Question about Belkin (F5D5231-4) Router
Belkin N1 wireless router
Hi-  My Belkin N1 router is working to the desktop to which it is hardwired, but the wireless icon is not lit and I am not getting wireless reception.  I have reset the router, and I have turned off power for a couple of minutes, and rebooted by going to 192.168.2.1 as Sandrew mentioned on a previous post, all to no avail.  All other icons on the router are lit, and the connection to the desktop is fine.   Any great ideas?  Your help is greatly appreciated.
  • 2 more comments
  • docholiday37 Jul 04, 2008
    Hi (I'm on live chat with Maanita right now)
    I didn't turn anything off, and I'm not sure how to check that.
    docholiday37
  • Anonymous Jul 16, 2008
    same as docholiday37's
  • SCOTT NELSON
    SCOTT NELSON May 11, 2010
    do you have your computers wireless adapter turned on?
  • Anonymous Mar 23, 2014
    I have a Dell Latitude D630. Earlier it was connecting fine and now, I'm not able to connect. It tells me there is no wireless available. The desktop works fine. It's connected to the ethernet. The light on the router for wireless is not lit up. I have reset it and nothing changed.
FixYa's Maanita was no help whatsoever, and worse, a complete waste of time.  I called Belkin who's tech guided me to the problem in ten minutes, whereas I wasted an hour and a half with FixYa.
Posted on Jul 04, 2008
SOURCE:
Hi, I'm using a Belkin N1 wireless router. I mostly have a stable internet connection, but once in a while the "wireless" icon start blinking orange. What is this? My internet some times get...
if the wireless light is lit up in red it says "someone is trying to connect to your network using wrong password"
Sometimes if any of your devices are not compatible with the security enabled in the router then the light will lit up in red. click here to know more about security types of belkin router
routers has to be turned off atleast 2 hours per day for it to work properly... so better turn off the router when not in use, this will clear the routing table of your router and will make the router to work as a fresh router everyday, so you wont face any speed problems.
May 03, 2011 | Belkin N1 Wireless-N Wireless Router
Cant gain access to change settings on my router Belkin N1+
hardwire any computer to one of the wired ports in the router...
type 192.168.2.1 in any web browser and log in to router setup utility manually....
password....leave it blank and click submit..
now you can configure settings manually....
Apr 20, 2010 | Belkin N1 Vision Wireless Router
I just bought a belkin n1 wireless router at a thrift store. everything works but the wireless part. its all hardwired to my desktop, but my laptop won't pick up a signal from it.
I would suggest going into the router itself at 192.168.1.1, and reset to the factory settings, or if you are familiar enough with router configuration, make sure your SSID is being broadcasted. Also, make sure you are currently using the up to date firmware.
Also make sure you are using the correct security settings to connect up to the router once it's discovered under the "Available Wireless Networks".
Dec 20, 2009 | Belkin (F5D8231-4) Wireless Router...
Trying to create a bridge with two routers
You do not need a bridge if you are using a wireless adaptor on your pc in the other room. Just set up the Belkin Plus router to the WEP security settings you want and make sure the pc wireless usb adaptor has the same settings as the router. You should be good to go. Good Luck.
Jul 15, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin N1 wireless network not working
It might be an idea to upgrade the firmware which can be downloaded from manufacturers' website
Mar 20, 2009 | Belkin N1 Vision Wireless Router
My Belkin N1 and my xbox 360
I just got it and yes latest firmware as of end of mai has been downloaded
Jun 02, 2008 | Belkin (F5D8231-4) Wireless Router...
Belkin N1 Wireless not STAYING connected
change channels to 1-6-or 11. Make sure you change all of them.
Jan 07, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
Wireless router belkin n1
Right click on the network icon in your task bar and click view wireless networks, then when all the networks show delete them all and close the window, next, a pop up will say found wireless connections click the icon again and look for your connection in the list and click connect and enter the pass phrase
Nov 05, 2007 | Belkin (F5D8231-4) Wireless Router...
Downloads locks up - Belkin N1 Wireless Router
I had the same problem. My Belkin N1 Router was constantly dropping the WiFi connection (every few minutes). I tried several solutions I found on different forums:
Change the channel selection from Auto to a specific channel -- I tried all 13 channels, but no improvement.
Update the firmware to the latest (Beta) version -- still no improvement.
Finally I enabled "Protected Mode" and the connection seems fine now. Hope this helps, and good luck!
Can not identify Belkin N1 Wireless USB Adaptor on PC
Hi, A couple of things: 1. Have you tried all the USB ports of your desktop PC (front and back)? 2. What is your desktop PC brand/model or at least the motherboard? and What OS please?; 3. If running Windows in the desktop PC, can you please check in your Device Manager if your USB are 2.0? 4. Are you using a USB hub or directly connected to the PC's USB port? Hope this be of some idea/help. Pls post back with your desktop brand/model/motherboard. Good luck and kind regards.
Sep 16, 2007 | Belkin N1 Wireless USB 2.0 Network Adapter...
Belkin (F5D5231-4) Router Logo
180 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
