Novelist:
  • 173 Answers
First you need to check what is the standard of your wireless adapter that is installed on your computer(to check this well you need to grab the manual or check the specification of the computer or adapter) if it's wireless b 802.11b the maximum speed that you'll be getting is 11Mbps regardless if your router supports N standard 802.11n which can get you through a maximum of 230 to 280Mbps tops.
Second, check the wireless settings of your router make sure that the wireless mode is set to auto or mixed.
Posted on Aug 06, 2008
Tip
How to improve signal strength on a wireless network
The success of a wireless network depends on the signal strength. A strong signal is required so all networking devices can communicate with each other. A weak signal causes low bandwidth preventing communication between hosts and causing network disruption. <br /> <ol> <li>Pay attention to router placement. It should be away from walls, floor, and glass and metal objects, all of which disturb wireless signals. If possible, place the router in a central location.</li> <li>Change your router's standard antenna to use a high-gain antenna that sends signals in one direction. This way signals can be focused in the required direction. Standard antennae send signals in all the directions, which may not be desirable especially if the router needs to be placed next to a wall.</li> <li>Use a wireless repeater, the device that enhances range of a wireless network.</li> <li>Change the channel on which the router is functioning. Similar to radio stations, routers function on different channels one of which may give better performance than the other.</li> <li>Ensure the network card installed in the hosts is capable of receiving and sending signals to the router. In this respect, using equipment from one manufacturer is better.</li> <li>Check the vendor's site regularly for latest updates, performance enhancing tips and fixes.</li></ol> if you need more information regarding improvement of wireless network, visit<a href="http://www.microsoft.com/athome/setup/wirelesstips.aspx"> THIS</a> site.
on Dec 13, 2010 | Computers & Internet
Wifi signal is very weak
Things That Affect Wireless Router Signals
1. Many wireless routers are using the same wirelesschannel. Many manufacturers choose channel 6 as the default. Change to anotherchannel.2. Analogue video senders used to send audio and video toother TVs in the home.3. Microwave ovens emit interference in the 2.4GHz band.4. Wireless speakers and console controllers can causeinterference with the wireless router.5. Bluetooth devices, newer Bluetooth devices can jump todifferent frequencies if there is a connection problem.6. Power cables located near the wireless router can causedropouts and speed reduction.7. Fish tanks will cause massive Wi-Fi shadow on the otherside of the tank from the wireless router. 8. Depending upon the location of large mirrors will reflectwireless signal away your computer.9. Building materials will block wireless signals such asplasterboards with metal foil, reinforced concrete walls and floors. Alsoobjects near the wireless router such as metal filing cabinets and otherelectrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performanceby 25% when it is close to the wireless router.
Jun 29, 2012 | Paradyne Computers & Internet
Me tp-link give weak internet and some times dissconected but when i uesed by wire give excellant internet speed
Most probable cause is the materials used in the construction on the home/office or where ever you have the router. Your options would be to move the router to a more central location or you could invest in some repeaters/wireless extender to extend the range of the signal. IF you use wireless extenders please note you will need to make sure they all have the same SSID (name seen for your network) and make each device is on either channels 1,6 or 11. So your first device would be say 1 (Doesn't matter which you pick) the next device would be on 6 and then next on 11. If you had another device, hypothetically you would want it on 1. These three channels do not overlap enough to interfere with each other.
Apr 09, 2012 | TP-LINK TPLink Tp link Tl wr940n 300mbps...
My signal strength is very low
You Can Try Changing the Wireless Channel on the Router you have 11 Different Channels Available.
> Steps to change the Channel
- Open Internet Browser on Hard wired computer & Go to 192.168.2.1
- Towards your Left Corner Under Wireless Click on Channel & Ssid
- Leave the Password Blank Click on Submit
- Change the Wireless Channel To Number 1 or 6 or 11.
- Click on Submit
- Check the Signal Strength
- If you Still Have Low Signal Strength you Can Try Updating the Firmware or Changing the Wireless Mode to G only... :)
Mar 06, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How can I increase my WIFI range. My internet signal is very weak when I am in my bedroom. Can I increase my range by possibly buying a signal extender.
Try moving the wireless router around and or higher.
If the wireless router is in a different room and the room has concrete walls of foils insulation in the walls, this will weaken the wireless signal. AND/OR
You can connect add a antenna to your computer. Have a look at this device. Normal 0 USB High Gain Antennas www.pricewatch.com/gallery/networking/high_gain_antenna
Oct 25, 2010 | Arris SURFboard SBG900 Wireless Router...
Belkin Router Signal Weak
Wireless configurations are tempermental over larger distances. Some routers do have the ability to increase the signal strength to over come this, but a good location is key.
The more obsticals in the way the slower the connection will become. Closed doors, being buried under books, underneath desks, can all cause the signal to come through a slower speeds to compensate.
Make sure your router is in an elevated location to help with a less blocked signal.
Are you using a Wireless-N adapter on your computer? If not, you might need an extender because Wireless-G does not have the same range as -N.
With the model number of your Belkin router I might be able to assist more.
Jan 20, 2010 | Linksys Wireless-G Broadband Router
Wireless Network Connection constantly reading low/vlow/no signal
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply).
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Jan 04, 2010 | Computers & Internet
My wireless router signal is weak. How do i make it stronger so i dont have to be sitting next to my router to use my laptop?
connect wireless receiving antenna to laptop (if you have input for it in your wireless card), or connect transmitting antenna to router, or both
Nov 01, 2009 | D-Link DIR-615 Wireless Router
My PC cannot see the wireless signal.
The reason why your PC can't see the wireless signal is because it is too far from the router. Or your wireless card is too weak to detect the signal from the router, its either the antenna it bad or loose, you may need to double check that. You may consider changing the channel on the wireless router to channel 11. Try to power cycle the router as well.
Jun 20, 2009 | SMC Barricade g SMC2804WBR Wireless Router
ParkerVision SIGNALMAX WR1500 (884181000031) Router Logo
50 people viewed this question
Top ParkerVision Computers & Internet Experts
Aris C.
Aris C.
Folusho Adeyanju
Folusho Adeyanju
Larry Maranto
Are you a ParkerVision Computer and Internet Expert? Answer questions, earn points and help others
